CLS Coupe (C219) Discuss the CLS Coupe.
Where is the aux battery? CLS550
Old Apr 27, 2013 | 09:04 PM
titanium681's Avatar
2007 cls550
Hi all,
Have searched until I'm blue in the face and can't find the answer. Could someone please tell me where the auxillary battery is located on an 07 CLS550? The upper left cover near the bottom of windshield contains a filter, and the right cover contains a fuse box. Can't see anywhere else it could be.
Help!
Old Apr 27, 2013 | 11:00 PM
Bullwheel's Avatar
W219 CLS 63 AMG
SHould be under the filter housing....
Old Apr 28, 2013 | 12:54 AM
2007 cls550
Thx alot for the vid. The reason that I couldn't find it, is because it's not there. I bought this car used, and did not know that it was suppose two batteries. Will this cause a problem, not having an aux battery? I've been driving the car for a little over a year without it.
Thx
Old Apr 28, 2013 | 01:49 AM
mbenz1's Avatar
2007 CLS 550 and some other MBZ
From my understanding only the 2006 500s and 55s have secondary battery and not the 2007 and up 550s or 63s
Old Apr 28, 2013 | 02:26 AM
2007 cls550
Thx for the update.
Old May 22, 2019 | 09:20 PM
Byron Rhodes's Avatar
07 cls 550
Did you find it
Originally Posted by titanium681
Hi all,
Help!
Hey im having the same issue with my 2007 cls 550 the aux battery is not under the air filter cabin plz help me to locate this small battery
Old May 23, 2019 | 02:05 PM
konigstiger's Avatar
'71 Pinto
2007 does not have an auxiliary battery.
Old May 24, 2019 | 03:39 AM
07 cls 550
Plz help
So I just changed the battery in the trunk and it's still giving me the red battery light is it the alternator?
Old May 24, 2019 | 12:01 PM
'71 Pinto
Most common alternator, voltage regulator, or corroded battery terminals. Have someone pull fault codes before you start replacing parts. See attachments.
File Type: pdf
File Type: pdf
Old May 25, 2019 | 08:50 PM
07 cls 550
It was the alternator
Old Mar 14, 2023 | 01:56 AM
kenner's Avatar
2007 CLS63 AMG
Well, I can certainly believe that the 2007 cls amg does not have an auxiliary battery, because I cannot find it! The owners manual states that the 2007 has two batteries, and says the auxiliary batt is in engine compartment. The aux batt is not under the cabin filter. I do have the red battery light in the dash and have already replaced the main battery in the trunk. I bought a replacement aux battery from auto parts store, and they sold me an auxiliary battery to fit the 2007, and I saw it on his computer screen as a 2007 replacement. Before I return this battery, can you confirm that the 2007 cls only has one battery. Thank you for your help!
Old Mar 14, 2023 | 11:43 AM
'71 Pinto
Provider VIN, I'll provide confirmation.
Old Mar 29, 2023 | 03:55 PM
kenner's Avatar
2007 CLS63 AMG
2007 CLS63 AMG
WDDDJ77X57A095286
Old Mar 29, 2023 | 04:47 PM
'71 Pinto
Confirmation, aux battery (90) is greyed out meaning not applicable.
File Type: pdf
Old Dec 17, 2024 | 04:19 AM
Michael Lockha's Avatar
Hi all,
Help!
it's a battery overload relay module in truck follow ground wire rear passenger quarter panel.
Old Dec 17, 2024 | 04:27 AM
It is none for my 2008 cls550.
Hi all,
Help!
did you find the cause because there is no second battery.
Old Jun 22, 2026 | 05:47 PM
Royal Nelly's Avatar
2007 cls550
my vin# WDDDJ72X27A110401 can you check for the aux battery plz
