Unable to Change Speedometer from KMH to MPH
C220 Premium AMG
Hi all,
I seem unable to get the readout to change from KM/H to MPH as in the photo below. I have successfully changed the setting to change the main readout in the centre of the cluster but KM/H still shows in the top left hand corner (beneath the bluc "C"). Can this be changed? This is a UK C220 2014 BTW (my log book says W204 but is this not a W205?).
C3004matic, BMW 328d xdrive
in yous Operator's Manual
Displays and operation
Settings menu
Selecting the unit of measurement for distance
The Display Unit Speed-/Odometer:
function allows you to choose whether certain
displays appear in kilometers or miles in
the multifunction display.
X Useòon the steering wheel to call up
the list of menus.
X Press the:or9button on the steering
wheel to select the Settings menu.
X Confirm by pressingaon the steering
wheel.
X Press the:or9button to select the
Instrument Cluster submenu.
X Pressato confirm.
Display Unit Speed-/Odometer function.
You will see the selected setting: km or
miles.
X Press theabutton to save the setting.
The selected unit of measurement for distance
applies to:
RDigital speedometer in the Trip menu
ROdometer and the trip odometer
RTrip computer
RCurrent consumption and the range
RNavigation instructions in the Navi menu
RCruise control
RDISTRONIC PLUS
RASSYST PLUS service interval display
Settings menu
the list of menus.
wheel.
X Pressato confirm.
miles.
applies to:
RTrip computer
RCruise control
RDISTRONIC PLUS
Settings menu
the list of menus.
wheel.
X Pressato confirm.
miles.
applies to:
RTrip computer
RCruise control
RDISTRONIC PLUS
Settings menu
the list of menus.
wheel.
X Pressato confirm.
miles.
applies to:
RTrip computer
RCruise control
RDISTRONIC PLUS
I have another problem. I have a car with US specifications that I want to bring to Europe the odometer in miles, the temperature in F; and see my post:
https://mbworld.org/forums/c-class-w...ce-canada.html
2020 CLA 250 4Matic Black
I used the steering control to go to settings and this was the only option under secondary display
Here in Canada you can change the top left (Secondary Display) to show MPH while leaving the center display to KMH
The A under the C means that you have automatic high beams turned on. When dark and no other vehicles in front of you, the high beams will turn on/off automagically. You can disengage using the light stalk. You do have to have the headlights on auto as well.
The little speedometer shows the speed in opposite units. If the main speedometer is mph then the little one is kph, and vice versa. The options only allow that little speedometer to be turned off
BMW e89 Z4 sDrive 35i & MB S205 C200 AMG Premium Plus
Hi all,
presumably you want mph at the top left because you want something else in the centre than mph? Personally I just look at the speedo and find the alternative kph scale useful for reference.
Mercedes-Benz S-Class 2012 4.7L
I couldn't change it either. Here is a lifehack I did:
Convert your necessary speed limits with something like this: https://oneconvert.com/unit-converte...ter/kph-to-mph
Write them down on white tape and place them on or near your speedometer.
Seeing them every day will make you get used to both.
You will always see km and mph or mph and km. In my car i see km, km in the middle and mph on the lower left side. If I swap it, i see the opposite
