Footwell Lights / Door Courtesy Lights?
Old 03-01-2015, 07:06 PM
cjmoy's Avatar
2015 GLK250 Bluetec, 2011 BMW 335d
Has anyone retrofitted footwell lights or door courtesy lights to their GLK?
I don't have the ambient interior lighting package, so it is pretty dark at night.
I really miss the footwell lights and door courtesy lights from my previous VW.
They are really helpful when getting out of the car in a dark garage, especially with a black interior.
Old 03-03-2015, 06:13 PM
rmfnla's Avatar
2013 Infiniti G37 Coupe; 2011 GLK 350 w/ Premium 1, Multimedia & Sport Appearance; I LOVE IT!
http://www.ebay.com/itm/2-x-Laser-LED-Door-courtesy-Shadow-Projector-Lights-for-Mercedes-X166-GL-AMG-/221613637744?pt=Motors_Car_Truck_Parts_Accessories&hash=item339933c070&vxp=mtr
These are all over ebay; they crack me up...
Old 03-03-2015, 08:27 PM
cjmoy's Avatar
Originally Posted by rmfnla
Yeah, I'm looking at adding the stock ones, not these.....
My doors have reflectors only not the active lights and I don't have anything in the footwells.
Old 05-15-2015, 01:26 PM
reesepcpatel14's Avatar
GLK
any luck with putting those stock lights in the door
Old 05-17-2015, 09:18 PM
MKenM's Avatar
2010 GLK Black, Premium 1, Lighting, Multimedia, Appearance and Media Pkg, 2012 Corvette Grand Sport
When I unlock my car at night my cabin and dash lights come on for about 20 seconds until I get in the car and start it. The same goes for my headlights. I always leave my headlights on automatic. I never have a problem at night. Mine has a switch on the overhead console to activate the interior lights when unlocking the car.
Old 10-25-2015, 07:38 PM
cjmoy's Avatar
Well, I'm halfway there. It took a while to get the appropriate information, but I finally have the factory footwell lights fitted and working.
Old 11-01-2015, 06:46 PM
RustyHoook's Avatar
glk 350
DO TELL!!! I'm looking for the same lights.
Old 11-03-2015, 10:11 PM
Mystic2k's Avatar
2011 GLK 350
Please share us how you retrofit it. I'll like to have it done to my 2011 GLK as well. Thank you.
Old 11-04-2015, 01:47 AM
SPONSOR/MBworld Guru
AZN Optics's Avatar
Looks great. Was there an actual socket to plug the footwell housing into or did you run a tap to a different trigger wire? If you had to run a tap, the problem is you probably wouldn't have two current levels (torch vs ambient vs off) when door is open and closed, but if there was a factory plug that just had to be plugged in and functioned correctly, that's awesome.
Old 11-06-2015, 02:46 PM
Pacific208's Avatar
C207 E350C
yes, please spill the beans!
I found a USA source for oem light housings under $8 each if I'm reading the part number right. Connecting is the question. Same for the door panel lights. I got replacement housings for the reflectors but when removed didn't feel / see anything up in the door. Have to take the panel off and look for a module or connector.
Old 09-27-2016, 07:28 PM
G-Daddy350's Avatar
2010 GLK350 4Matic
What's up? Was wondering if you had any guidance for installing door lights on GLK. Much to my dismay, I too only have the reflector installed (I'm assuming. I haven't taken the door panel off yet). I just got this in the mail:
http://www.ebay.com/itm/122083029610
And I can't do anything with it. About to do the necessary research, but please let me know if you have any information that might prove helpful.
Old 04-08-2017, 12:04 AM
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
HOw about an update?
Old 05-04-2017, 12:07 AM
travelingj's Avatar
2013 GLK250
It would be nice to hear how people made it work. I tried to buy lights to go in the footwell and to replace the reflectors in the doors. The reflector replacement didn't fit at all, and the footwell lights didn't appear to have any plugs available for them.
Old 05-26-2017, 08:06 PM
Vinnymagic's Avatar
GLK
Hello everyone,
I am new here but wanted everyone to know how I wired in welcome door lights on my 2013 GLK that only had reflectors in the doors. I tipped down the console that houses the interior light. See the picture
Once you tip down the console turn the light sockets a quarter turn and remove the socket and solder the wires on the side and then
snaked the wires towards the windows (remove the sunshade courtesy light) that makes it much easier. You will need to flex the trip that runs along the interior windows down the door. Next sneak a wire inside the door through the door conduit into the foot floor area on both sides of the SUV.
The door wires can be run by removing the part of the door that pops out (horizontal) from the door window switch. See the second and third picture
Old 05-31-2017, 04:29 PM
tasty's Avatar
2014 GLK350
how were you able to get the wire through the conduit without taking the door apart? It was very tight for me trying to pull a wire through there.
Old 06-22-2017, 02:19 AM
travelingj's Avatar
2013 GLK250
Do you have links to the lights that you used? Everything aftermarket I have bought for this car, has failed. Even when it says it's for a 2013 GLK, it doesn't end up fitting.
Old 12-15-2017, 07:07 AM
JohnnyC's Avatar
2013 GLK350
I am in the process of installing footwell lights in my glk
Old 12-17-2017, 01:39 PM
Flipbound18's Avatar
2015 Mercedes Glk350
How too coming soon ? I need this in my life.
Old 12-20-2017, 07:44 PM
Updates ?
Old 12-20-2017, 10:53 PM
JohnnyC's Avatar
2013 GLK350
i got the lights but the cable harness still has to be made. You can do the lights with a set of wires independent from the cabin harness, but that just looks sloppy to me.
Old 12-21-2017, 12:19 AM
I need a wiring diagram to find out where to run to the oem relay.
Old 12-21-2017, 01:49 AM
JohnnyC's Avatar
2013 GLK350
I don't have access to that. That's another reason why i'm just gonna use the factory harness. I don't wanna go through all the mess of tracing wires and making new wiring.
Old 12-21-2017, 06:22 AM
I have access to all data at work and my buddy works at Mercedes-Benz dealer here in town. I may can get more information about that.
Old 01-02-2018, 01:25 AM
-phoenix-'s Avatar
2007 C230 - 2011 GLK
I have a 2011 GLK350 and have a question
I don't have the lighting package but want these, is there a pre-wired plugin for these if I order OE lights from MB? Or would I have to wire these independently like above?
Old 01-30-2018, 04:51 PM
JohnnyC's Avatar
2013 GLK350
Well finally got around to this again, the local dealers (Yes i called several) doesn't want to work with me and look up the part number! BOO!
One stated that I'm looking at several thousand dollars just for the wires and another few thousand to disassemble the car. WHAT?
I don't remember the part number is that expensive, even if it was $300-400 I would still do it. I bought a pretty long Benz wire harness set a while ago and it was only $30. But I suppose I will just get the local Audio shop to build me a separate connection from scratch if I can't order the original harness.
Rate This Thread
Rate This Thread:
Quick Reply: Footwell Lights / Door Courtesy Lights?
