Need input in TURBO M273 Project
So guys, I have been debating on whether to be unique and do something I have yet to see, or whether to just become part of the AMG herd. While I love the AMG's, I also love my CLS550 and want to do something different with it.
Here's the idea, in crude terms;
Rear mount twin turbo set up with it's own oil supply with an FMIC.
Obviously, a lot more goes into this, been around 2JZ's for a while and boosting isn't new to me.
However, engine management is my main concern? Do these ECU's allow maps to be changed to accommodate the turbocharged pressure? Would engine management be the largest concern most of you have as well?
Thoughts and input is appreciated as I will start compiling a list necessary to move forward with the project.
Thanks!
Thanks!
I follow most of what you are planning here. "been around 2JZ's for a while and..." No sure what you mean here.
Anyway, if your car is betwen 2006 and 2009 model years, I would do one very important check before adding the kind of money you are thinking of adding.
Compression check on all cylinders! I would want them all to be better than the factory 5% delta before adding any load to the lower end.
The M270, M271 and M273 engines, built between 2006 and 2009 have valve guides with inadequate heat treatment. The hardness is not sufficient to resist wear and leaks develop. Valve guide leaks = low compression.
Easy and inexpensive job.
dokdokter (03-24-2022)
Thanks!
Thanks!
Antman604 (09-22-2024)
I think the Bosch Me9.7 can be made to work with boost, but torque based with no wastegate control that I've found so far.
Had great gains NA using Winols, I don't see why we cant have a higher expected tq to make room for boost
I'm in the middle of trying to rear mount a single on a e550
MikeG132 (10-14-2023)
Searching for the same thing here. Following. It makes me upset that no one makes performance parts for this model. 😭… understandable.. But damn nadda? Alls people wanna do are copy and paste builds lol
Also looking to turbo my cls550 in the near future here after i figure out these last couple issues im having lol! As for performance pars.. they are out there. Just takes more searching or fabbing 😉
https://www.carid.com/
https://www.uspmotorsports.com/
Custom tube assemblies:
https://www.woolfaircraft.com/motorsport/
