Seat doesn't move back with Easy Entry/Exit Option
Old 03-04-2015, 06:22 PM
miketc's Avatar
W205
With Easy Entry/Exit option on, the driver seat does not move backward when leaving or entering my car. The steering wheel does move upward.
What gives?
Old 03-04-2015, 06:26 PM
jkyriakou's Avatar
C250 CDI coupe, Obsidian Black Vision Pack, Drive Assist Plus pack, Comfort Pack, Rev Camera
That's normal.
Old 03-04-2015, 06:30 PM
miketc's Avatar
W205
According to the operator manual, the feature moves the steering wheel up and the driver seat backward so why is it normal that the seat does not move backward?
Old 03-04-2015, 06:35 PM
jkyriakou's Avatar
I've had a c204 and now a W205. The seat has never moved backwards. They both have easy entry. On the coupe it moves forward when you tilt the seat to get in the back. I think the manual is wrong.
Old 03-04-2015, 09:24 PM
miketc's Avatar
W205
You may be right but like to see if others have the same experience.
Old 03-04-2015, 09:34 PM
StanNH's Avatar
2015 C300 Sport: Palladium, Premium, Multimedia, Leather, BLIS
The manual says both the seat and steering wheel positions can be set in the vehicle menu under the easy exit selection. There's supposed to be an option there for the settings.
Old 03-04-2015, 09:51 PM
BenzC400's Avatar
2019 E53 Coupe
The display graphic in vehicle settings only highlights the steering wheel in yellow, not the seats. The manual clearly says both should move, but the seat doesn't. I asked the dealer about this and was told it's the way it's designed. My guess is because the back seat passenger would be crushed if the seat moved back in the W205.
Old 03-04-2015, 10:59 PM
seanvree's Avatar
2015 C300
My steering wheel moves down, but I've never had the seats move.
Old 03-05-2015, 04:37 AM
ManiacGT's Avatar
BMW e89 Z4 sDrive 35i & MB S205 C200 AMG Premium Plus
Having the seats move on their own could be very bad, lord knows why thats mentioned in the manual. Just imagine a back seat passenger or a child paying behind the seat when you get out or in and it starts moving on its own. Its for this reason MB don't have auto movement on the memory buttons, to help prevent harm, like it or not.
Old 03-05-2015, 08:28 AM
miketc's Avatar
W205
Yes, you could set it 'on' or 'off'; nothing else. The way I look at this is that if it's not available for whatever reason, don't put it in the manual. I like to see if it's available in other country or non-US builds.
BTW, I think some MB model stopped and move forward an inch or two when experiencing resistance from the rear.
Old 03-08-2015, 12:32 AM
NYC-Style's Avatar
Corvette/2017 E-300
My steering wheel moves up and back...the seat doesn't move at all.
Old 03-08-2015, 04:19 AM
DrEarl's Avatar
2007 E350 4matic
I also had 2011 C300 and now have a 2015 C300 W205, the 2011 could be set up so the seat would move back as the steering wheel moved out of the way. The 2015 only has the steering wheel move.
Old 03-08-2015, 04:33 PM
hugh1's Avatar
2014 BMW328i
Both 2008 and 2010 Lexus we used to drive had this useful function. In conjunction with the steering wheel, it makes it easier to mount and dismount. Present BMW 328i lacks this function and we miss it.
Old 03-08-2015, 09:50 PM
miketc's Avatar
W205
Called MBUSA, the seat does not move; manual is wrong to states that it does.
Old 04-29-2017, 08:23 AM
Drazil's Avatar
In my old w203 e class the seat also moved back. It was very helpful. I'm guessing BenzC400 is right on with the c class being so relatively small.
Old 04-29-2017, 10:10 AM
Former Member
removedCFGaccount's Avatar
CLS
Dude, that last sentence....
Old 04-29-2017, 04:57 PM
Thlian's Avatar
2018 C350Te Wagon
Buy a bigger car! You need to be pretty long legged to get crushed (we are taking about a car Seat right?) Though it could be a bit painful if the seat are hoisted and your setting lower it. There ain't room for any toes in a 205.
But seriously! Is this even a problem? Nice feature, but by far necessary.
Old 04-30-2017, 09:55 AM
mo11's Avatar
2017 C43
I've always wondered about some of the decisions that MB does when it comes to features for the different models. My old w211 e class did move the seat backward aside from the steering wheel moving upwards. My 2008 c class folded the mirrors and after the w204 facelift they took it away...
Old 05-01-2017, 08:52 AM
NYbenzzz's Avatar
2016 C300
nothing moves in my car when i enable easy entry/exit.
not even the steering wheel, wtf?
Old 05-01-2017, 09:30 AM
ManiacGT's Avatar
wtf? Wtf? Well a) do you have electric steering adjustment and b) is the wheel already adjusted fully upwards?
Old 05-01-2017, 10:30 AM
NYbenzzz's Avatar
2016 C300
my steering wheel is telescopic, electronic adjustment.
the steering wheel always set a little up than center. never all the way top.
never really bothered to tell dealer, since i don't really need it. but it sucks it's not working in my car
Old 05-02-2017, 12:30 AM
gfmohn's Avatar
2021 E450, 2020 C43, 2015 C300, 2007 C280
Default is off
Check your vehicle settings. That would be in the instrument panel settings, not the COMAND panel. I know my 2007 W203 had that feature, and I didn't have COMAND on that car. I believe the default value of that feature is off, so you have to turn it on.
Quick Reply: Seat doesn't move back with Easy Entry/Exit Option
