C63 AMG (W204) 2008 - 2015
Intake manifold cleaning/catch can
Old 03-29-2016, 07:47 PM
deadlyvt's Avatar
2010 C63 AMG
Have some time off so thought I'd take my intake off and clean it out, was quite a lot of crude in it
[IMG]https://cimg2.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/80-image_7b8b6123618b451edeebafe9b663c5691142694f.jpe g[/
Intake ports/vavles
Intake manifold runners
Inner intake manifold
Old 03-29-2016, 07:51 PM
deadlyvt's Avatar
2010 C63 AMG
Everything cleaned up fairly easily
Was literally oil pooling in areas of the manifold, I noticed closer to the pcv valve had more noticeable amounts of oil/pooling as you got further from it, it was more of a dry caked on crud
Pics after the cleanup
Intake runner after
Head port after
jdbassman (02-08-2024)
Old 03-29-2016, 07:53 PM
BLKROKT's Avatar
Received 2,810 Likes on 1,664 Posts
Nice job. Did you remove the throttle bodies when you cleaned, or leave them in place? What was your method, did you just spray a crap ton of brake cleaner in there, or soak it, or what? I'm about to install phenolic spacers, so am going to do this over the weekend probably.
Old 03-29-2016, 07:54 PM
deadlyvt's Avatar
2010 C63 AMG
Took apart the pcv valve and fitting a catch can should be a lot easier then I figured.... Both the pcv valve and the connection to the crankcase have barbed and rubber o ringed ends that measure out to the same as -10 hose so you should be able to just fit some -10 hose onto each and a catch can in between and save a few $100 on the Weistec setup
Old 03-29-2016, 07:57 PM
deadlyvt's Avatar
2010 C63 AMG
I took the throttles out as well they weren't too bad, yea maf cleaner but only because I had some sitting here brake cleaner probably work better...
Sprayed a **** ton then used some long length of blue shop towels to pull from one end of the runners through to the other end
95gsrturbo (09-10-2023)
Old 02-22-2019, 06:16 PM
anomadtoo's Avatar
09 E63
For clarification please, where is the oil leaking from into the intake manifold? From a bad gasket? Or just a design flaw and the reason for a catch can?
thanks
Old 02-22-2019, 06:17 PM
anomadtoo's Avatar
09 E63
Also, where would I find these Renntech PDF instructions for removal of the manifold? Sorry I didn’t come across it googling.
Old 02-22-2019, 08:27 PM
chrisridebike8's Avatar
'10 C63
just use this
https://mbworld.org/forums/c63-amg-w...valve-diy.html
Cwagon (07-17-2019)
Old 02-22-2019, 09:00 PM
anomadtoo's Avatar
09 E63
Originally Posted by chrisridebike8
thank you, I greatly appreciate it! Did you remove and clean yours? If so how bad was it? And did you do a catch can?
Old 02-22-2019, 09:02 PM
anomadtoo's Avatar
09 E63
nevermind I see you did the write-up, haha sorry
Old 02-22-2019, 09:18 PM
'10 C63
no to both. But i wish I had.
Old 02-22-2019, 09:45 PM
deadlyvt's Avatar
2010 C63 AMG
The oil isn’t leaking from anywhere it’s sucked up as a mist/vapor from the pcv valve cia the vacuum from the intake manifold it then hits parts of the intake and gradually pools up or gets re burnt by the engine
The following 2 users liked this post by deadlyvt:
BLKROKT (02-22-2019), Cwagon (07-17-2019)
Old 02-22-2019, 09:54 PM
BLKROKT's Avatar
Not only does it make your intake dirty, but that oil introduced into the intake also slightly lowers the effective octane of the burn.
Funkwagen (02-23-2019)
Old 02-22-2019, 10:20 PM
anomadtoo's Avatar
09 E63
Ok thanks everyone. I also saw in the post where fcpeuro sells the kit with new PCV valve. Looks to be priced well.
Old 02-23-2019, 01:11 PM
Funkwagen's Avatar
2009 C63 AMG, 2010 C250 4Matic Sport
I'm in the process of cleaning mine out right now as well. I really would like to fit a catch can considering how absolutely disgusting the inside of my intake is at 140,000km. My intake ports have a lot of gunk buildup as well. Luckily the valves and their seats are clean as a whistle, as well as the injectors, but everywhere else is filthy.
Old 02-24-2019, 07:51 AM
Kriston's Avatar
C63 AMG
Did the same last year.
amazing how much smoother the car runs just by cleaning the intake manifold!
Old 07-17-2019, 04:55 PM
Catchyname's Avatar
2012 C63 w204 sedan
edit: got caught out by the scroll down and posted in wrong thread.
Old 07-29-2020, 08:10 PM
iBoost's Avatar
2011 C63
Hey guys I've put everything pretty much back together, but can't seem to figure out where this vacuum hose connects. Can anyone help me out here?
Old 07-29-2020, 08:21 PM
MeAn63's Avatar
2012 Mercedes C63 AMG
Doesn’t that go into the y pipe? The canister in the middle.
Old 07-29-2020, 08:46 PM
BLKROKT's Avatar
Yep, Y-pipe
Old 10-28-2020, 12:11 AM
farkis644's Avatar
00' W210 E55 (sold), 07' W211 E63
Hey guys. About to do this job. Do you all recommend unbolting the throttle bodies for this job as well? Is it necessary? If so, do we need to replace any other gasket besides the intakes? Looks like there is a rubber gasket behind the throttle bottle plate.
Lastly, has anyone replaced the rubber gasket at the end of the intake/air box y-pipe? Part number?
Old 10-28-2020, 02:42 AM
swedepat's Avatar
2011 C63 AMG, 589hp
In my other car with an M272 engine the bushings for the flaps inside the manifold got worn out, one thing to consider if mounting a catch can.
Old 12-07-2020, 04:31 PM
Former Vendor of MBWorld
VictoryRoadPerformance's Avatar
E55 C63
Use code MBWORLD2020 for an exclusive discount!
>>> shop here! <<<
Old 05-25-2021, 11:49 AM
SoCalCL's Avatar
CL 63 AMG
Did you ever get into this DIY, I am about to switch over my old throttle bodies into a used IM I'll be getting from ebay.. curious how this went and if ill be needing to replace those TB gaskets?
Old 02-07-2024, 12:04 PM
MTBSully's Avatar
2006 E55
Bumping an old thread. Going to be taking off my intake manifold for inspection/cleaning this weekend. I've ordered new gaskets for intake to heads, as well as new MB intake bolts. Questions are:
1. Can the gasket on the throttle plate be re-used if in good shape? If not, anyone have a part number?
2. Can the hardware be re-used that secures the throttle plate? Anyone have a torque spec?
Rate This Thread
Rate This Thread:
Quick Reply: Intake manifold cleaning/catch can
