Difficult start when warm M111
Old 03-31-2016, 06:58 AM
w124lk's Avatar
E220
Unhappy Difficult start when warm M111
Hi
Having a problem on the e220. After driving the car up to operating temp and turning the car off and leaving for 10-15 mins, the car must be cranked for about 5-6 secs before it fires up again?? Initial start in morning when cold is good no dramas starts within 1-2 secs of key turn. When warm, the car does start eventually (never fails to) but takes a longer period of time to fire up after a run. Starts great after cooled down again though??
any ideas to the cause of this problem?
cheers all
Old 03-31-2016, 08:29 AM
Plutoe's Avatar
1999 E300TD
Whats the VIN??
Old 03-31-2016, 08:55 AM
w124lk's Avatar
E220
Originally Posted by Plutoe
Whats the VIN??
hi plutoe. tnx for your concern. I Pm'd you the chassis no
Old 03-31-2016, 03:11 PM
Plutoe's Avatar
1999 E300TD
Wow this baby has seen alot-an SKD Vietnam vehicle----I looked at the ignition system for your 111.960(HFM-SFI) and my guess without putting any diagnostics on the car is that your crank position sensor needs to be changed---enjoy!!
Old 03-31-2016, 07:05 PM
w124lk's Avatar
E220
tnx plutoe. could u please explain the first part of this response a little? tnx
Old 03-31-2016, 07:21 PM
w124lk's Avatar
E220
just looking some service receipts here and its got here "good 2nd hand variable timing sensor" installed in 2012?? could this be the culprit?
whats the best way to replace the sensor? cheers
Old 03-31-2016, 10:03 PM
w124lk's Avatar
E220
ok so i got underneath to have a look at this CAS
i presume this is the little sucker?
i could reach it from underneath and took a pic with the iphone. just not sure whether id have enough room to take it out without removing the starter bolts??
i noticed also that the aftermarket sensors are a little different to this original sensor, in that the connector sits vertically as opposed to my sensor's horizontal connector position?
tnx
Old 03-31-2016, 10:10 PM
w124lk's Avatar
E220
sry for being blunt! mine appears to be the older type of sensor with leads by the looks of it?
Old 03-31-2016, 10:43 PM
w124lk's Avatar
E220
does this look out of the regular guys?
loose connection?
ps: i had a fiddle around and this is a worn round piece of rubber which spins freely. presumably has peeled off the wiring due to old age and heat ^^
Old 04-01-2016, 06:10 AM
Plutoe's Avatar
1999 E300TD
When it comes to engine sensors try not to use any repeat any "used" sensors---they create more problems!!
In any event the correct sensor part number for your engine is 002 153 43 28---make sure that your Austrailian supplier confirms that the part is equal to that sensor--
Old 04-01-2016, 06:32 AM
w124lk's Avatar
E220
was waiting till you orbited around ... haha . thank you for clarification on the part number Plutoe! i was tossing between 8 or 3 on the sensor housing. the 2nd hand one was installed when the vehicle was not in my possession. i presume because the garage couldnt source the equivalent of Bosch so they wanted to avoid unknown OEM perhaps...
Old 04-01-2016, 07:01 AM
w124lk's Avatar
E220
where abouts does the other end of the sensor lead go? trying to see if i can find where it goes to but hard to see. maybe the starter needs to be moved out of the way?
Old 04-05-2016, 06:10 AM
w124lk's Avatar
E220
tnx Plutoe
Old 04-08-2016, 06:39 PM
w124lk's Avatar
E220
replaced crank sensor but problem still exists it seems ? does the cam sensor have to be replaced also? Could it be my wiring harness causing the premature starting?
Old 04-10-2016, 01:29 PM
Russell Ormerod's Avatar
not a merc
Wiring harness do give issues. Crank sensors very seldom. For your issue. Check fuel pressure after you switch off. Make sure it has holding pressure and that it does not fall back to zero bar. Good luck
Old 04-10-2016, 06:20 PM
w124lk's Avatar
E220
thanks for your response Russell. i dont think i have the DIY tools to check the fuel pressure. how would u suggest i go about it? tnx
Old 04-10-2016, 08:18 PM
not a merc
Only way is to buy a gauge. Or find a indy that can check. Without holding pressure it will battle to start when hot.
Old 04-12-2016, 05:20 AM
w124lk's Avatar
E220
hi russell. would i have to test the pressure at various points to determine where exactly the loss could be? is it not the external fuel pump?
Old 04-12-2016, 07:17 AM
not a merc
You only need to test the pressure at the test point on the injector rail. Connect gauge. Run the car. Switch off car and check if a holding pressure is maintained.
Old 04-14-2016, 04:26 AM
w124lk's Avatar
E220
oh ok. just one thing russell. i spoke to a friend who works at MB and they said they have a feeling it might be throttle body related. he didnt diagnose the vehicle just when i mentioned chassis, year, and symptoms he said that. could it be the case?
Old 04-14-2016, 04:45 AM
not a merc
Throttle bodies and wiring looms do give trouble yes. Also airmass sensors. But according to your description I would check fuel holding pressure first simple easy test and costs u nothing. You also say it starts perfect when cold. Runs and idles fine? A throttle body would cause very low idling and would be especially problematic when with cold start. Fuel pressure is your first test. If that's OK. We will continue further.
Old 04-14-2016, 04:50 AM
w124lk's Avatar
E220
yes thats correct rus. starts in 1-2 turns when cold. love it. more turns needed when hot or after 15-20 mins of resting. if started within about 5-10 mins of vehicle resting it will start within 2-3 turns. strange really ?
Old 04-14-2016, 05:50 AM
optimusprime m1's Avatar
W124 260E
I am still waiting for this post to get going again .This is just like my 2.6 m103 .Easy to start ,but when hot , it will not start right away. Fuel pressure regulator has a smell of fuel in the pipe. Accumulator changer ,fuel filter changed ovp relay changed .As was the fuel injection relay.
Old 04-14-2016, 07:36 AM
w124lk's Avatar
E220
that is interesting optimusprime. i guess time will tell
optimusprime m1 (04-14-2016)
Old 04-14-2016, 09:59 AM
W124 260E
w124 The car runs great .Only jobs keep on popping up from time to time. And to be expected for the age of it. Even picked up an ezl , thinking it to might have been the culprit. And it was not. With the price of these ezls, it wont eat anything in my garage. Time to buy an EZL now if you dont have a spare .I bet ,you have seen the price of them .
Quick Reply: Difficult start when warm M111
