DIY Oil Change - Anyone done it yet
Old 06-06-2016, 10:47 AM
TJGLC300's Avatar
GLC300
Hi,
I am a new MB owner with the purchase of the GLC300. I am old school and cringe at leaving the original oil in for 10,000 miles. I have always done the first oil change at 1500-2000 miles. For the first oil change I prefer to drain rather than suck it out through the oil filler tube.
My question is how to access the oil drain plug. I just glanced under the car and it appears the entire bottom cover has to be removed and then hopefully I can see the drain plug. I am used to cars having an access panel to enable easy access to the drain plug.
I guess I will find out if I can replace the filter without removing any of the intercooler ducting etc.
I have the filter from the dealer and Mobil 1 0-40W that meets MB 229.5.
Thanks for your help.
TJ
Old 06-07-2016, 04:42 PM
rdrunner21's Avatar
GLC300 4matic
First, I don't think you need to change oil at 3000 miles unless you drive in a really dirty environment.. if you really want to change it earlier then 5k or 7.5k is reasonable. Mercs use synthetic high quality oil and I believe a larger amount is stored in the car so the oil gets dirtier slower.
I think you can refer to the w205 forum for knowledge on the oil change. The engine is the same.
The oil filter is easily accessed since it is on the top of the engine(I believe just under the engine decorative cover in the front somewhere). If I were to do this I would probably buy one of those oil suction pumps off Amazon/car part store etc.. and go through the dipstick hole rather than mess with lifting the car and dealing with the oil plug.
Lots of videos on youtube as well. Search on amazon: oil vacuum pump
is it something like this Mityvac 7201 Fluid Evacuator Plus. many different manufactuers.
Not sure which pump is the better one since I haven't done this yet!
Old 06-07-2016, 06:52 PM
mikbar2's Avatar
2015 C300, 2015 F-350 Platinum, 1969 Mach 1 428cj, 2007 Roadking
I haven't done our GLC yet, but I did our old 2015 C300 and it is basically the same platform. I removed the cover on the bottom to drain the oil. Piece of cake. I do however have a two post lift in my garage. That makes a lot of things easier.
Old 06-14-2016, 05:06 PM
CA_GLC's Avatar
GLC300
Wow, you have a lift in your garage and live in SoCal? Nice! That would be my dream to have a garage like that. Off the top of your head about how many pop-it clips have to be removed to take off the cover? As soon as my maintenance plan expires I plan on doing my own oil changes.
Old 06-14-2016, 06:53 PM
mikbar2's Avatar
Honestly I don't remember now but it's no biggy. Don't be afraid to do it. Just keep receipts and your good.
Old 05-22-2019, 08:58 AM
progonat's Avatar
2003 E320
You have the M274 engine.
Here is a DIY to get you started. https://www.youcanic.com/wiki/merced...ine-oil-change
Old 05-23-2019, 11:26 PM
shutterfly's Avatar
volkswagen Jetta TDI
I have been doing oil change for my 2016 GLC for a few times, and have been doing it on my previous VW TDI 7+ years. Instead of trying to access the drain plug, I use an oil pump instead. Link here:
https://www.amazon.com/America-2005LV-LiquiVac-Changing-System/dp/B0002AJR8E/ref=sr_1_13?crid=1DPUAS0QDQM5Y&keywords=oil%2Bpump%2Bextractor&qid=1558668290&s=gateway&sprefix=oil%2Bpump%2Caps%2C192&sr=8-13&th=1 https://www.amazon.com/America-2005LV-LiquiVac-Changing-System/dp/B0002AJR8E/ref=sr_1_13?crid=1DPUAS0QDQM5Y&keywords=oil%2Bpump%2Bextractor&qid=1558668290&s=gateway&sprefix=oil%2Bpump%2Caps%2C192&sr=8-13&th=1
Super convenient, and from my experience it can suck more oil out than letting the gravity doing the work.
Audi Junkie (07-16-2020)
Old 05-24-2019, 07:35 PM
Flubadub's Avatar
2017 GLC300, 13 PorscheC4S, 12 Porsche Cayman S
https://www.amazon.com/America-2005L...2&sr=8-13&th=1
I have used this approach for at least 20 years on several MB models. The engines are designed to have the oil pumped thru the dipstick and this same method is used by the dealers. It gets out all you can hope to get.
Old 05-24-2019, 07:38 PM
mikbar2's Avatar
I still like pulling the bottom cover to inspect other components during maintenance. Everyone to their own preferences.
Old 05-24-2019, 09:16 PM
fred9x's Avatar
2019 GLC300 4matic
I have been changing my own oil for over 25 years and last week used the Topsider for the first oil change in my 2019 GLC. Worked very well (and clean).
https://www.ebay.com/itm/Topsider-Oi...6d53%7Ciid%3A1
Old 05-25-2019, 11:57 PM
Mr. J's Avatar
C450, GLC43
I vac out the oil too. I use a little electric transfer pump I bought for $20 on Amazon. Total time for oil change including cleaning up and putting everything away is about 15 minutes and everything is accessible from the top of the motor. I will never go back to using a drain plug again.
Old 05-26-2019, 02:15 AM
maxoujm's Avatar
GLC 220 D
I regularly do the engine drain of my 2017 GLC 220D
I perform a traditional drain because with the suction, you do not remove everything and the "dirt" that normally does not flow.
Old 05-26-2019, 04:04 AM
Gazwould's Avatar
S204 C250 CDI Sport
I use a 6.5L Sealey vacume pump , very comvienient given thats the capacity , if it broke I'd get a 9L .
This has a hard plastic pipe with a wire through it .
Some of the hand or motorised have softer flexible pipes that can collapse with prolonged oil temps .
First drain is a sump job with the addition of a magnetic Gold plug .
Is 229.5 a LongLife oil ?
Old 05-26-2019, 06:07 AM
maxoujm's Avatar
GLC 220 D
for my GLC engine OM 651 I used the oil Mercedes 229.52 with the filter it is 6litres 5W30
new oil specification
MB 229.52 is for high performance oil for engines with diesel particulate filters and extended oil change intervals.
Specifically designed for the latest generation of lBlueTEC diesel engines to
catalytic catalyst reduction (SCR) of Groupe DAIMLER (Mercedes)
Old 10-31-2019, 08:17 AM
Maui5150's Avatar
GLC300
I tended to do this on my motorcycles as well, but at 400. Never purchased a car new, so never have had the need, but if I did, I would do this as well.
The reason? Engine break in. You would be surprised how much tiny pieces and slivers of metal you find in the first change even at 400 miles. Maybe the bikes have less tolerances, so their break-in produces more crap, but then again, I also have a separate rinse bucket when I wash my car as well. These are small slivers of metal and rubber, so I am assuming piston, rings and other excesses. Probably more paranoia than a big difference overall, but I have been more happy knowing that crap is not floating around.
Also note bene - for the 2nd change, those things were not seen.
Old 10-31-2019, 10:39 AM
linus69's Avatar
2019 GLC 300 4Matic SUV
Personally I prefer to remove the drain plug on a warm engine and let it go till it stops dripping but that`s what I have always done with my vehicles. I usually use the time this requires to do other tasks on the vehicle like rotating the tires. I restored a 1970 Benwil 2 Post Lift that was laying in a field rusting about five years ago and that has made oil changes and vehicle maintenance a pleasure relatively speaking.
maxoujm (11-19-2019)
Old 11-01-2019, 07:58 AM
Rmlasalle's Avatar
2009 ML350 and 2018 GLC
I have completed oil changes on my 2018 GLC using a oil suction pump. The oil filter is easy to get to and the entire process takes no more than 20 minutes.
chassis (11-01-2019)
Old 11-19-2019, 02:18 PM
Camaroguy72's Avatar
2019 GLC300, 2017 E300
yes, you need to remove the lower cover to access the drain plug. There's no access door.
Old 11-19-2019, 02:36 PM
maxoujm's Avatar
GLC 220 D
[font][font][DEVIS = linus69; 7891199] Personnellement, je préfère retirer le bouchon de vidange sur un moteur chaud et le laisser aller jusqu’à ce qu’il cesse de couler, mais c’est ce que j’ai toujours fait avec mes véhicules. [/font][font]J'utilise habituellement le temps que cela nécessite pour effectuer d'autres tâches sur le véhicule, telles que la rotation des pneus. [/font][font]J'ai restauré un ascenseur Benwil 2 Post 1970 installé dans un champ en train de rouiller il y a environ cinq ans et qui a permis de faire des changements d'huile et de faire l'entretien du véhicule. [/font][/font]
[font][font][/CITATION][/font][/font]
same for me
Old 11-19-2019, 06:20 PM
spielnicht's Avatar
2015 BMW 550i xDrive; 2017 GLC300; 2013 C300 (SOLD)
It is literally a 15 min job on my wife's GLC with my Mityvac. It's one of the best investments you can make. I've had mine for 9 years now.
Old 11-19-2019, 10:11 PM
DanD.'s Avatar
2018 GLC 4MATIC
+1.
Did the oil change on new to us GLC, easy but they could find a better place for oil filter.
Old 11-20-2019, 12:10 AM
maxoujm's Avatar
GLC 220 D
Keep MB Invoices
Old 12-06-2019, 10:09 AM
dsi1's Avatar
GLC300
I wonder how does changing oil yourself effects warranty ? If something happens with the engine, can the dealership say 'seems like you never changed oil so the issue is because of that'? and you wouldn't have any proof (no invoice/payment receipt)?
Old 12-06-2019, 10:16 AM
mikbar2's Avatar
Save your parts receipts and log when you changed it and at what mileage. I buy MB filters. They cannot refuse a warranty claim because you did it yourself. Just keep records of everything. Same goes for having a private shop do the work.
Old 12-06-2019, 10:23 AM
spielnicht's Avatar
I do all of the A & B services myself. Just buy approved parts, save your receipts, and they can't say a thing. You also don't need to buy "MB" parts as long as they're approved parts. E.g. I wouldn't trust anything but Liqui Moly in my engines. Just make sure whatever oil you use is 229.5 approved.
__PRESENT__PRESENT
