S-Class (W222) 2014-2020
2015 S Class Sedan: Looking for trunk umbrella holder
Old 06-27-2016, 05:05 PM
suburbcity's Avatar
2015 Mercedes-Benz S550 4Matic Sedan
My car is a 2015 Mercedes S550 4Matic Sedan. Past models had a trunk mounted clip/bracket to hold an umbrella. I can't seem to find one of those that will fit my model.
Does anyone have any idea if it exists for this model and year? How can I find one if it does exist?
Thanks in advance.
Don
Looks something like this.....
Jim Ma (05-27-2021)
Old 06-27-2016, 05:23 PM
konigstiger's Avatar
Received 4,411 Likes on 3,144 Posts
'71 Pinto
Same part # 2218101214 as previous w221 https://mbworld.org/forums/s-class-w...ml#post6728970
Attached Thumbnails 2015 S Class Sedan: Looking for trunk umbrella holder-capture.jpg
hstmercedes (06-28-2016)
Old 06-27-2016, 06:01 PM
suburbcity's Avatar
Thank you....,
Thank you, I didn't think they were offering it as an option any more.
I'll order one and try to install it myself. I appreciate your response.
Cordially,
Don
Old 06-28-2016, 12:07 AM
Streamliner's Avatar
Received 3,385 Likes on 1,931 Posts
2020 S560 Sedan, 2019 SL450, 2019 E450 Luxury Trim Wagon
I always wondered what that thing was for.
Old 09-13-2018, 06:43 PM
lika1's Avatar
S550 4MATIC
Confirmation
So I did it! I recently traded in my W221 and purchased a 2015 W222. With that, I removed my umbrella holder from the W221 and successfully installed it in my W222. I have a post on the W221 forum with the part numbers of everything I used, and everything transferred over with no issues to my W222. Below are the pictures:
SwineHund550 (10-13-2018)
Old 09-14-2018, 08:43 AM
BenzV12's Avatar
W212 FL
Thanks for putting your insights, I didn't know S Class had that option . However, that makes me ask a question : Where's that umbrella ?
Old 09-15-2018, 01:35 PM
jbarhorst's Avatar
2018 S450 4Matic, 2010 S550 4Matic(sold), 2012 ML350 4Matic
Were the holes already in the trunk lid inner steel panel on the W222 like they were on the W221, or did you have to create the holes? When I installed this on my W221, the holes were already stamped out of the sheet metal. It made installation very simple.
Old 09-15-2018, 02:21 PM
lika1's Avatar
S550 4MATIC
Installation was exactly as it was for the W221. The holes are already stamped out of the sheet metal just like it was with the W221; insert the treenails into the holes to catch the screws, make the holes through the liner and screw the holder into place.....done!
Old 09-15-2018, 02:22 PM
lika1's Avatar
S550 4MATIC
Old 09-15-2018, 02:44 PM
Utopia Texas's Avatar
2019 SL550/2023 EQS 580 SUV
For long trips it’s great For holding extra Summer Sausage in case you get a flat and don’t have a spare....
Old 09-16-2018, 11:13 AM
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
It’s rare that I ever saw any w221 with this. I think it’s a port installed thing. Like an accessory item. Also haven’t seen any w222 with it yet.
Whats cost???
Old 09-16-2018, 11:30 AM
'71 Pinto
$20 - $30
Old 09-16-2018, 12:26 PM
lika1's Avatar
S550 4MATIC
I paid $36 total shipped a couple years back when I put it in my W221, and as mentioned above, same part #s work for W222.
Old 09-19-2018, 08:23 AM
obwielnls's Avatar
2014 S550
I just bought one of these from ebay.. Did you have to pull the liner? Cut slots in the liner for the tabs? Were they marked on the back side of the liner?
Old 09-19-2018, 11:06 AM
'71 Pinto
Mounts on trunk lid panel using treenail part #6399980185 (210 in diagram), and screw 4.2x25 # 000000000525 (220). See attachment.
File Type: pdf
The following 2 users liked this post by konigstiger:
dlafever (02-29-2024), SwineHund550 (10-13-2018)
Old 09-19-2018, 01:17 PM
lika1's Avatar
S550 4MATIC
Yes, I pulled the liner back just a bit, from the bottom, where you will see two square holes centered. Those square holes are where you put the treenails to catch the two screws. I measured distance from square holes to the plastic rivet holes on both sides and poked through with a screwdriver. FYI, you will also have to remove the two plastic "arm covers" #130 in the diagram above to be able to peel liner back. Hope this helps....
Old 09-19-2018, 01:36 PM
Jason B's Avatar
My friend has one of these from his old w221 that he said he'd GIVE TO ME. He just has the holder piece and no screws. I have a lot of screws in my parts bin, etc. If I only have the back holder that he gives me, do I need anything special to attach it besides some basic screws??? Hope someone can answer this.
Old 09-19-2018, 01:51 PM
lika1's Avatar
S550 4MATIC
Just the treenails or part# 210 from the diagram above to catch the screws. The part# for the treenails that I used is A639 998 01 85.
Old 09-19-2018, 02:03 PM
Jason B's Avatar
google shows this...
I bet I have something else that will work laying around that's similar...... hmm
Old 09-19-2018, 09:08 PM
lika1's Avatar
S550 4MATIC
Yes, exactly that.....they snap into the square holes that you will find under the liner.
Old 09-20-2018, 08:18 AM
obwielnls's Avatar
2014 S550
I'm going to see if I can 3d print a couple of those.
[QU
OTE=Jason B;7557810] google shows this...
I bet I have something else that will work laying around that's similar...... hmm[/QUOTE]
Old 09-20-2018, 12:42 PM
Jason B's Avatar
That's cool! You think it will be as strong?
Not all of them have this for some reason, but this is cool graphic...
Maybe you could add "S class or no class" ha
Old 09-20-2018, 03:30 PM
obwielnls's Avatar
2014 S550
I meant print the treenail things. I might be able to print that but I'd have to work out springs and such.
Old 09-20-2018, 03:43 PM
Jason B's Avatar
Oh!! Cool. I'd be down for some treenails if you do them, Very cool!
Old 09-22-2018, 03:26 PM
obwielnls's Avatar
2014 S550
I did print something like the treenail to go in the square holes to run screws in. I'll post some pics this week.
Rate This Thread
Rate This Thread:
Quick Reply: 2015 S Class Sedan: Looking for trunk umbrella holder
