good lowring springs ( 2015 C300 / W205 ) AMG Sports Package
Hi Guy's,
any suggestion on lowering springs? I like the stiff ride as is but wanted to lower maybe 1.6 front and 1.5 rear.
do you guys suggest i should go with shocks and springs? or just springs will be fine. I'm bit afraid that it might mess up the ride but wanted to get forum opinion before i go with it.
It will be lowered on 19" AMG Multi Spoke Rims Front tires 225/40/R19 93y and rear 265/35/R19 94y
Thanks in advance
Thanks in advance
Are you in the AMG sport suspension currently?
Reason is most of the after market springs refer to their drop from standard.
The AMG springs are already 15mm or 1/2 inch lower than stock.
At 1 inch below standard the stock dampers won't be out of range...
Much more than that eg 2 inch and you'll get better performance from different shocks and modified bump stops... Or ideally coil overs.....
For springs only H&R sport (25-30mm drop) are are good road compromise on standard shocks... Depends what you are after....
jatt143 (08-14-2016)
yes I'm on AMG Sports suspension now.
I was thinking about getting the below H&R model springs they are 1.2in front and back drop. do you think with 1.2 inch drop I won't damage the dampers?
http://www.hrsprings.com/application...s/25/1753/2015
http://www.hrsprings.com/application...s/c28811-1.jpg
Pretty sure they are 1.2 off standard.. So 30 mm drop off standard....
As AMG is already 15mm lower these would add another 15 mm off from your current state....
If that's what you are after, they will be a similar match in spring rate as your current springs and therefore pretty well matched to the AMG shocks...
Summary they will work well BUT YOU ONL DROP 15mm from current state...
I ran these springs on my w204 c class and they were a great and cheap addition...
I won't bother in my S205 as it has the AMG pack and this is too similar to be worthwhile this time around...
All the best.
All the best.
All the best.
All the best.
just wanted to follow up on this post. I bought the H&R Sport Spings for W205 and got them installed yesterday. as H&R factory spec car was lowered to 1.2". here are few pics on factory 19" AMG wheels
GeminiDSM (02-15-2020)
2017 Mercedes-Benz C300
Lowering
Can you advise how or if possible I can lower my 205 amg. Currently sitting on 19” merc wheels. I want to change the wheels to a gun metal colour multi spoke wheel , 8.5 x 19” et 45
9.5 x 19 et 48. Tires 225/40 and 255/35
suspenion is 486 sports suspenion with sports direct steer system
Hi Guy's,
Thanks in advance
Thanks in advance
no need for shocks if you go only 1.2". I suggest cheaper route just get H&R Springs.
I'm selling my H&R springs for 2015-18 w205 models. I got a new ride so took off the springs.
pm me if you guys want it
Charla_flame (04-30-2020)
I have been running Eibach PRO-KIT for about a year on stock shocks, i'd be biased if I said they are better the H&R springs since I work at Eibach lol but both are great springs IMO
semperroy (02-24-2020)
Sorry forgot to mention I also have the AMG suspension you have and switched to non run flats.
Currently running 235/40/19 Michelin Pilot Spot 4S on Front and 265/40/19 Michelin Pilot Super Sport on rear.
Zero bounce after the tire switch at 36 PSI front 38 PSI rear
Eibach
i called eibach uk yesterday and they told me it isn’t possible to lower a amg on just springs , can anyone tell me why this isn’t possible or why eibach would say it can’t be done
I work at Eibach North America but that’s odd, what part number were they referring to and when you say AMG do you mean AMG package or an actual AMG mercedes ?
Hi no just the amg spec it a c220 I looking to lower I got a part number this morning off eibach haven’t the hole number to hand but it ends in 222, they say it will lower the car another 20mm to what it is atm
I've been more than satisfied with my H&R VTF adjustable lowering springs. Good quality ride and more lowering flexibility than either H&R or Eibach Springs offered (In addition, Eibach gave me a 2 month Leadtime when I ordered).
[QUOTE=Jesbran Silva;7403221]I have been running Eibach PRO-KIT for about a year on stock shocks, i'd be biased if I said they are better the H&R springs since I work at Eibach lol but both are great springs IMO
Couldnt find anything for the 4matic only rwd. Only spring no Coilovers
[QUOTE=Rogue-CLK;7403561]
It was a special order from Europe since they don't have it in stock in NA (they only had it for RWD)
I have Bilstein B12 on my C300 4MATIC. It's basically Bilstein B8 Shocks + Eibach Pro-Kit Springs combo.
[QUOTE=andylaidb9;7403887]Nice! How do you like the shocks? any difference in ride quality?
[QUOTE=Jesbran Silva;7405644]I've never tried short springs + stock shocks combo, so I don't know.
(I think short springs + stock shocks combo will make the shocks wearing out faster)
I really like my current setup tho. It's quite comfortable for this kinda drop.
