GL Class (X164) 2007-2012: GL320CDI, GL420CDI, GL450, GL550
2nd row middle seatbelt replacement
Old 09-13-2016, 02:19 PM
crasshh's Avatar
2008 GL 450
I would appreciate any good advice or direction on replacing the 2nd row middle seatbelt on my 2008 GL450. Someone pulled it so hard they stripped the gear. Does anyone have any idea how I can get into the seat to replace it? Or do I have to buy a new bench seat entirely?
Thanks for any help.
Old 09-13-2016, 06:25 PM
Plutoe's Avatar
1999 E300TD
Post your VIN and that will be determined!!
Old 09-13-2016, 08:41 PM
crasshh's Avatar
2008 GL 450
4JGBF71E38A324572
Old 09-14-2016, 07:15 AM
Plutoe's Avatar
1999 E300TD
Will the attached help
Old 09-14-2016, 10:11 AM
a2j
a2j's Avatar
2008 GL320CDI (265k) & 2017 GLS450 (120k)
I thought OP was referring to seat belt, not the buckle. Replacing seat belt buckle is easy.
Old 09-14-2016, 10:46 AM
crasshh's Avatar
2008 GL 450
Yes, I was referring to the seatbelt itself not the buckle.
However, your PDF file seems to be a large manual..
Can you provide how to fix the seatbelt or at least gain access to it.
Additionally, how can I obtain the large manual also. Thanks for any assitance.
Old 09-14-2016, 03:26 PM
crasshh's Avatar
2008 GL 450
Any instructions on how to remove the second row bench seat?
Is it pretty straight forward DIY?
Old 12-03-2018, 12:28 PM
Lee Reed's Avatar
2007 Mercedes-Benz GL450
Did we make progress son this? My middle seatbelt won't retract either, and I've no idea how to reach it to repair.
Old 03-26-2019, 04:43 PM
Lee Reed's Avatar
I disassembled the rear seat panel, and found some debris stuck in the seatbelt. I cleaned that out and the seatbelt retracted. NOW, the seatbelt is locked and I can't get it to pull out. I'm tempted to replace the whole portion of the seat.
Old 03-26-2019, 10:37 PM
lkchris's Avatar
'07 GL320CDI, '10 CL550
its pretty likely you’ll set an airbag light if you don’t disconnect battery first
Quick Reply: 2nd row middle seatbelt replacement
