Parking Pilot space detection
Hello,
I'm rather frustrated with the parking space detection of the Parking Pilot. I can slowly drive through a parking lot and pass open space after open space without the PP detecting them. At that point I just park the car by hand.
The few times I did get the PP to work, I had to make the effort to drive up and down the lot a few times. It might detect spaces you drove past before without them being detected. Once a space gets detected, it parks beautifully.
Does this match the experience of others? Is it just my car?
2024 GLE 53 AMG Coupe
On mine I've noticed I have to have the passenger side of the car facing the parking spots. I've noticed that it does not detect on the drivers side when going down a row. Also Parking Pilot finds spots based on cars parked, not lines or empty spaces. I tried to use it in a grass lot but it didn't work there the few times I used it.
Also I noticed with mine that when it does work, it pulls the car too far forward so the bottom of the front bumper scrapes the parking barrier so I usually stop it before it gets too far forward.
I have not tried it yet with parallel parking but I heard that it works a lot better with parallel parking over perpendicular parking.
The old system only looked for parking spaces on drivers side if you indicated that direction as it defaults to passenger side. New one looks both sides at once. Mine finds spaces aplenty but I'll admit, the only time I tried to actually use it I couldn't select a space to park in; rotating dial, pushing it, tried the touchpad, nothing selected a space. My COMAND has been updated since then but I've not got round to trying it, hope it works as I used it a fair bit on the old one.
It isn't just your car, I do have same problem with the parking pilot system.The answer I got from the dealer is Mercedes is aware of the problem and they are working to improve it in the next generation of E class.Looks like it is a beta version of the software and Mercedes is collecting data to find a way to make it more reliable. I don't using it anymore due to the system limitation, I park faster and better by myself.I will test drive the new E class coupe, maybe is coming with a better version of the Command system.
CarFan1 (03-21-2018)
The semi-autonomous mode (drive pilot, parking pilot, collision detection...) it is limited.It is a new born and it was released into the wild to learn.It will be a few years until will start "crawling" and do what it was design for.It will need "mother" (read AI/car to X) to overcome real life situation and human behavior challenges but it will grow up eventually, we need patience and money of course to buy the upcoming new generations of Mercedes "toys".
Shanks’s Pony
My wife had it (self parking) on her 2010 A class and it worked perfectly!!
So I tried it a few days ago (car is only a week old). There were two cars parked with three perpendicular spaces between them. It detected a perpendicular slot but then paralleled parked across the three spaces(!!). I was actually laughing and a colleague told me all Mercedes drivers park like that lol.
Think I’ll stick to doing it myself
Shanks’s Pony
Why would anyone actuate the parking assist when it is obvious that the car has chosen the wrong parking? It always is your decision to decide if the parking spot is appropriate! The owners manual is pretty clear on this!
Shanks’s Pony
There were / are 2 different systems -- one tells you how/when to turn your steering and the other actually parks the car.. I've owned one or the other on 4 cars. The proper self parking works really well.
The following 2 users liked this post by ua549:
rorywquin (03-21-2018),
SmedleyButler (04-05-2018)
Which part of the commonsense applies to it driving past bone fide spaces that it should be picking up on? It’s erratic in its detection. Tbh, I’m never likely to use the parking pilot anyway, but to consider it some wonder of technology is a bit of a leap of faith. There’s plenty about the car which really is outstanding, like the Drive Pilot, but Parking Pilot still has a way to go.
it detects wide open spaces as a parallel park. I wa# testing it in a parking like next to one single parked car and it attempted to parallel park so I hit the brake. When I used it in a true parallel parking situation, it worked perfectly. I used it once with the dealer in a parking lot with 2 cars on either side and it worked perfectly.
Shanks’s Pony
From the manual......
Parking Pilot does not assist you parking in spaces at a right angle to the direction of travel if:
Parking Pilot does not assist you parking in spaces parallel or at a right angle to the direction of travel if:
Parking Pilot is activated automatically when you drive forwards. The system is operational at speeds of up to approximately 35 km/h. While in operation, the system independently locates and measures parking spaces on both sides of the vehicle.
Parking Pilot will detect only parking spaces that are:
- two parking spaces are located directly next to one another
- the parking space is directly next to a low obstacle such as a low kerb
- you forward-park
- the parking space is on a kerb
- the system reads the parking space as being blocked, such as by foliage or grass paving blocks
- the area is too small for the vehicle to manoeuvre into
- the parking space is bordered by an obstacle, e.g. a tree, a post or a trailer
- parallel or at right angles to the direction of travel
- parallel to the direction of travel and at least 1.5 m wide
- parallel to the direction of travel and at least 1.0 m longer than your vehicle
- at right angles to the direction of travel and at least 1.0 m wider than your vehicle
Shanks’s Pony
Stop the vehicle when the parking symbol shows the desired parking space in the instrument cluster.
Shift the transmission to position .
- The Start Parking Pilot? Yes: OK No: message appears in the multifunction display.
To cancel the procedure: press the button on the multifunction steering wheel or pull away.
or
To park using Parking Pilot: press the button on the multifunction steering wheel.
- The Parking Pilot active Accelerate and brake Observe surroundings message appears in the multifunction display.
Release the multifunction steering wheel.
Reverse the vehicle, being ready to brake at all times. When reversing, drive at a speed below approximately 10 km/h. Otherwise, Parking Pilot is cancelled. Parking Pilot brakes the vehicle to a standstill when the vehicle approaches the rear border of the parking space.
Stop as soon as Parking Assist PARKTRONIC sounds the continuous warning tone, if not before.
- Manoeuvring may be required in tight parking spaces.
The Parking Pilot active Select D Observe surroundings message appears in the multifunction display.
Shift the transmission to position while the vehicle is stationary.
- Parking Pilot steers immediately in the other direction.
etc,,,,,,,
pcascio (03-22-2018)
- you forward-park
