C43 Black Window Trim Stained!!
2017 C43 AMG
Hi All,
I recently purchased a selenite C43. I took it to a touchless car wash for the first time and after I noticed that the black window trim on the driver side and passenger side has what looks like water stains or permanent water marks. I spoke to the dealership and they suggested using a magic eraser with soap and water to remove it, said they have experienced this and worked for them. This did not work! So I requested that the window trim be replaced. I am being told by the service dpt that this will not be covered under warranty!
I am furious. They did not tell me I could not take my vehicle thru a touch less car wash? Mercedes has a defect that is for sure. The car wash I used is the same car wash I have used for years. I wash both my vehicle and wife's there and never had any issues to any window trim.
Has anyone experienced this? The window trim in the rear does not have any issues. If it was the car wash wouldn't the rear window trims have the same? I am very disappointed and frustrated with my current situation. Any advice or feedback would be appreciated.
I think it might have been the soap/cleaning detergent used at the car wash that might have caused the damage. My shop uses PH neutral soap both for the body and wheels when washing just to be safe.
Sorry to hear, hope it's not an expensive fix.
Hi All,
Sorry to hear this. If it cant be fixed you could always do a vinyl black wrap on the trim to cover it. When I had my car ceramic coated, the paint protection coating turned the A pillars next to my mirrors white. I decided to laminate them in carbon fiber instead of painting them.
The following 2 users liked this post by BallzOne:
Big Goober (02-23-2017),
Gr8 (02-16-2017)
next time you do your scheduled maintenance.
try a different dealer !
i have the same issue on my 2016 c450 amg. i told them about it on 10,000 miles Service A. they replaced the windows trims.
on Service B 20,000 miles, i have the same issue again.
on order sheet.
CAUSE: Water staining on outer door moulding
19318 Water staining on outer door moulding 0.10 Cleaned off water stains okey at this time
i didnt even bought the car from them but i have the 4 years prepaid maintenance. so i guess that' all it matters.
on order sheet.
This happened to all my BMWs, left water stains with a rainbow effect on all the black window surrounds.
I used to to have to go around using polish on them to remove the stains.
I only hand hand wash the C63S now...
Yup. It's a problem that happens to all MB anodized trim. I had mine replaced by the dealer only to have it happen again.
Had this happen to my C450 before I demanded a replacement vehicle (had lots of other problems).
Long story short an automatic wash shouldn't do this, especially so quickly. Maybe after years of doing it, but this problem is a manufacturing defect.
It's not a manufacturing defect. Mercedes explicitly says in their manual that you shouldn't take it to a touch less car wash.
My grandma's SL550 has the same issue I had with the anodized black trim staining. Her car is Mars red and has even worse trouble from the car wash. She has small white spots in the clear coat along the top edge of the door, following back over the rear quarter. Our dealership replaced her black trim like they did with mine, as for the clear coat spots... yer beat!
Shopping for first MB
Try Mothers cleaner wax...worked on my 2018...which yes I did the touchless wash...yes I should of read the manual. I have the 100k mile warranty if I want it replaced the dealer will.
Received 2,178 Likes
PFL205.064
