SL/R129: Blinking Fuel Gauge Lights '98 SL500
Has anyone experienced their fuel gauge lights blinking? They blink continuously, then stop without warning.
Thanks for any suggestions.
JazziM
1998 SL500 (Prissy Palomino)
2001 Jaguar XKR Silverstone
JazziM
Do you mean the instrument back light or the fuel gauge warning lights? If the first, there may be a loose connection in the instrument panel, or a loose bulb, easy to fix once you get the instrument panel out but that is difficult to do without the right tool to avoid damaging the surround.
If it's the low level light, check the fuel sender connections which are under the rear seat. It may be you would need a new fuel sender, not a job to do at home.
The regular flashing discounts a loose connection and I think it may be linked to the check engine light. I think it’s time to take the car to an MB specialist who can read out the diagnostics and has a manual explaining what the flashing means. It might, for example, mean the fuel pump pressure is low. These are old cars now and without modern displays, different light patterns could have been used to aid diagnosis.
The flashing indicates a leak in the EVAP system, though it's possible there is no leak at all, and a sensor is malfunctioning. Reading the OBD-II code associated with the Check Engine light may provide further detail.
R129 SL55 AMG & W208 CLK55 AMG
Plug in the Star diagnostics, and replace exactly what that stupid machine tells yo to, reset the codes, take it for a 3 min test drive and deliver to customer!
I'm going back and finding out what's going on cause yesterday he sent me a message saying they are looking for a "Fuel Pressure Sensor"
Here is the diagnostic manual for your engine: http://manual.startekinfo.com/manual/JSP/e4/9_4/m11.jsp. There are several codes associated with the EVAP system, and none of them encompass a diagnostic outcome where replacing the air mass sensor or an EGR component is indicated.
Ahmed (05-29-2019)
Thank you so much sir, much appreciated.
I'm gonna tackle this issue myself.
On a side note, I previously purchased an Actron CP9690 Elite AutoScanner Kit Enhanced OBD I and OBD II Scan Tool for all 1996 and newer and select 1984-95 vehicles.
I needed this for my 1993 Dodge viper RT/10.
Can I use this device on my 99 R129?
Hey guys, I am having the same problem, 98 as well, and I am thinking since I just had the roof cylinders redone and some work on the engine bay, I will check all the valves and hoses are properly connected .. in case something came loose
However I have a questions; if I can't resolve the issue, can I still drive the car ? my mechanic is going away and won't be back for 2 weeks ..
Drivable ?
Drivable ?
Indicative of an EVAP leak. Possible causes:
Gas cap.
Cracked/disconnected vapor line(s).
Bad (leaky) purge valve.
Bad canister vent valve.
Best way to diagnose after a visual inspection is with a smoke machine and a two way test scanner. Without this, evap leaks can be tough to find and may result in a lot of trial and error.
Gas cap.
The following 2 users liked this post by Floobydust:
Ahmed (08-11-2020),
FATHERTIME (08-11-2020)
Yes I understand
My questions is; can the car be driven ? and how safe is it to drive it ?
If it can wait until my mechanic comes back I will wait if not I will have it taken care of asap
Ahmed (08-12-2020)
Large vacuum leak. Large enough to trip the fuel trim function to try to compensate for the extra air.
Time to locate the vacuum line routing diagram under the hood and trace ALL the lines. Also check the vacuum fittings for the power brakes. Check each line and verify that they hold vacuum by blocking off one end and apply vacuum to the other. Inspect the throttle body bolts and gasket. The intake manifold hold down bolts, attempt to tighten each one.
When you get to rubber hose elbows and other connectors, flex them and look for cracks. I've now replaced all of my rubber flex ends. If all else fails, use the smoke test method.
A large leak should be easy to find. You should be able to hear it.
Ahmed (08-15-2020)
