1999 E430 Transmission Options
Old 02-26-2017, 12:29 AM
treymorriss's Avatar
C280
Transmission bit the dust - a lot of nasty noises and bearing remnants in the pan. I'm looking into a used one. I'm wondering if I can expand my search parameters in 1998-2003 models and look at S430 and CLK430? Are those other choices compatible?
Thanks!!
Old 02-27-2017, 07:59 AM
Plutoe's Avatar
1999 E300TD
post your VIN
Old 02-27-2017, 07:27 PM
C280
Plutoe,
VIN is WDBJF0H3XA851598
Symptoms: From stop car initially accelerated normal then began to hesitated, jerked, and audible clunk from location south of the engine compartment. As car heavily shifted from 1st to 2d symptoms continued. When car shifted to 3d and above shifting and performance was normal. As I had to slow the car shifted hard from 3d to 2d and 2d to 1st also hard. This all occurred while returning from lunch back to work. I had to stop twice on route back to work and same experience each time. On drive home same experience. Drained fluid and removed pan. Good amount of metal shavings and a couple bearing pins in pan. No CEL. Car is NOT in limp home. No ODBII codes.
Car has about 140K on it. Changed the fluid and filter at 110K. Only a slight trace of metal dust present at the 110K fluid change.
Thanks!
Old 02-28-2017, 08:53 AM
Plutoe's Avatar
1999 E300TD
Regrettably you are missing a digit in the VIN---repost the correct VIN!!
Old 02-28-2017, 11:20 AM
C280
Resending corrected VIN - WDBJF70H3XA851598
Old 02-28-2017, 03:29 PM
Plutoe's Avatar
1999 E300TD
Your VIN has a 722.623 serial number 01 335481 or part number 140 270 95 00-------and that is the only transmission that will work with your VIN without expensive modifications to the drive train---do not be fooled by the spammers trying to sell you a transmision
Old 02-28-2017, 09:22 PM
C280
Perfect. That's exactly what I needed to know. Much appreciated.
Rate This Thread
Rate This Thread:
