Remove door handle on W166
2015 ML350 BlueTEC 4Matic
Hi Folks,
I have a 2015 ML 350 BTec W166 chassis (Canada build, though not sure that matters here).
How does one go about removing the door handles on these vehicles?
I picked up some chrome door panel inserts for in the door handle "well" but need to remove each handle to install these.
Sure it's not difficult but would like some direction. Presume it's got something to do with those little round rubber "plugs" on the non-hinged, open side of each door?
Cheers,
TA Canada
Cheers,
TA Canada
2012 ML63, 2017 SLC300
I was told these are usually installed at port or dealer so I imagine they don't remove the door handles.
I removed a set from my car. You can thread them off with the handle pulled open so they probably go on the same way. It might be hard to avoid touching the adhesive strips to anything. Have you attempted a dry run with the backing still on?
