Solutions for some of these rattles and creaks?
Old 03-10-2017, 06:50 PM
Waylon Zeng's Avatar
2016 C450
Having driven the car for over a year, I gotta say I love the drama that comes with the sound and appearance. But the build quality really is lacking. My last car was a 2004 Lexus ES330 with over 130k miles, and it didn't come anywhere close to the amount of rattles and creaks this car has.
I have a few videos of where I've found annoying creaks and rattles. Any advice would be great!
With the door handle one, the service center says that because it's attached through rivets, there isn't any way to tighten it. Any suggestions?
With the dash rattle, the service center kept making excuses saying that because my exhaust was modified, they can't go looking for interior rattles. However, as you'll notice in the videos, the area literally rattles ALL the time. It's located slightly to the right of the center speaker. Nothing I press will make it stop, but it looks like when I turn on the wipers, it'll stop vibrating for the duration the wipers are moving. This rattle is temperature dependent. It doesn't occur when the weather gets hotter in the afternoon (I also live in Florida, so that means 80+ F). You may need to raise the volume to hear it, but it's super loud when the music isn't on.
With bumps:
There are annoying creaks that occur when the body is flexed (over bumps, turning, etc). They did address the door creaks, but they quickly came back in the rear doors.
I know this is a long post with quite a few vids, but these areas have been driving me nuts for the past year. Hopefully some of y'all have encountered some of these areas and have some solutions
The following 2 users liked this post by Waylon Zeng:
Jimmy_c63s (09-08-2021), xclream (08-24-2017)
Old 03-10-2017, 07:23 PM
Mike5215's Avatar
2016 C300
There's play between them parts. I got some 1/2 foam tape. Then with a butter knife I carefully crammed the foam tape into crevices that were doing the most talking.
On the dash speaker grille, just pry up an edge and lift up to unclip it and remove it. Then run little pieces of foam tape around the perimeter of the underside between the clips. Pop it back on.
Stuff foam into the following seams. Stop adding foam when you can grab the part, shake it and it doesn't budge or creak:
Over the tops of both outboard ac vents.
Between the gauge binnacle and dash top arch.
Between the COMAND screen and dash where the two meet.
On the door trim, along the thin upper seam between the trim panel and the top of the door panel.
On the underside of the door trim between the LED light strips and the main panel.
It took me about 30 minutes to do all of it. It won't be "pretty" from the standpoint that the foam tape, once the adhesive is exposed, is going to want to bunch up and roll in on itself as you work it into the seams. You won't see it as it'll disappear into the seams once you've forced it in deep enough with the knife, but if you're obsessive about that kind of thing the alternative would be to disassemble the dash and doors and lay the foam in nice and neat. Me, I just wanted the f'ing creaks to stop, because each time I hear one in my new $60,000 Benz a little piece of my soul dies.
Old 03-11-2017, 11:11 AM
OU8one2's Avatar
C Class W205
My first car I ever remember getting on every last nerve (rattles), is this one. I took it the dealer and told them to fix them all or it will be the last one I ever buy. Two days later I get a phone call saying since I have an aftermarket suspension they wouldn't fix them. As I was picking up my car there was a couple with a salesman looking at a c300, I made sure they knew what they were getting into. The couple stopped me and asked a bunch of questions and I was very happy to answer all of them right in front of the salesman.
Old 03-11-2017, 09:16 PM
Standingoten's Avatar
C450
My C450 had rattles from all four doors.
Took a few days for the dealer to find them all. They ended up replacing all of the window and door seals. The cabin is completely quiet now except for a new rattle from the glove box.
Combine that with my front driver and passenger door handle LED lights flickering and it's yet another visit to the dealer.
Lol I've gotten to drive the new E300, CLA250, C300 and GLA250 from all of my dealer visits.
Old 03-11-2017, 11:33 PM
likerage's Avatar
C450
Ive brought mine back twice now for rattles. They have nearly fixed them all. Only one left that bothers me is the speaker rattle on the front driver side.
All their repairs revolved around felt tape. They just keep taking stuff apart and placing felt tape between it and whatever its connected to. So far the center console, seatbelt adjustment cover, sun roof, and worst of all the glove compartment were fixed.
Old 03-11-2017, 11:48 PM
rustycruiser's Avatar
2015 W205
I have a really annoying one where the silver trim around the outer edge of the command screen is lose, and rattles against the glass of the screen.
Old 03-12-2017, 03:26 AM
Humeid Al-Habsi's Avatar
C450
same here,,, plus my screen rattles a lot,,, sound everywhere. my 2008 Lexus IS have a better quality materials and doesn't rattle as much !!!
am so disappointed.
Old 03-12-2017, 03:38 AM
Mike5215's Avatar
2016 C300
am so disappointed.
Mine two. It affects my perception of the car and of Mercedes. It's very unlike for them not to be able to button down a cabin like it's a vault. It's sort of what they're known for, or were. Now it's all about eye candy and seeing how many non AMG cars they can stick AMG badges on.
Old 03-12-2017, 06:31 PM
SteveE400's Avatar
2015 E400 and 2015 GLK350
If you have rattles from parts that are riveted together, the first thing to check is whether you can get at least one finger onto the joint. Next is the question of whether the rivet is visible once things are back together. If you can get to the rivet but it is not normally visible, put some RTV sealant (room temperature vulcanizing vinyl plastic sealer, like caulk) on your fingertip and smear it between the parts. This will "glue" the offending parts together, but if you ever need to remove them, a razor blade gets them apart. The RTV lasts a very long time, and even if it doesn't effectively glue parts together, it also acts like cushioning material and quiets the buzzing vibration.
Other than that, black felt and/or black sticky fuzz from vel-cro work wonders.
Old 03-12-2017, 06:54 PM
Mike5215's Avatar
2016 C300
Shouldn't be any rivets in the dash. Gluing parts together might present some warranty problems if there's ever a need to disassemble the dash.
Old 03-25-2017, 06:59 AM
Smoothie's Avatar
2015 c300
I've had a rattle that the dealer looked at.
They say its something internal in the comand unit. So it's getting replaced, would I then get the latest map update by default? No free map updates for Canadians.
Old 03-25-2017, 08:09 AM
StanNH's Avatar
2015 C300 Sport: Palladium, Premium, Multimedia, Leather, BLIS
My rattles were apparently not typical. They turned out to all be coming from the passenger's front seat. The dealer found a seat rack that was loose, as well as a fan unit for the seat ventilation that was rattling. They spent several days with the car until they were satisfied that all the rattles had been found and eliminated.
Our local roads have been battered by horrible winter weather, and there are "frost heaves" that can shake the fillings out of your teeth. Through all of this, I have not heard a single rattle or creak since getting the car back from my dealer.
Old 03-26-2017, 07:23 PM
2016 C450
Update: I figured out where the dash vibration was coming from. Turns out the right plastic cover in the hood was causing the vibration. When I removed it, the rattle was completely gone. Since it's temperature dependent though, I'll need another day to see if I can put some felt tape somewhere and will have the cover stay inside
Old 03-27-2017, 04:45 AM
ManiacGT's Avatar
BMW e89 Z4 sDrive 35i & MB S205 C200 AMG Premium Plus
agreed, I just put a little felt between any plastics that rub.
Old 03-27-2017, 02:18 PM
2016 C450
Update 2: I fixed maybe 80% of the creaking noise coming from the arm rests by spraying silicone in every nook and crevice around the arm rests. This also included the arm rest itself where the pleather meets plastic. I couldn't eliminate it completely since the arm rests themselves are bound to the door trim with rivets so they will be looser regardless of how much silicon lubricant I put on.
I went to another dealership and they sprayed a similar compound on all the door gaskets, which definitely helped with the door creaks.
I adjusted the plastic cover inside the hood, which seemed to have made it better, but if it keeps rattling, I'll need to put some felt tape on a few areas. Unfortunately, this one is purely temperature-dependent.
I don't think I mentioned it here, but I also solved a rear seat rattle yesterday which turned out to be a piece of plastic vibrating against the metal chassis right behind the seats. I had to toy around with that and apply felt tape.
At the end of the day, if the noise is obvious and you don't want to bother doing the work yourself or you don't have the right materials, go to the dealership. Otherwise, you're better off solving these rattles yourself. I've complained to different dealerships about these problems and they either couldn't replicate them or said they wouldn't cover it due to my exhaust modifications. But with a bit of handiwork, I covered it myself with no issues.
Old 03-28-2017, 11:32 PM
angeloxnet's Avatar
15 Mercedes C400, 12 Mercedes C250 coupe
this is an awesome thread, although i do not think i should be buying and installing felt on a luxury car, the creaks and rattles are certainly becoming a "thing" for me.
I thought it was just me!
Old 03-28-2017, 11:33 PM
angeloxnet's Avatar
no free maps? when i go to the navteq website, it says 3 years!
Old 03-31-2017, 06:19 PM
BMWMB71's Avatar
2016 C450 break AMG Sport
Those rattles and squeaks are driving me nuts!!!!
My car was allready 2 times/4 days in the dealership, and without solution.
Before this car i had a BMW F10 530d, and even after 150k miles, the interior was quiet.
Old 03-31-2017, 07:46 PM
achez's Avatar
2023 GLC300 4MATIC
My headliner is rattling and the sound is toward the front near the edge of the pano roof. Has anyone had this issue and/or fixed this themselves?
Old 03-31-2017, 10:00 PM
janusgrimnitz's Avatar
C200 4matic
following this tread !!
Old 04-01-2017, 02:46 AM
ManiacGT's Avatar
likely pano roof seals. Open roof, place Krytox along front edge of roof glass and front seal.
Old 04-01-2017, 08:49 AM
BF3PDZ's Avatar
E class, C class
Just noticed some rattling sound coming from the overhead compartment or somewhere near there. Also the creaking from the rear door is more audible, it sounds like it is coming from the door seal.
Old 04-02-2017, 01:14 AM
C200 4matic
I've had some very annoying rattle sounds from my footwell. Took it to my stereo installer today and they told me that some of the wires were lose and were causing the rattle
Attached Thumbnails Solutions for some of these rattles and creaks?-photo829.jpg   Solutions for some of these rattles and creaks?-photo276.jpg
Old 04-04-2017, 07:53 PM
Webmoto's Avatar
2020 GLE53 AMG
One of the issues (talking only about rattles and creaks) that started 3-4 months after I got the car was the instrument cluster rattling and squeaking.
Finally MB Canada was able to fix this issue. ( took only 4 months of complains )
Here is what they've found and how was fixed in case someone else is having the same issue.
Old 04-04-2017, 07:54 PM
C200 4matic
wondeful it's been fixed !!
Quick Reply: Solutions for some of these rattles and creaks?
