C63 AMG (W204) 2008 - 2015
Help me..2009 C63 AMG Engine check lamp
Old 03-24-2017, 10:50 PM
C63Mania's Avatar
2009 C63 AMG
Exclamation Help me..2009 C63 AMG Engine check lamp
Dear my friends.
My car is in the 2009 C63 AMG..
My car currently has one problem.
*Error code*
0810 Air flow in the secondary air system (serial cylinder 1) is too low.
&Repair details according to the above code.&
1.Secondary air pump replacement.
2.Replace surge tank gasket.
3.Surge tankCarbon cleaning.
4.Replace changeover valve.
5.Replace air flow sensor.(Right. Left)
6.Replace air pump relay.
★Changed Part photograph★
The next morning, if you replace the accessories, the engine check will be carried out.
Error code same.
How can I fix it? Someone who had the same symptoms?
Please help me.
@@Reference@@
Engine check lamp illuminated only at cold start.
Engine check not illuminated while running.
Best Regard.
Old 03-24-2017, 11:04 PM
BLKROKT's Avatar
Received 2,810 Likes on 1,664 Posts
Try this: https://mbworld.org/forums/c63-amg-w...recommend.html
C63Mania (03-24-2017)
Old 03-24-2017, 11:39 PM
C63Mania's Avatar
2009 C63 AMG
Thank's!
I'm a Korean.
I do not understand.
Do I have to replace the right catalyst?
Or, replace the ECU? update?
Old 03-25-2017, 12:09 AM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
OP are you in the US? If so what city?
Old 03-25-2017, 12:28 AM
C63Mania's Avatar
2009 C63 AMG
South Korea Seoul
South Korea Seoul
Old 03-25-2017, 12:53 AM
Did you take it to the dealership?
Old 03-25-2017, 01:04 AM
C63Mania's Avatar
2009 C63 AMG
Yes
Yes
The delegates have exchanged parts.
But the condition is the same.
Old 03-25-2017, 01:39 AM
I see. First, I hope they didn't charge you for the unnecessary repairs. Secondly, the link posted by Blkrkt basically said the problem was "Hose disconnected from air pump." You may want to look into that one.
Old 03-25-2017, 01:40 AM
I'm Korean also, btw, but I don't know of any good shops in Seoul, but I can ask some of friends if they know of a good shop.
Old 03-25-2017, 03:01 AM
C63Mania's Avatar
2009 C63 AMG
T.T
C63Mania
Old 06-09-2020, 03:30 AM
Roshan Perera's Avatar
C63
DI YOU FIX YOUR CAR ... I HAVE THE SAME ISSUE WHAT WAS THE PROBLEM ... REALLY APPRECIATE IF YOU CAN HELP ME
Quick Reply: Help me..2009 C63 AMG Engine check lamp
