E-Class (W213) 2016 - 2023
How To: Replace center console
Old 04-27-2017, 03:38 PM
vic viper's Avatar
S213
Sure the gloss black looks classy, but I was a bit shocked when I was told that gloss black is the only option for the sedan and estate 213.
Coming from a S205 with the open pore black ash center console I also wanted it in my E.
A few months ago the E-Coupé arrived and the problem was solved, I ordered a panel immidiately and it arrived today.
Here is how you do it
Tools needed, small flat head screwdriver and a Torx 20 screwdriver
Remove the rubber grommets hiding the two screws, remove them and pull the armrest locking mechanism backwards.
Remove the two exposed screws, then lift and fold the panel upwards
Unplug the black and the white connectors below
Now pull the panel slightly down and backwards from its top fitting, lift the entire panel and place it to the side on your lap.
Disconnect the connectors to the 12V socket, media panel, AC-panel, keyless antenna module, analog clock and the two LED-modules for the ambient lighting, they just snap right out.
Now remove all the stuff from the old panel, touch pad module, ashtray compartment, media panel and the AC-panel
The touch pad is fastened with four screws, the ashtray compartment with just two, they are easy to spot and remove.
The AC and media panels are just snapped into place, use the flat head screw driver to bend the tabs holding the units, then remove the units from the back.
The lid to the ashtray compartment is just slid onto place, pull it firmly backwards and it snaps off.
Assemble in reverse order and it should look something like this, note the Mercedes-Benz microfibre cloth
Part number for this specific panel is A238 680 15 03, that is open pore black ash with ambient illumination,
they should exist in all the other different finishes, however I am not sure of this, remember that panels without ambient illumination, analog clock and so on has different part numbers.
The following 29 users liked this post by vic viper:
2coolminator (02-13-2018), 6speeddave (09-11-2019), ADD0514 (04-29-2017), arnsbrae (04-28-2017), BeachBunny (05-24-2017), davekarn (04-28-2017), denjermen (11-11-2018), Endeeo (02-09-2021), flyinraven (08-04-2022), Forty9 (04-27-2017), grange3 (05-24-2017), Hixi (03-21-2021), HZ1YR (12-26-2019), johny555ive (02-25-2018), King•24 (02-16-2022), Mercedesfinance (06-01-2017), mickhoog (09-29-2017), mikevle (03-16-2018), nycebo (11-03-2018), nynd (11-13-2017), OLDs550 (11-09-2020), sagres1 (03-16-2019), salemraucher (04-27-2017), sFrancois1988 (07-12-2018), Streamliner (07-16-2017), thefisch (04-27-2017), tonecas (08-06-2018), vladarh (05-08-2017), Wassaby (08-10-2017) and 24 others liked this post. (Show less...)
Old 04-27-2017, 04:23 PM
Fastlife5096's Avatar
2017 E300 4Matic, 2004 E320 4Matic, 2007 Mustang GT, 2011 Kawaski Valcun Vaquero
Looks awesome!
Old 04-27-2017, 05:22 PM
c4004matic's Avatar
Received 1,067 Likes on 703 Posts
17 E43; 21 GLS580
Great how-to-do sequence thanks!!!!
Still, that medusa of connectors looks daunting to a once in a blue moon mechanic like me. I'm sure I'd be taking it apart again at least once because I missed one!!!
Now give us the same great by step on how to deactivate the speed governor on the E 43 and I'll call it all good.
Old 04-27-2017, 05:23 PM
Forty9's Avatar
2017 Mercedes E400 wagon (formerly 1995 Honda Accord EX sedan)
Does anyone know whether the corresponding console panel part is also available in the designo Magnolia flowing lines wood, and if so what the part number would be?
Old 04-27-2017, 06:04 PM
thefisch's Avatar
2011 E550 P2 4M Sedan
That is a nice touch. And a great write-up. How much was the part?
Old 04-28-2017, 12:45 AM
vic viper's Avatar
S213
Dont think that one is available, for what I can see I can find the panel in,
Elm Tree Open Pore
Elm Tree gloss
Black Ash Open Pore
Birds Eye Maple
And of course the AMG version in carbon finish.
Price of my panel was around USD 650, but that is here in Sweden and our part prices are usually higher.
Old 04-28-2017, 11:18 PM
terp97's Avatar
20 E350 & 17 GLS450
Made my night
I going to order this asap. Hate the gloss. I to have black open ash and couldn't understand why it was not carried through to the center like they do on the c class.
Old 04-29-2017, 03:29 AM
vic viper's Avatar
S213
The swap is very easy so dont let that hold you back.
Old 04-29-2017, 10:40 AM
evanblack00's Avatar
e220d
Anyone know if this will void warranty?
Old 04-29-2017, 12:30 PM
c4004matic's Avatar
17 E43; 21 GLS580
Absolutely not.
Old 04-29-2017, 01:03 PM
vic viper's Avatar
S213
Showed my car to our car dealers and they were all ecstatic to see that it was possible to swap the panel, they have had so many remarks on the glossy panel from customers.
Old 04-29-2017, 01:21 PM
thefisch's Avatar
Honestly, they should make that an option. Are you planning to sell the original part?
Old 04-29-2017, 01:24 PM
ua549's Avatar
In the 2018 E Class the console wood is coordinated with the other wood with a couple of exceptions.
Old 04-29-2017, 01:27 PM
terp97's Avatar
20 E350 & 17 GLS450
Not able to get in US
CHecked local dealer in VA. CAN NOT GET it
Old 04-29-2017, 01:45 PM
vic viper's Avatar
S213
There was low stock when I ordered the panel as well, but there is always express services available, do not know how overseas orders work though.
Old 04-30-2017, 09:41 PM
terp97's Avatar
20 E350 & 17 GLS450
Can't order in US
So basically the coupe is not in US dealers yet and until that time we won't be able to get that part at the dealer yet. The part number is good as you stated but just have to wait for the coupe to reach our shores which should be soon.
I can't wait to swap it out. Hopefully we are not looking at $600 usd.
Thanks for posting.
Danielsan (11-20-2022)
Old 05-17-2017, 10:07 AM
RAzZin's Avatar
W213 E200
Great how-to, replaced mine easily:
Car looks much more finished inside with the new console.
The following 5 users liked this post by RAzZin:
arnsbrae (05-17-2017), Danielsan (11-20-2022), Endeeo (02-09-2021), grange3 (05-24-2017), Wassaby (08-10-2017)
Old 05-19-2017, 05:07 PM
RickInHouston's Avatar
2017 E400 Coupe
Agreed. Looks much, much better!
Old 05-19-2017, 05:15 PM
ua549's Avatar
Is/will there be a burl walnut center console to match the steering wheel and dash trim?
Old 05-20-2017, 06:22 AM
e220d
What is the part number of that console? I will get my car end of this month and I want to replace it ASAP.
Thanks, looks nice though!
Old 05-24-2017, 04:27 AM
BeachBunny's Avatar
2018 E300 Luxury - P3 and more
Does anyone know if this is available in the Burl Walnut finish?
Old 05-24-2017, 04:41 AM
vic viper's Avatar
S213
Doesnt look that way, at least not yet.
Old 05-24-2017, 10:09 AM
grange3's Avatar
2017 W213
Hi all, if any one else is in a good mood and decides to replace the center console could to please video your work and put it on here and YouTube so we all can see how you did it for future reference I'm sure you will be very popular for a long time to come.cheers
Old 05-24-2017, 10:29 AM
BeachBunny's Avatar
That's a shame... The existing black *could* look good if they didn't make it out of cheap plastic. Something like porcelain would have been nice -- wouldn't scratch anywhere near as easily.
Old 05-24-2017, 10:32 AM
johnmc1's Avatar
2017 300E
I too hope it becomes available...do you think a MB dealer (service dept) would install or would this only be a 'do it yourself' project?
Quick Reply: How To: Replace center console
