Parts confirmation for overflow coolant tank
2005 CLK320
Hi,
I have a slight leak at the coolant overflow tank at the tubr area. Not sure what had happened to it... but there is a silicon patch repair there that's not exactly working ... so kinda thinking of just replacing it. The tank is pretty straight forward, but the hose... i am assuming its the overflow hose is number (14) in the picture attached? and not the upper hose (8)?
Just wanted to confirm this. thank you!!
Btw... does MB need some special coolant i'm reading there are some specifically made for them?
MBworld Guru
The coolant reservoir is very easy to replace. There are two hoses: a small overflow hose that attaches to the nipple on the side of the tank, and the return hose (#14) on the bottom. You do need to use coolant compatible with the system. One that is readily available is Zerex G-05.
2005 CLK320
Thanks Rodney! Strangely Autozone here doesn't carry zerex... I managed to get a pentefrost? I guess they should be able to be mixed?
There is one more thing.. there's a black metal looking thing in front of the overflow tank. It seems to be leaking too... Do you know what is that?
2005 CLK320
Attached a picture to be more specific.
Lifted a picture off the web. This isn't a photo of my clk (i wish thou... looks really clean and beautiful) but it's almost the same for the coolant tank area ... What is that in the red circle? anyone?<br/>
MBworld Guru
That's the overflow hose. It's a common source of leaks. You need to replace the overflow reservoir. It;s under $40:
http://www.genuinemercedesparts.com/...MtMmwtdjYtZ2Fz
2005 CLK320
MBworld Guru
Oh, that's the recirculation pump. It's used when you have either the REST option or the heated windshield washer fluid reservoir option. Or you sure it's leaking? The reason I ask is that I thought mine was on the C240 and it turned out to be the seal on the reservoir between the light and dark sections.
2005 CLK320
I don't see the option for heated windshield washer as part of the initial purchase by the first owner...
Actually i am not sure whether that is leaking or its just coming out of the hose area from the expansion tank. That's something i'm trying to figure out before getting the parts. I am seeing wetting around the lower ring, i'll try and take a picture of the thing.
Maybe after the expansion tank has been replaced i'll check again.
Thanks Rodney!
2005 CLK320
Found a better angle... Funny thing is the picture looks even similar with the wetting i see there. I think maybe i should replace the expansion tank first before looking at replacing this.
And i didn't even know i had heated wiper water lol.... MB thinks of everything don't they!...
