R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
Diesel Glow plugs
Old 06-18-2017, 03:41 AM
kevinchung's Avatar
A160(Sold) C180(Sold), ML320(Dead! Sold) CDi, R300 CDi
Diesel Glow plugs
saw in ebay, how often we need to change the glow plugs and how do I tell is time to change?
http://www.ebay.com.au/itm/6-x-Bosch...8AAOSwiOFZOSti
Regards
Kevin
Old 06-18-2017, 10:20 AM
efzauner's Avatar
2005 C240 2011 R350
when they fail. Very rare...
Old 06-18-2017, 02:41 PM
benzslo's Avatar
C43 5.4, ML320CDI, Fords
They are not a maintenance item. You replace them when they fail, a check engine light and glow plug light will illuminate when the system detects one is failed.
Old 06-19-2017, 08:46 AM
kevinchung's Avatar
thanks.
Only because the car is getting old now, and sound like a truck or a bus.(2010, 100,000km)
Just think it will help
Old 06-19-2017, 11:02 AM
efzauner's Avatar
2005 C240 2011 R350
Originally Posted by kevinchung
thanks.
Yep, but not because of the glow plugs. Glow plugs only prewarm the chamber on startup.
From various threads I believe the reason for the noise is wear of the injectors. The quality of the atomisation has a huge impact on combustion.
Not much to do apart from changing them and that is $500+ per injector.
That's why I wont buy another diesel. I grit my teeth everytime I accelerated from stop because of all the noise. Still quiet at highway speeds.
Old 06-19-2017, 05:15 PM
benzslo's Avatar
Glow plugs won't help with any noise. Lately I've seen some timing chains stretching out causing some noise, this on the v6 om642, usually higher miles.
Old 06-22-2017, 01:51 AM
kevinchung's Avatar
so I need to change timing chains? I thought timing chains can last for 200,000km or more
Old 06-22-2017, 08:08 AM
efzauner's Avatar
2005 C240 2011 R350
No no,.... dont change timing chains.... this is not the same noise.
Old 06-22-2017, 10:40 PM
benzslo's Avatar
I did not say that. I'd have to hear the noise and there is also a specific test for the chain to see if it's stretched beyond specification.
Quick Reply: Diesel Glow plugs
