XM weather app
XM weather app
Guys
Is XM weather not available for this vehicle? I see a weather section, but I liked and used the XM weather app available on my CLS.
Well that was uncalled for. Everyone is tuff behind a computer. Thank you for the dumb contribution to this post.
Anyone else can provide some feedback around the differences in the command interface from the 14' to 17'?
Sure... since if you have COMAND on your GLC then you will find the Weather app MUCH expanded from your 2014 cls - MUCH expanded..
Pull your COMAND manual or download pdf from MBUSA.com under Owner's Section... see pg 168/approx thru 175
You are correct. Found it buried in command. Makes no sense the way they did it. In a ny case I added some pics to help you guys find it. In essence use the controller to display the menu that shows the world icon. Then follow the same process all over again and you will notice that the world icon now has a drop down icon attached to it. If you select it it will bring you to a whole new sub menu were you will find the Sirius App
Edwin
Edwin
Are you saying for your car that the Owner's Manual pages were correct - or the manual was incorrect ?
Or are you saying you just didn't look ?
How about the "expanded features" - what's your opinion of new/new - since most don't even know about that - or are you stuck in a 2014 CLS TimeWarp ?
