GLC (non-AMG) Rear Spacers
Need some help here.
I have the 19" AMG Rims on RFT from factory. This is a non-staggered setup.
I am happy with the ride comfort vs handling compromise but looks too "tucked in" if you get what I mean.
Will like to get a spacer kit (2 spacers + set of lengthened bolts) for the rear.
I will like to know a couple of things:
1) how much can I push before I need to redo my wheel alignments? 15mm? 20mm?
2) Any thing to look out for when shopping for a set?
3) Any recommendations to who makes the best kits? Links will be appreciated!
Thanks in advance!
Thanks in advance!
GLC Wheel Spacers
From the research that I've done 10MM on the front and 15mm on the rear seem to be the best combo. In the past, I've had the best luck with the H&R spacers and longer lug bolts. Prices on the internet vary widely, best prices seem to be in the $85 - $90 range.
Read up about spacers a little more. Seem like alignment is not an issue but pushing the rotational centers outwards might put more force on the wheel bearings than factory specs.
Now I will like to know the specs (size and the offset) for 20" and 21" AMG rims from the factory. That will give me an idea on what is the range i can push the offset before severely shortening the wheelbearings lifespan.
I have attached a picture on how much gap I have from the surface of the rim to the fender trim.
What is the minimum size spacer I can get away with to achieve a reasonable look.
I do not need it to be totally flushed.
Thanks!
Thanks!
Wheel Spacers
Ran Spacers for 4 years on an X5 4.8 M Sport and have run them with the winter tires on my '13 E93 M3 for 3 years without any problems; am sure that Mercedes Bearings are equal to the quality of those used by BMW.
vratenza (07-02-2017)
Were your applications used for the rears or fronts?
Read about scrub radius (definitely will add to the scrub radius if spacers are added) and how messing with them can affect the handling of the ride. I guess it is more for the front but wondering how does it affect the handling if only applied to the rear wheels?
http://www.ebay.com/itm/H-amp-R-Spur.../391433080448?
Scheibendicke: 20mm
Lochkreis: 5x112
Mittenloch: 66,5mm
H&R Spurverbreiterung System DRA Silver Edition
System DRA
Die Spurverbreiterung wird mittels der mitgelieferten Befestigungsschrauben an der Achsanlagefläche befestigt.
Die Befestigung der Räder erfolgt mit den vorhandenen Radschrauben der Serien- oder Sonderräder. Die aus der Felge überstehende Länge der vorhandenenRadschrauben, muss hierbei unbedingt kleiner sein als die Dicke der Spurverbreiterung!
Alle zur Befestigung der Spurverbreiterung erforderlichen Teile werdenmitgeliefert!
Lieferumfang:
Zwei Spurverbreiterungen (=für eine Achse)
Spezial Fixierschrauben
H&R Artikelnummer: ME40556654
I don't read German but can this set fit out GLC?
Concerned that the stock wheel lugs might be longer than the spacer thickness?
Scheibendicke: 20mm
Lochkreis: 5x112
Mittenloch: 66,5mm
System DRA
Lieferumfang:
Sp[acers
Ran Spacers on all 4 corners of the X5, am only using them in the rear of the M3. Effect is no different then installing the same size wheels with less offset/backspace than the originals and is quite common in model specific aftermarket wheels designed to position wheels so that they aesthetically fill out the wheel wells.
Thus still searching for the factory bolt specs for the 19" AMG rims (non-staggered)
Spacers
GLC bolt Circle is 5 X 112mm
Wheel Center Bore is 66.6mm
Lug Bolt thread is 14mm X 1.5
Stock lag bolt length is 27mm
To determine the required lug bolt length add the thickness of the spacer that you have selected to the length of the OEM lag bolt, i.e., if you are installing a 10mm spacer, you should purchase 37mm lug bolts, for a 15mm spacer, you will need 42mm lug bolts...etc.
vratenza (07-04-2017)
Passenger Car lugs are 27mm, when I measured those on my '17 GLC W/19" Non Staggered Night Package Wheels, the OEM/Stock lug bolts measured out @ 45mm, if yours are the same, you would need 60mm lug bolts W/15mm Spacers.
Alright, I know what lug nuts I need now. If these are black spacers, I will take them and Paypal tonight. My rims are black and I believe silver will have to much contrast. Wanted to go 18mm in the back, do you feel that is to much?
Try this link...was just on there looking at specs tonight.
https://www.wheel-size.com/size/merc...lass-amg/2017/
