My GLK350 Mods
Old 08-16-2017, 09:56 PM
JohnnyC's Avatar
2013 GLK350
My GLK350 Mods
So I wanted to showcase some mods I have done (or will be doing). Figured my own thread will be appropriate as i have many mods.
Current build list is as of DEC 2019 on 2nd GLK:
EXTERIOR
+ Mercedes-Benz black bonnet badge (000-817-16-01)
+ Titanium license plate screws
+ Mercedes-Benz Distronic plus emblem (164-888-04-11)
Mercedes-Benz 20" GLK twin five spoke (204-401-66-02)
+ Mercedes-Benz 19" GLA five spoke (156-401-06-00-7X23)
INTERIOR
+ Unbranded aluminium door pins
+ Mercedes-Benz chrome memory seat buttons (212-905-02-51 & 212-905-03-51)
+ Mercedes-Benz cargo liner (204-814-05-41)
+ Mercedes-Benz right boot ledge (204-843-02-61-9G08)
+ Weathertech floor liner (445011 & 442102)
+ Mercedes-Benz black ash flat bottom steering wheel retrofit
+ Mercedes-Benz black passenger map lights (212-820-50-01-9051)
+ Mercedes-Benz black overhead console (212-906-46-01-9051)
+ Mercedes-Benz black rear view mirror with homelink, dimming, & compass
+ Mercedes-Benz parking pedal pad (203-430-00-84)
+ Mercedes-Benz brake pedal pad (170-290-01-82)
+ Unbranded accelerator pedal pad
+ Center console tray (204-680-90-50)
DRIVE LINE
+ Liqui-Moly Leichtlauf 5W-40
+ Titanium oil drain plug
+ AMG transmission mount (212-240-10-18)
LEMFÖRDER engine mount (3754301)
BRAKES
+ Mercedes-Benz C218 CLS63S rear caliper M12 x 1.5 - 35mm hex flange bolt (018-990-00-01)
+ Mercedes-Benz GLC300 front caliper M14 x 1.5 - 45mm hex flange bolt (019-990-79-01)
+ AMG W212 E63S rear caliper (212-423-59-98 & 212-423-58-98)
+ AMG C218 CLS63 Front Caliper (003-420-79-83 & 003-420-80-83)
+ Racebolt M10 x 1 titanium bleeder
+ Mercedes-Benz front dust seal kit (001-421-22-86) / Brembo (20.4872.45 & 20.4872.44 & 20.4872.43)
+ Mercedes-Benz rear dust seal kit (000-421-74-86) / Brembo (20.4872.42 & 20.4872.41)
+ Mercedes-Benz front pad (000-420-44-00)
+ Mercedes-Benz rear pad (005-420-25-20-41)
+ Mercedes-Benz front rotor (230-421-12-12) / Brembo (09.9313.33)
+ Zimmermann rear rotor (212-423-04-12)
+ Brembo B-quiet lubricant (G00075)
+ Brembo seal conditioning fluid (04.8164.90)
Bowa pad sensor (A098023)
+ Brembo DOT4 hydraulic fluid (L04010)
+ Goodridge W211 E500 front stainless braided brake line (SME0850-2FC-CL) [used for AMG rear caliper]
+ Goodridge X164 ML420 front stainless braided brake line (SME0811-2FC-CL) [used for AMG front Caliper]
LIGHTING
+ Mercedes-Benz black LED interior lights (000-906-31-05-9051)
+ Philips interior T10 LED 4000K colour (127994000KX2)
+ MAXGTRS T10 LED reverse light (3546-T10-T15)
+ Philips headlight D1S xenon white (85415WHV2S1)
WISHLIST
+ steering column (2129003507)
+ steering column (2129000116)
+ light switch (2049053003)
+ radar sensor (2129004603)
+ radar sensor bracket (2128850314)
+ radar sensor (0009055701)
+ left knuckle (2183320500)
+ right knuckle (2183320600)
The following 2 users liked this post by JohnnyC:
Clasik (03-29-2019), hoglaw (01-01-2019)
Old 08-17-2017, 10:14 PM
Amir_AMG's Avatar
2007 SL55
That emblem is beautiful
JohnnyC (08-18-2017)
Old 08-18-2017, 04:38 PM
JohnnyC's Avatar
2013 GLK350
So here are the door pins i did a few weeks ago. You need two different lengths. I went with aftermarket, but the factory part numbers with AMG are: 000-766-03-28 (REAR) and 000-766-02-28 (FRONT)
Aftermarket Chinese Sport pedal. Extremely great replicas; well worth the low cost. I did the proper installation by taking apart the accelerator. The aftermarket ones you can do either way. factory pedals need to take apart. Full set is: 000-290-01-00
hoglaw (01-01-2019)
Old 08-21-2017, 11:01 PM
JohnnyC's Avatar
2013 GLK350
More wheel caps, perfect fitment.
Old 09-01-2017, 04:28 PM
JohnnyC's Avatar
2013 GLK350
na
hoglaw (01-01-2019)
Old 09-01-2017, 09:14 PM
ble2716's Avatar
Very very slow
I like the steering wheel swap.
Looks really nice.
JohnnyC (09-13-2017)
Old 09-01-2017, 09:15 PM
LandSeaAir's Avatar
2008 W204
Very nice.
How do you plan to retrofit the memory seat control on the passenger side?
I am guessing you need either re-coding, or a front SAM module from a wreck car that had passenger memory. Also wiring harness? New door module?
I put leather door panels on my W204 C300 - I got them from a wrecked C which had memory seats - did not try to fit the memory option on my car because I know its more than just plug and play.
Old 09-01-2017, 09:24 PM
JohnnyC's Avatar
2013 GLK350
After i get my car repainted,wrapped, and add on Brembo brakes; the last thing is to trying to add in AMG recaro seats.
At that time I would have the opportunity to tear apart the interior and figure out all the wiring. I heard it is adding the control module and plug in play, but no clue as no1 has ever added it in a glk350.
SpeKtro (06-07-2019)
Old 09-02-2017, 10:49 AM
Flipbound18's Avatar
2015 Mercedes Glk350
Good morning, looks good, where you get your steering wheel from or part number?
Old 09-02-2017, 02:57 PM
JohnnyC's Avatar
2013 GLK350
na
Old 09-02-2017, 06:05 PM
Originally Posted by JohnnyC
Obtained from a salvaged CLS550 for super cheap, its near perfect with the only flaw from improper removal. Eventually i wanna source a different style with lane assist. ONLY 218-860-30-02-9116 (non-leather) air bag unit compatible (comes standard on all 2013+ GLKs)
218-460-14-18-9E38 Black Ash Wood / Black MB-TEX no lane assist
218-460-13-18-9E38 Burl Walnut / Black MB-TEX no lane assist
Flat bottom requires different air bag 172-860-28-02-9116(non-leather):
231-460-26-03-9E38 Burl Walnut sport flat bottom
So the black one , doesn't vibrate correct ? I need that black one mines is black wood , but these dummies put a brown wheel. , No glk options ?
Old 09-02-2017, 08:17 PM
JohnnyC's Avatar
2013 GLK350
So if i understand, you are looking for the flat bottom steering wheel (with lane assist vibration)with black ash wood to match your trim?
231-460-24-03-9E38 Black ash sport flat bottom, no lane assist.
You can also opt for the newer generation of steering wheels:
002-460-80-03-9E38
Old 09-02-2017, 08:43 PM
002-460-80-03-9E38
Thank you , not necessarily looking for the flat bottom one but I did like it on my 2015 turbo sonata . I just wanted to maintain the vibration feature. And BLK Ash wood to match my dash .
Old 09-02-2017, 08:54 PM
JohnnyC's Avatar
2013 GLK350
No problem! just make sure you verify again with your source that the steering wheel is correct. Its pretty common to get the wrong steering wheel sent because the part numbers are super long and parts are very similar. Don't forget you need the different air bag, the ones that comes with the GLK originally wont fit on the sport style.
Old 09-02-2017, 09:03 PM
So just buy the matching air bag with the wheel.
Old 09-02-2017, 10:06 PM
Highroller735's Avatar
2012 CLS550, 2015 GLK350, 2005 E320
The black hood emblem looks nice - how did you remove the stock emblem?
Old 09-03-2017, 03:10 AM
JohnnyC's Avatar
2013 GLK350
You simply lift it up with a plastic prybar or credit card. It is held down by something called grommets. They are constructed of plastic and it holds down the emblem with friction only. If they are loose you need to replace the grommets as well (201-997-22-81) to prevent the badge from falling off. Take a precautionary step to clean the area with a microfibre cloth to minimize scratches to paint work.
Highroller735 (09-03-2017)
Old 09-03-2017, 11:13 PM
Great - thank you!
Old 09-04-2017, 02:12 PM
JohnnyC's Avatar
2013 GLK350
So i just transfered the vibration motor to the new steering wheel and moved some electronics around. Now i have my lane assist working. Very time consuming but doable.
Old 09-04-2017, 05:59 PM
I see . did you need a steering wheel puller ?
Old 09-04-2017, 08:59 PM
JohnnyC's Avatar
2013 GLK350
Hmmm let me think. It was a headache to do the conversion. Here is the toollist I used:
Extended long Tire valve stem tool
10mm bit socket
Electrical insulator
10 hex socket 3/8"
XL 3/8" ratchet
3/8" torque wrench
Torx 20 long bit
Curved pick tool
Long needle nose pliers
Thats about it. You need the torx 20 and curved pick tool exclusively for the lane keep assist conversion. The 10mm and insulator for the battery disconnect. You gotta go slow to remove everything down to the bare frame basically.
Old 09-04-2017, 09:11 PM
hmmm let me think. It was a headache to do the conversion. Here is the toollist I used:
10mm bit socket
XL 3/8 ratchet
3/8 torque wrench
Torx 20 long bit
Curved pick tool
Thats about it. You need the torx 20 and curved pick tool exclusively for the lane keep assist conversion. You gotta go slow to remove everything done to the bare frame basically. its pretty straightforward.
Thank you , Johnny , now have to find a used one , I'm not going to pay over 2k at the stealership lol
Old 09-05-2017, 09:04 PM
Jed818's Avatar
2015 glk350
Can you please help me with a link to that black emblem I looked up the part number on mbparts the one you provided, the image isn't on it when you buy it so can you provide me with the straight link to buy this thank you!
Old 09-05-2017, 09:51 PM
JohnnyC's Avatar
2013 GLK350
Hi, received your private message.
https://www.mbpartsfactory.com/oem-p...ign-0008171601
This is Mercedes Benz of Long Beach, California. Jon@mbpartsfactory.com is the a member here who convinved me to order through them. The best price I've found; although if you only purchase the one item the shipping will be around $11USD. I combined several items like air filters, the passenger memory seat controller and misc stuff. You can order this part at your nearest dealer and only pay tax.
Old 09-06-2017, 03:26 AM
JohnnyC's Avatar
2013 GLK350
I made a part number mistake.
231-460-28-03-9E38 is the Black Ash, flat bottom, lane assist, with mercedes benz badge on spoke. This one will plug and play if you fancy a flat bottom.
Flipbound18 (09-06-2017), mbzusr (09-06-2017)
Quick Reply: My GLK350 Mods
