SL/R230: Help with fault codes
Old 09-18-2017, 05:40 PM
rtd
rtd's Avatar
2007 SL550 w/68000 miles. Can't get it inspected for fault codes. To start with, it threw fault for O2 sensor. Replaced with Bosch from Advance. After that it threw P0228,P0443,P0447, and P1337. Now it won't even communicate with the North Carolina computer system for inspection. It is hard for me to believe that all these things happened at once. Can anybody tell me what I should do?
Thanks.
Old 09-18-2017, 07:58 PM
REXY WAGON's Avatar
I've had similar issues on my 05 CDI but no check engine light. I tracked it back to the EGR valve. I would have no boost or kick down. I had no interest in replacing the EGR valve so I bought a Green diesel engineering tune that took the EGR out of the picture. Now I have more power and better fuel economy with no soot emitted after kick down.
Not sure if this is your issue but it would be worth looking at.
Old 09-18-2017, 10:59 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
The only one of those generic OBDII "P" codes that translates is P0447:
0957 Component Y58/4 (Activated charcoal canister shut-off valve) has a short circuit to positive.
Old 09-21-2017, 05:08 PM
rtd
rtd's Avatar
What the mechanic told me:
P0228-Throttle/Pedal position sensor/switch C circuit high input
P0443-Evaporative Emission Control System purge control valve circuit malfunction
P0447-Evaporative Emission control system vent control circuit open
P1337Faulty Engine control module,ECM harness open or shorted,ECM circuit poor electrical connection
Does any of this sound like it could be a problem? How would be the best way to straighten it out?
Any help would be greatly appreciated. Sorry I did not get back to you right away. I have been traveling.
Old 09-21-2017, 09:17 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
My advice is to get it scanned with SDS to read the native MBZ codes.
Quick Reply: SL/R230: Help with fault codes
