Lug Wrench Missing
Lug Wrench Missing
I am going to email my SA about this, but I assume I am missing the lug wrench and another item from my trunk on my wagon. Anyone else with a sedan or wagon can confirm a lug wrench comes with the car? Thanks
I assume it’s on purpose given now spare. Did they include a jack?
and it doesn’t look like there’s an empty spare wheel well. Is there any storage space under the rear hatch where the spare would be? I was hoping to do a subwoofer...
My SA checked another E AMG they had at dealer to be delivered & it had the wrench in trunk and said it was suppose to be included. We even went to parts and printed schematic and they said it was to be included too. The jack & tire stop aren't included per the parts dept., which is fine. You may want to check with the parts dept to confirm it's to be included. It's not like I can do much without a jack anyway.
Unique lug nuts or wheel locks?
We recently took delivery of an E63S wagon. As others have previously noted, there is no lug wrench in the back of our car either. The car has the 20" AMG Black Cross-Spoke wheels (package RTS). We did *not* order wheel locks and to my knowledge the dealer did not install wheel locks either. However, every lug nut on every wheel has a unique "torx-like" pattern. I've attached a picture. We've believe we've thoroughly looked all around the vehicle for a lug nut key and can not find one. Are these lug nuts just some standard part I need to order a new wrench for? I'm working with my SA to understand what is going on here, but my experience is folks on these forums know more than he will...
2018 S560 and 2019 E450 Wagon.
With these cars we would be so screwed if we got a flat tire. I guess just call the MB 800 number and have the car flat bedded to the dealer would be the best bet.
I agree, that would be my course of option should that ever happen.
That is the Mercedes lug nut design. It is commonly called the flower head design. As well, it normally has a chrome cap on the lug nut which can sometimes come off depending on which socket style you use to remove. They do sell a unique socket to avoid damage:
I'd keep the socket along with a tire repair kit (plug and some hand tools) to plug a tire if ever stranded after driving over a screw / nail.
https://www.amazon.com/ST-9160-6-POINT-CONVEX-FLOWER-MERCEDES/dp/B01BKQXUGS/ref=sr_1_1?ie=UTF8&qid=1512084294&sr=8-1&keywords=mercedes+flower+socket
WalterRoss (12-02-2017)
That is the Mercedes lug nut design. It is commonly called the flower head design. As well, it normally has a chrome cap on the lug nut which can sometimes come off depending on which socket style you use to remove. They do sell a unique socket to avoid damage: https://www.amazon.com/ST-9160-6-POINT-CONVEX-FLOWER-MERCEDES/dp/B01BKQXUGS/ref=sr_1_1?ie=UTF8&qid=1512084294&sr=8-1&keywords=mercedes+flower+socket
Multi-Point
5 or 6 Flat Sided
You can use ( I think it's a 17mm on it) regular socket. Sometimes the multipoint sockets end up popping the cap off so you can try using the normal 5 or 6 flat sided socket...(if that makes any sense). The flower one they recommend is to prevent any damage to the chrome cap on that lug.
