82mm throttle body install with no CEL
Old 10-17-2017, 02:23 PM
Das_it16's Avatar
2004 E55 AMG
For everyone that is planning to go to a 82mm throttle body for your M113k/55 AMG. You will need to replace all the old seals and gaskets from the supercharger with new ones. I didn't the first time and used the old seals and gaskets. I had CEL code p0505 the whole time. I finally got feed up and did it the right way. Remember our cars are over 11-14 years old. They total to just around $60-$100 depending where you get them. Also get a new map and IAT sensor. Silicon used Permatex Ultra Black on all the gaskets and under the adapter plate of the 82mm throttle body.
You'll need the following:
23- 112-142-00-56
29- 113-141-07-80
71-1131411080
74- 271-141-12-80
86- Avoid this part, this gasket comes with 2 metal o-rings that WILL cause a tiny leak. Use gasket maker to seal that area.
122 -(two of these seals)
Surge tank gaskets:
A113-098-01-80
A113-098-00-80
Also get a new wire(harness) for the throttle body as the one that is on the stock tb is super glued on. Here's the part number for that wire:
113-150-0028
Supercharger oil: 000-989-62-01-09-MBZ
Mercedes just Rebrands AcDelco supercharger oil: 000-989-62-01-09-M71
The following 2 users liked this post by Das_it16:
gjunon (02-12-2019), MSG 55G (11-14-2018)
Old 10-17-2017, 02:30 PM
Das_it16's Avatar
2004 E55 AMG
Silicon used
The parts diagram
Old 10-17-2017, 03:15 PM
E55amg0220's Avatar
2003 Mercedes E55 AMG
I disagree with using the that black sealant the better one to use is The Right Stuff it seals better and works faster but I would only use it on the supercharger to the intercooler connection that doesnt come from the factory with a gasket. You can buy the gasket for it but most recommend not using it and say it seals better with the sealant .... having tried both ways I say the sealant way is much better. Just make sure that you clean both surfaces very well use a blade to get off any excess sealant that is left over and then clean with a wire brush and lastly prep both surfaces with brake cleaner. The seal for the bypass to the supercharger is a MUST, this seal gets old, hard and brittle after all the heat. Take this time to also clean your intercooler of oil that has contaminated its vanes ... this lowers its efficiency spray some brake cleaner in there and then rinse with water til clear.
As for the other gaskets I dont think I would use the right stuff on those I prefer to use good old copper spray gasket on both sides this provides a very good seal and not as messy and less likely to smear off when mounting the parts together. I have done several of these and never had a leak, and when you need to disassemble there is almost no cleanup compared to sealant on everything
Just another guys differing opinion
Old 10-17-2017, 03:48 PM
MACEDON's Avatar
05 E55, 98 CLK320
Where do you get those parts diagrams????
I wanna do that throttle body mod someday soon....
Old 10-17-2017, 04:56 PM
C32owner's Avatar
2011 CL63 AMG (Current) 2005 CLS55 AMG (Current) 2004 C32 AMG (Sold)
It's from EPC the Mercedes electronic parts catalog.
Old 10-17-2017, 07:52 PM
sexyxe's Avatar
04 E55
And for a 3rd opinion.
I have re-used my bypass gasket multiple times and just applied a light oil smear to to let it slide into place and not grab the o-rings and move them out of position. I use silicon instead of the gaskets at the tb, adapter and intercooler. I also re-use my surge tank gaskets with no silicon. I have no leaks, idle problems, CEL, surges or hiccups.
Old 10-18-2017, 02:02 PM
Alex L's Avatar
CLK56TT (WIP), S65, RR 5.0 S/C
MB uses Loctite SI 5900. Just in case you were wondering.
Old 10-18-2017, 03:52 PM
GM_Lover's Avatar
NA
Are you guys using bolt-on adapter plates or did you weld? Wondering if that makes a difference in how likely you are to see problems.
Old 10-18-2017, 05:02 PM
E42AMG???'s Avatar
E420
If the bypass tb seal is flexible and not hard, reuse it.
Also instead of the good ole reliable permatex red, black, however you like your girls. I would recommend
petroleum resistant and 10-20 dollars can't recall
Old 10-18-2017, 08:49 PM
PutNavid's Avatar
06' E55 AMG, 03' E55 AMG
mines bolt on but it’s sealed with rtv. Can’t see how it’d be a problem if it’s sealed.
Old 10-19-2017, 06:36 PM
Simmelma's Avatar
2014 E63S AMG w/CCB's
Anyone know the part numbers for 24 and 74? Hoping to do this install next weekend
Old 10-20-2017, 02:30 PM
Ders's Avatar
2005 E55 AMG
I use GenuineMercedesParts website for this kind of stuff. Here is a link to our engine and you can pick which part of the engine from there. Lays out a diagram similar to above with part numbers:
https://www.genuinemercedesparts.com...-v8-gas-engine
Old 10-20-2017, 03:48 PM
mbmg's Avatar
2004 E55
#23 112-142-00-56
#29 113-141-07-80
#71 113-141-10-80
#74 271-141-12-80
#86 113-141-08-80
#122 (two of these seals) 113-141-09-80 same for Left and Right
Surge tank gaskets:
A113-098-01-80
A113-098-00-80
The following 2 users liked this post by mbmg:
Das_it16 (11-03-2018), Simmelma (10-21-2017)
Old 10-29-2017, 01:40 AM
Das_it16's Avatar
2004 E55 AMG
I’ve only used it with the bolt on adapter plate. I put the silicon gasket maker between the snout and the adapter plate. Let it dry and remove any excess carefully.
Old 10-29-2017, 02:11 AM
E55amg0220's Avatar
I welded mine on dont want the chance of a leak an i bought a spare snout so that i have a stocker in case i wanted to switch back
Old 02-27-2018, 05:44 AM
Woodpecker1's Avatar
2003 Mercedes SL55
Question
Did you use sealant on the intake manifolds and surge tank gaskets
Old 02-27-2018, 09:14 AM
E55amg0220's Avatar
no i used copper spray is all on those gaskets
Old 11-14-2018, 10:28 PM
MSG 55G's Avatar
2006 E55
This is an awesome post!! Just what I was looking for to DIY 82mm TB with some sense of confidence...thanks guys for all your insight!
Old 11-15-2018, 01:09 AM
newe55guy's Avatar
2006 BRABUS E55 K8 & SL500
23- 112-142-00-56
29- 113-141-07-80
71-1131411080
74- 271-141-12-80
Surge tank gaskets:
A113-098-01-80
A113-098-00-80
113-150-0028
thanks man I have the damn p505 and I hope this will fix it
Old 11-15-2018, 01:12 AM
newe55guy's Avatar
23- 112-142-00-56
29- 113-141-07-80
71-1131411080
74- 271-141-12-80
Surge tank gaskets:
A113-098-01-80
A113-098-00-80
113-150-0028
Old 02-12-2019, 01:09 PM
MSG 55G's Avatar
2006 E55
Bump for our fellow member doing TB
Old 02-12-2019, 01:12 PM
PutNavid's Avatar
Just tried the 80mm again this week since I got star and was able to raise the idle. Still got the cel and car went lean.
Old 02-12-2019, 05:38 PM
oneslow55's Avatar
E55 amg
You got a leak,,I know you hate to hear this but you do..You need a proper smoke tester with high psi and to be held for 5 min to fill the system wit smoke.
Old 02-12-2019, 05:41 PM
PutNavid's Avatar
I’ve had a feeling but here’s what I don’t understand, maybe you could help me understand. If I have a leak why doesn’t it do this on the stock throttle body? I’ve had the P0505 code come and go on the stock throttlebody probably once a month but it never goes lean and never throws the p0106 and never goes lean.
Old 10-28-2022, 05:52 PM
Ajai Thomas's Avatar
2006 SL55 AMG
what is this part?
#23 112-142-00-56
is this a bolt or some type of plug?
Rate This Thread
Rate This Thread:
