Car will not go into park HELP!!!
I have a 2010 e63 and in will not go into park.I can shift into neutral and drive fine but will not go into park with the shifter or the park button.
I shut the car off in neutral and open the door and it goes into park.Anybody else have this happen.
craig309 (10-19-2017)
Received 1,886 Likes
Well known issue ... you need a new shifter/plate button mechanism
The following 2 users liked this post by PeterUbers:
craig309 (10-19-2017),
TheMountain (08-11-2018)
On a side note, if you end up needing the shifter assembly, let me know. I have one that you can probably use some parts from
E63 shifter
hello sir, im new to forums for this exact issue so bare with me if I don't know how to use this. I'm having a similar issue, I have pictures of the exact part I need from the shifter, is there a way we can exchange pictures ?
Has anyone had this problem.What part did you replace the black box on the side of the shifter or the L shape circuit board under the button?
My park button works 7 at 10 time.
Sadinga (05-31-2023)
2014 Mercedes Benz E 63 S Model
I have the exact same problem on my 14 E63s, did you find a solution other than spending 900 on shifter?
craig309 (10-21-2017)
I bought the shifter assembly from a junkyard. I have my original "box" on the side of the assembly, it's fine if anyone wants it. The mechanism got broken on mine
