Warped brake rotors
Warped brake rotors
I've got the AMG line bigger brakes on my W213 and they've warped. Vibration started a couple weeks ago under light braking, really noticeable when drive pilot is slowing the car or maintaining distance to cars ahead. It's gotten worse now and needs to go back to dealer but I suspect with 26000 miles on the clock I'll be told to stump up for replacements (last check indicated something like only 10v percent pad use, I'm not hard on brakes!).
I've never braked hard in the car and don't cover the brakes. I've never warped discs in over half a million miles of driving and wouldn't expect discs that big to be overhelmed by the cars weight either. But I think drive pilot is the cause, constantly light braking, dragging the brakes all the time and putting a lot of heat in to them. I do a lot of miles with it active.
I've read others have had problems with standard brakes and drive pilot, anyone had issues with drive pilot? I'd like some at least anecdotal evidence to go to the dealer with before trying to avoid what's likely to be around £1000 bill.
W205 and W213 both use a new type of hybrid rotor, very sensitive and easily warped.
According to Daimler using aftermarket wheels and an impact wrench will void rotor warranty.
Wow! They look like they'd stop a truck. Why on earth make them so fragile? Have you seen any amg line rotors warped? I feel like I'm being very unlucky with this car.
Yh don't worry it's not just you I have had warped rotors on my w213. First time it happend car was around 6k miles and I was on a trip across europe from UK.
It started shaking the whole car when braking & happened on the drive from France to Italy and I managed called mercedes and they arranged for a dealership in italy to take my car in while i was there. (Which was incredibly done as they arranged for everything considering i was in milan for a day). The italian dealership replaced all my back rotors and brakes. No charge for me as car was under warranty. They didn't ask too much questions as there was a language barrier between us, they sent couple of engineers to drive around and test and just got to work.
However now its doing it again, but only noticeable on long trips 4hrs+ . Its been 6 months since the rotor change and i've done another 6-7k miles. It always seem to start when ever the autopilot has been driving for extended amounts of time. Im convinced the auto pilot brakes harder or something of that sort especially 90+mph . As I haven't really done any heavy braking but can't really be sure whats called heavy with this car.
My first service is coming up and i'm going make a point to bring this up and get it fixed. But im not so sure they will just replace them as its such a pain to get anything done by the dealer in UK , even just the map updates. Will update and see what happens.
Im pretty sure the italian dealership just put new everything as it was easier/language barrier.. Im sure my UK dealer will somehow turn it to be my fault.
ours are good for 100,000Km (I think, could be 80k) but only 2 years, UK is 3 years/100,000 miles (160k km) if I'm not mistaken. This is pretty terrible considering how tough EU is on consumer rights. We don't have an option to buy additional warranty here either (not sure about UK)
I've heard the standard brakes are prone to warping but not heard anyone with the bigger vented brakes suffer it; I've got the bigger brakes.
My car goes in to the UK dealer next week to have this looked at. I'm convinced drive pilot is the issue coupled with brake hold. Ever since I started getting the vibrations I've become very aware just how much drive pilot rides the brakes, it's not very good at naturally slowing down/matching speed with motorway traffic so I find it's braking way more than I would. So I imagine the pads are heating up badly on the motorway then, coming off on to busy/stationary slip road and putting brake hold on, it's just heat sinking the rotor in that little spot. I remember from track days you never put the handbrake on when back off track till the brakes cool but that's effectively what's happening on every commute for me.
Fingers crossed UK dealer is as accomodating as the Italians where maybe I need to do a road trip!
Warped rotors are not in fact warped they have deposits of brake caliper material, the deposits are very small but lead to an uneven surface. A quick turn on the disc lathe will cure it. The culprit is not the disks but rather the pads. Run of the mill street pads are quiet but have lower heat capacity and are thus more prone to heat degradation thus "warping". As far as I can tell the AMG brakes do not have the issue, I would have had it by now since I have tracked the car, thus operated the brakes at very high temps.
c4004matic is correct. There is an excellent technical discussion here by noted brake authority Carroll Smith, titled
The "Warped" Brake Disc and Other Myths of the Braking System
http://www.stoptech.com/technical-su...nd-other-myths
Indeed, the article describes exactly what I'm saying, high heat put into the pads by drive pilot use followed by sitting stationary with brake hold on is hot spotting the rotor and likely causing pad material to weld on the disc. Not a great design pairing!
Unfortunately, "warping" is not really a "defect" its a wear and tear issue. Honda cars have suffered from it for........ forever! Personally, I do consider it a design flaw AKA, cheap brakes. Wow european warranties suck royally, no pun intended In the states its 48 mths 50K miles which is considered an averagel offer, VW just introduced a six year warranty.
Yup, over here mercedes only sells on the back of brand loyalty/dedicated fan base. They don't have any dealerships here in Ireland, it's just one distributor who has a few dealerships + few independents who buy off that one distributor. I hope Mercedes will get tired of their BS fairly soon. BMW have the market cornered here with the 3 series, the new 5 series is flying out of the show rooms. E class W213 was selling well last year, but I think 5 series has sold a lot more this year. There are no GLC or GLEs to be seen anywhere, in this segment you only see the X3 and X5, maybe the odd audi Q3 and Q5. I'm sure I'm probably the youngest guy in the country who has ordered a new W213 this year at 27. The salesman was almost shocked to find out my age.
They got it on their notes to look at the brakes when its in.
I'm debating if I should say this is the first time its happened or mention about it happening 6 months ago in italy (brakes+rotors being replaced). I dont think they have their systems joined across Europe such as the UK dealer network. Italian dealership had a hard time finding any info and they just gave me paperwork and took photocopies of my V5 to claim for repiars.
As i don't think they might be so inclined to replace/fix my brakes for a second time. Even tho it's nothing to do with me.
And anyone have experience with first service? Am I better off by refilling my adblue prior to it?..
My adblue ran out after about 8k miles and dealer charged me like £40-£60 for refill (can't remember exact). Is there a specific kind thats used by Merc for there cars? Since adblue is every where for cheaper, so don't see why you have to pay such a premium.
I'd be inclined to mention the previous incident and replacement to show the brakes are even newer and so shouldn't be juddering at all. I'm doing a 53 mile each way trip up the motorway everyday and had been using drive pilot extensively so I'm with you on what the potential impact is. Something about dense traffic speeding up and down a lot (why can't people maintain speed on the motorway! Grrr) is maybe giving the brakes a serious workout with drive pilot dragging so much.
I'll let you know how I get on next week. Might sway how you approach the dealer.
Re adblue, I filled mine up at 10,000 miles or so in a truckers fuel lane at a notify motorway services (and had a lorry driver go off at me for the pleasure "f-ing car drivers using the lorry lane", he was red in the face ranting,I found it hysterical). Cost about 70 pence a litre. So by first service I had over half a tank left and without asking the dealer filled it up (standard to do so I was told) at about £1.30 a litre! It's just run out again and I've the warning come up at 27000 miles. Might just buy some online this time.
Car went in to dealers a few days ago and brake rotor was identifed as being at fault; minor runout issue. Dealer gave details to Mercedes and obtained a {lack of any} goodwill discount of 50 precent of the cost to replace front discs and pads. They are only worn 15 percent, dealer expected Merc to cough up 80 percent of cost and even that is rubbish considering it seems to be a common design issue. No way in hell I'm paying £280 for brakes/rotors and having a very high chance of it coming back again!
15 percent wear over 27000 miles surely shows I'm not harsh on the brakes.
Anyway, anyone have any luck getting Mercedes to increase "goodwill" amounts?
After numerous dealer visits for vibration, dealer accepted that the discs have a "run out" issue and is replacing them as goodwell. Very unacceptable for Mercedes. If you come across this is in the future, know its a design issue and not your problem.
http://www.stoptech.com/technical-su...nd-other-mythsVery good information above. There are some additional articles and suggestions in post #20 of this earlier conversation here: https://mbworld.org/forums/e-class-w...ke-judder.html
Having spent 30 plus years in West Texas heat, these tricks will stop the brake pad deposits from occurring. I never had an issue after learning what the cause was.
Hi has anyone here brought their car to the dealer for the brake vibration, when braking lightly? I think I am starting to feel it too. AMG line with the bbk, and still under 10k miles. So they should be like new, just curious if anyone had success with dealer replacement or resurface under warranty and actually resolved the ussue?
E 300 AMG-Line diesel-Hybrid - 2021
yes 3 times & every time replaced (over a period of a year) . for passed 6 months or so everything seems to be ok . (had car for 1.5y / 70.000km)
