Transmission not shifting into any gears except for reverse.
1995 Mercedes Benz C class c280 W202
Hi. My transmission on my 1995 Mercedes Benz C280 W202 is not catching any other gears except for reverse i did a transmission filter and fluid change but still will not catch in drive. Does anyone have any advice they can give me it is the 722.4 transmission.
Only data I can offer from a 1998 C280 is that the valve solenoids can test good, and yet fail to operate. You may need a replacement conductor plate, and they're not cheap but they are available. I used Valvoline fluid for refill and alles gut.
You have a classic symptom of b2 band failure. Google the term and you will find plenty of discussions. In short, you need a transmission rebuild - its worn out. I expect you know it's not the conductor plate as that's a 722.6 issue.
