has my car got servotronic steering?
Received 4,415 Likes
'71 Pinto
servotronic = parametric or speed-sensitive steering – pull data card, look for code 213. Or post VIN.
'71 Pinto
'71 Pinto
Mercedes e class w211 facelift
Servotronic in steering rack
Hi could You check is mine w211 steering rack with or without servotronic sensor? Its my vin number WDB2110082B258024
'71 Pinto
'71 Pinto
No.
Asgeir Johnsen (10-21-2019)
'71 Pinto
Code 213 is not listed on your data card and this is what I'm basing my decision on. See subject line on attached bulletin.
I think i will check if its some wires or sensors connected to the steering rack later.
here is a pic of the number on the steering rack
Anyone able to check whether mine has servotronic as I need to replace the steering rack on my C203 ?
WDB2037562A885324
I appreciate this is the E Class board where mine is a C Class but the I assume the VIN database will still return the info ?
WDB2037562A885324
Based on the provided VIN number you're vehicle shows the code 213 in the datacard so you should have Speed Sensitive Power Steering.
'71 Pinto
'71 Pinto
-213 = no speed sensitive power steering. If there had been + sign ahead of code it would indicate yes. So once again, no this VIN does not have it.
gogydm (10-23-2020)
