Üro parts or BEHR blower motor?
Old 11-20-2017, 11:51 PM
Mythic Man's Avatar
2010 c300 4matic sport
So my blower motor for my c300 went bad and needs to be replaced , everything is taken out and I'm ordering but I'm stuck between two brands. üro and Behr , üro is about $80 cheaper but the blower motor in my c300 was behr stamped. If anyone as experience with Üro or Behr please share.
Old 11-21-2017, 12:03 PM
c300white's Avatar
2008 C300
Uro generally does not get good quality ratings - I have used their hoses in some applications and they were fine - if the unit is easy to replace again - I would go for it ... if it is a lot of work - go with the behr ....
at at least this is not a critical part that will leave you stranded ...
Old 11-21-2017, 12:10 PM
mrbrannin1's Avatar
2007 civic Si 2004 Acura TL 2013 MB C350
agreed
Old 11-21-2017, 12:18 PM
Mythic Man's Avatar
working upside down under the footwell was a pain in the *** and removing allot of things to get to it was a struggle. I went with Behr
Old 11-21-2017, 03:52 PM
Adi-Benz's Avatar
I've never heard of Uro, so I would have gone with Behr as well.
Mythic Man (11-21-2017)
Old 11-21-2017, 03:54 PM
romeo291's Avatar
W204
I got the Behr one when I did my replacement. It's a pain getting into there, I would hate to cheap out and have to replace it a year later. Save yourself the hassle and get something that you know will last a few years.
Old 11-21-2017, 05:11 PM
W204Motorsports's Avatar
2008 C350 Sport 4Matic Swap
Mine just failed yesterday and it freezing cold here, I didn't want to wait 2 week shipping so I got a URO blower motor from my local part store, the brand has had quality issues in the passed but apparently got a lot better, online you can see cheaper ones and when I compare it with the OEM BEHR one, the quality is the same and built the same, the cheaper ones had slight differences like different bolts holding it and felt flimsier.
My URO one fit perfectly and it has 1 year warranty so if it shows any signs of wear il probably swap it out in 11months and get another one under warranty.
Hoenstly the BEHR failed and its only 9 years old, if mercedes made them servicable they would just need a clean up and some grease on the bearing and you're set for another 9 years but they seal it like a lot of things they do so you cant service it.
Old 11-21-2017, 05:22 PM
Mythic Man's Avatar
Yea i was tempted to go with uro since its $80 cheaper. The original blower motor was behr stamped so i went with that , and the few uro buyer beware stories turned me away.
Old 11-23-2017, 09:56 AM
Well only 2 days with the uro blower motor and already it started making noise when its cold, very livable but noticeable, the BEHR is definitely the one to go with for 80$ more, I cant even imagine the 100$ ones on ebay, they must be even worse.
Old 11-23-2017, 11:26 AM
dennish's Avatar
1992 MB 190E, 2016 MB C300
I lubed mine and all is well.
Old 11-24-2017, 08:55 PM
How did you do that ? I tried removing the plastic empeller and I cracked it, they sealed it so you can't service it from what I saw, mine was old and had a lot of black dust, guessing its from the magnets. Im really curious how you took yours apart.
Old 11-26-2017, 11:08 AM
dennish's Avatar
The bearing is easily greased. No need to remove impeller. Easy job on mine (2009)
Old 11-26-2017, 11:53 AM
dennish's Avatar
BTW, URO is $71 @ Rock Auto.
Old 11-26-2017, 12:51 PM
Did you do it or a mechanic did it for you and told you he did it ? The motors have a sealed pressed metal rings that you cant remove so you can't get to the bearings.. If you know a way please share in details because the issues with these motors is they just get noisy because the bearings dries up, they rarely fail completely, just need cleaning and lubrication.
Old 11-26-2017, 12:53 PM
I did have a weird noise at a certain speed but I took it out again to check and one of the screws holding the motor was loose, guess quality control failed for URO parts but once it was tight, it was just as quiet as the oem one.
Old 11-26-2017, 01:36 PM
dennish's Avatar
Do a search here on this forum. Several write ups on lubing.
Quick Reply: Üro parts or BEHR blower motor?
