Retrofitting Wireless Charging
I found the parts for the wireless phone charging from the new W213 E-Class. I'm wondering if I order them ($204 total) I can remove the ashtray and retrofit it into my GLC? The way I see it, it will fit, but the screws holding things in probably will not be arranged the same, and the power source for connecting it is likely not there, even though there is a cigarette lighter and fuses to tap into.
Do you think it's worth a shot? It's looks like it could work. Parts are not returnable.
Here is a photo of each compartment (E-Class with wireless charging vs. GLC Class)
E-Class
GLC Class
E-Class
GLC Class
if it did fit where o you plan on getting power from?
i plugged my phone into the cigarette lighter and blew a fuse. the dealer said since the low amperage there it wasn't designed to charge phone and would probably blow a fuse every time
while i don't believe it i also haven't gone back to confirm it either
GLC43, GTI, X3, Mazda3
Great thought, bummer it doesn't look like it will work. I haven't researched hard enough yet, but was thinking of doing something like this in the center console after getting one of those center console trays/organizers. It wouldn't be OEM, but would be a bit more convenient than plugging in/out everytime you get in/out of the car. Just need to search for a wireless charging pad that might work.
2019 refresh should have an option for wireless charging in the center console. Same as the C class sedan. Also LED head light standard but I see reflectors instead of projectors. Similar to the three series and Volvo LED reflectors. I still like the projectors better though.
I figured out how to do it. There is a pull tab on the cup holder tray that lets you take it out very easily by hand and creates a rectangular cavity. If you cut a foam block the shape of the cavity with a gap for a wireless charger you can buy off the shelf, plug into the cigarette lighter and put a piece of black plastic over the top, it will be the same as the factory one. The only downside is you now have to use the door cup holders.
ajmtbm (02-19-2018)
Appears to have 4 elements though. If aimed a little higher it might performance quite well. However I have always prefer projectors myself. Also the current static projectors looks "cooler" and more aggressive than those reflectors.
i am waiting to get the oem parts. they didnt change external shape of console so internal parts should be able to be replaces and we should be able to install this. The ash tray will need to come out,but it shoudl work!!
I guess wireless charging would be good if you aren't using the smartphone integration. Both CarPlay and Android Auto require the phone to be plugged in anyway -- so I lost my motivation to install a wireless charger.
I'm pretty sure both CarPlay and Android Auto have wireless capabilities now, as of earlier this year.
I was just responding to your post where you said CarPlay and Android Auto were not wireless and letting you know that they both can work wirelessly. Of course, that requires the head unit to support the wireless functionality which is very sparse at this point.
Yes, thanks. I understand that. My point was that in a 2018 or older M-B, the CarPlay is not wireless, so a retrofit of a wireless charger doesn't make sense if you are using CarPlay -- you have to plug in anyway.
Is there any word on a wireless charger we can add to our cars that integrates at least somewhat nicely? The spot after you take the ashtray out would be perfect.
The one I've seen floating around has all sorts of Chinese writing on the front and looks terrible.
Thanks; good find! I like the clean look of that one, but the on/off button gives me pause. Does that mean if I forget to turn it off, it will continue to draw power and drain the car’s battery? If not, why have the on/off button in the first place?
2015 C300 4Matic Sport
This one is nice because it doesn't require you to open the center console. Plus its only $26 and very flat and you can DIY it anywhere, like the arm rest box.
Video link:
https://cloud.video.taobao.com/play/...9113216421.mp4
https://www.aliexpress.com/item/Spec...972437557.html
Video link:
