c63 M156 without any problems ?
Honda Accord v6 3.0 - plan to purchase c63
Hi,
I am new here and reason I joined mbworld is that I plan to buy 2009 c63. Reviewing forum I can see that some of you had issues with head bolts, camshafts ect. My question is: are there users of 2008-2010 c63 who did not have any issue with common problems (so have not replaced head bolts, csmshafts ect) ? If so what mileage you have ?
Regards,nyknow.
Regards,nyknow.
'13 C63 AMG P31
Millage was shown to not be a common or definitive factor for the head bolts failing. Some failed early, while others would never fail. Members will suggest to go ahead and replace them just so it is one less thought or issue later on, that will cost you a quite a bit.
Regards,nyknow.
Mike Malik (12-21-2022)
I think you can keep headbolt in for sure. Corrision is not determined by mileage but maybe time so eventually it will happen. As for camshasht, i think from a vid from youtube, you may last till 200k mikes before it needs a change.
This car is not honda or toyota
I made it to 86k miles and then replaced the headbolts before they broke. Fuel pumps died shortly after.
The car would stall from a stop and would cut out at part throttle acceleration. It would also sometimes feel like it died at constant speed and then KICK you. HG motorsports said they were drawing too much voltage at idle and not enough once throttle was applied. once they replaced them, everything was normal. fuel sender was not replaced
Hi,
Regards,nyknow.
Regards,nyknow.
Regards,
nyknow
I can see that there are not many M156 users who use C63 (for 8-10 years already) and did not experience common problems (Head bolts, camshafts) - I thought that there will be significantly more users with no common issues so far. I plan to buy 2009 C63 this week and will have to think on this (especially head bolts) - my first idea was not to do anything until there are some symptoms (low level of coolant ect).
Regards,
nyknow
Regards,
nyknow
waiting is the wrong answer IMO. it is not a matter of IF it will happen. It is a matter of WHEN it will happen. And waiting until you are losing coolant means a bolt has already broken, significantly increasing the cost of the job and also possibly damaging the engine with a hydrolock. just find an indy shop to do the job before something breaks.
Instead, my 2009 has had 2 sets of fuel pumps in a year (thankfully the second set went bad within warranty from MB but $1900 otherwise), the intake manifold (due to a stupid rubber host which cannot be replaced into the $2500 OEM new part, used ran 1/2 that) and just last week the power steering pump was replaced by the experienced indy shop previously mentioned for $900 (would have been $1600 easy at MB).
So at 3 years of ownership, I've averaged around $1500-2000/year on repairs above and beyond the basic maintenance of oil changes. Add in 3 sets of rear tires (one set/year on a daily driver getting <10,000 miles/year) and one set of fronts. New light bulbs which seem to burn out faster than any car I've ever owned. The real cost of ownership for me is probably $3k/year plus car payment, gas, and insurance.
That doesn't even cover the items I've chosen not to fix. Rear window shade never worked right and would be $1500 from MB to replace. COMMAND knob rotation function stopped working (not an expensive fix necessarily), my COMMAND function buttons not working (press SYS and get a different function like NAVI), and other items I'm forgetting right now.
So if you want to own one of the most awesome engines ever made just be prepared there can be other costs. Keep in mind the car is now probably worth less than just the cost of a new OEM m156 engine.
My advice, be able to afford $30k for one, find a 2011 for ~$20k and either get a great extended warranty or have the spare cash to cover some repairs. Buy it, enjoy it, try not to wreck it.
That's great if you can find a competent indy shop to do the job. I've spoken to 3 shops in the Maryland area which only work on Mercedes. Two won't even touch an AMG for anything more than an oil change. The third has worked on multiple AMGs with the headbolt issue and recommended against doing them preemptively.
I can buy 2009 from person I know, with not so many miles so far (as for 9 year old car) with full service history - that is why currently I dont look for any other option.
doing one bolt at a time (bolt by bolt) may be significantly cheaper and if the result is the same than it is the option to consider (two risks I see are:
1. MB will not be willing to use this method
2. if I decide for this method and during unscrew bolt will be destroyed than probably it will be required to do the desired method (more expensive) ?
Received 2,810 Likes
I think D3-AMG summed it up well. If you can’t stomach that you may be paying $3-5k a year in just maintenance, and also the probability that there’s a $5k repair bill waiting for you in the future, then this isn’t the car for you.
Buy the face-lift W204, you'll have nothing to worry about. If your budget can't stretch for it yet, then I'd recommend waiting and saving up. The little updates and upgrades are worth it, with the headbolt issue being #1 fix.
C63 AMG, P30
Or find a car that's already had the head bolts done. Realistically, this isn't a car for a person that can't DIY things. It's just far to expensive for basic things to be done.
Also keep in mind that arguably a very small subset of C63 owners are probably online regularly, let alone on this forum reporting their issues. So when you ask "How many people haven't had headbolt issues?", the sample size is probably really really small.
