ML500 Battery Drain
Old 04-05-2018, 06:47 PM
anavabi's Avatar
2006 ML500, 2008 ML350
ML500 Battery Drain
Hi,
It is expected that computers use battery even when the car is not running.
I have a brand new battery on my 2006 ML500 and only have to leave it for a week or so when the voltage drops to around 10 and it won't start.
I have an ML350, and very old BMW X5 with over 5 years old batteries, and they both start at a snap even after few weeks of sitting idle.
I've check the drain on ML500 and it's within millivolts. Any suggestion?
Thank you
Old 04-06-2018, 04:18 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Be specific, what brand battery and where did you purchase it>
Old 04-06-2018, 06:14 AM
anavabi's Avatar
Eleminator Ultra, Canadian Tire
But had the same problem prior to changing the battery when the original MB battery was in operation.
My 2008 ML350 still running with the same 10 year old MB battery and has absolutely no hesitation in starting after couple of weeks sitting idle in Canadian winter!
Old 04-06-2018, 06:34 AM
First, could you please UPDATE YOUR PROFILE in USER CP to include the year and where you live.
The only thing I can suggest is to perform a quiescent current consumption test.
File Type: pdf
File Type: pdf
Old 04-06-2018, 09:46 AM
anavabi's Avatar
Thank you Sir. Very elaborate procedure.
As a side note, how do we find out about the models like W164...; transmission type etc. I can only refer to Wikipedia. But is there a more technical way?
Thanks for your help.
Old 04-06-2018, 10:28 AM
First let me tell you that your 06 ML500 is the best of all the W164 models and if you take care of it, it will last for years.
Learning about the 164 can only be archived by visiting the forum daily and read about all the problems, but they are all usually about diesel engines. Save everything that applies to you vehicles and you won't have to search for it in the future.
Here is the explanation of the 722.9 trans.
File Type: pdf
Old 04-06-2018, 11:03 AM
anavabi's Avatar
Thanks again
Old 03-21-2019, 07:11 PM
anavabi's Avatar
Major,
in Test 3 instruction, item 9 states "Remove battery cover (12) and detach cover from positive battery terminal (6)", but that terminal is not used throughout the instruction.
Is there an explanation. It is a very involved procedure.
File Type: pdf
Old 03-22-2019, 05:15 AM
This occurred almost a year ago, and you are still having this problem?
It's time to get this particular scanner and read the codes in every module.
Amazon Amazon
Old 03-22-2019, 07:17 AM
anavabi's Avatar
I have an MB specific Foxwell scanner that can scan all modules and test most components.
Is there a code for battery drainage?
Old 03-22-2019, 08:39 AM
No, but scanning the entire veh. will show you what component/s are affected.
Old 03-22-2019, 10:55 AM
anavabi's Avatar
Ok thanks I'll do that and let you know if there is something I don't understand
But still that item 9 of test #3 is not clear.
Old 03-22-2019, 03:17 PM
texterted's Avatar
ML420 W164 (2009)
Have you checked the condition of the auxiliary battery?
Also, with a cold engine, check the back of the alternator with your hand, see if it's getting warm.
If you have access to a thermal camera that'd be great! Check for hot spots everywhere.
Old 03-22-2019, 04:47 PM
anavabi's Avatar
[QUOTE=texterted;7712300]Have you checked the condition of the auxiliary battery? Apart from voltage, what else has to be checked on the auxiliary?
Also, with a cold engine, check the back of the alternator with your hand, see if it's getting warm. I checked, and it's cold
If you have access to a thermal camera that'd be great! Check for hot spots everywhere. Don't have it yet.
Major,
Please have a look at the item 9 on Test#3 that you sent. I'm following the procedure step by step, item 9 seems to be out of place, or is it?
Thanks,
Old 03-24-2019, 11:12 AM
anavabi's Avatar
Sorry Texterted, I didn't realize the posting was from you!
Old 03-24-2019, 11:14 AM
anavabi's Avatar
One of the codes is "9200 Hall sensor of component M28/1 (Front passenger seat fore/aft adjustment motor) is faulty". Is this repairable or I have to replace the motor?
Thanks,
Old 03-24-2019, 10:55 PM
You have to replace the motor. Here are the instructions.
anavabi (03-24-2019)
Old 03-24-2019, 11:41 PM
anavabi's Avatar
Thanks again Major.
Just for my own education, where is this hall sensor? inside the casing of the motor?
Old 03-25-2019, 05:55 AM
It's part of the motor.
Old 03-25-2019, 06:42 AM
Thanks,
You've said one of the codes is 9200. What are the other codes?
Old 03-25-2019, 08:37 AM
anavabi's Avatar
It's rather funny. I got numerous codes that weren't my concern nevertheless they showed up. Please see attachment.
The code 9000 disappeared the second and third time for some unknown reason.
Please tell me what you think about the codes.
Thanks,
File Type: pdf
Old 03-25-2019, 08:59 AM
Now that you have a record of the codes, delete ALL codes, then drive the truck as usual.
If the CEL comes on, do not turn off the eng. and immediately check for codes in all modules, and document them as you did before. This means that you should carry your Foxwell with you.
If the CEL does not come on, drive the truck as usual, and after three days or so of driving, check for codes in all modules and document them, if any are stored.
Take note that all problems with a vehicle will not illuminate the CEL. You can still have codes stored.
Old 03-25-2019, 09:28 AM
anavabi's Avatar
Sure will. Just let you know that I had no onboard message or as you call CEL for these codes. They only appeaed as the result of scanning the entire system.
Old 03-25-2019, 09:35 AM
I don't call it the CEL, every vehicle manufacturer calls it CEL. Are you aware that your instrument cluster has a CEL light?
Old 03-25-2019, 10:17 AM
anavabi's Avatar
No I wasn't aware of it. I just checked the manual, and I realized why I haven't; apparently the CEL only appears when there are some problems mostly related to emission, on pages 385 and 386; I think this is the case for all cars in general. Thanks for the question.
Rate This Thread
Rate This Thread:
Quick Reply: ML500 Battery Drain
