GTS hard launch issues
Hi Guys,
I been having some issues with my 2016 GTS when i am doing some hard launches of the line.
While in S+ or Race mode when i mash the gas pedal hard at a dead stop the car takes off and then a few seconds later it looses all power for about a second and then the power comes back on and continues just fine.
While the power is gone the traction light comes on as well flashing on the dashboard.
First i thought it was just a traction control issue but i tried it couple of more times but this time with the traction control completely turned OFF and same thing happened again.
If i try it in C or S mode the traction control light still comes on sometimes but everything works just fine, and i do not get the weird power loss.
Has anyone experienced anything similar , or do you have an idea of what is causing this?
I am assuming this is not normal.
It is the traction control. The thing with Benz is that you can not completely turn off traction control. (Except in Dyno mode }. You have to learn to feather the throttle.
The reason it’s better in C mode is because you start off in 2nd gear. Also, try lowering tire pressure to 30 pounds cold.
I spoke with service department of the dealership where i bought the car and he said to bring it in so they can check and see if there is any issues but he things its normal given that the car thinks it loosing control so it cuts the power. I was actually at the AMG driving academy this past monday and their cars did not seem to have that issue. Service guys told me that the AMG academy cars were less restricted or something like that.
From what i recall my car was doing this in the beginning when i bought it but i think it went away. I just put on brand new tires so i am not sure if maybe this has something to do with it. Whit the old tires which were almost bold the car would actually get sideways in S+ and Race mode but even at that point it did NOT cut the power out.
I also called another dealer to speak with them and the service guy told me that he has the same issue on his C63.
I am taking the car in next monday so hopefully this gets resolved other wise i guess i just need to feather the throttle as oppose to a mashing it 100%.
Any feedback is welcome, thanks in advance.
ps. Just looked at tread width difference and it’s over 1 inch according to Michelin. That should really change traction dynamic.
Tires are crucial here. My PSS only have 7 k and plenty of tread for another 3-5 k, but they have heat cycled and they don’t hookup anymore. I’ll be changing to P4S 305/30 in a couple months for summer, which is a tire size up and these run 10mm more than equivalent than PSS. Really wish they had a 305/35 option.
I am going to lower the tire pressure a bit and see what happens.
I think right now they are at 37psi cold
‘24 BMW iX M60
That surely is for sustained high speed conditions, such as the ‘Autobahn’. My recommended cold psi for ‘normal’ street driving is 31 psi at all four corners, and I actually use 28 psi. My car is a GTR though.
2022 AMG SL63
Seems about right to me. For my GTC vert I use the same pressures....actually those are approx. the ones suggested by AMG on the fuel door. If I were racing the car I'd lower that a few.
The delay off the line is partially a traction problem, but it's more so Mercedes developed the car intentionally to prevent drivetrain components from failing. A hard launch puts a lot of stress on the transmission, clutches, differential, etc.; so they put a limit to how much torque is available on your launch in effort to prevent you from coming in to their service department to make a warranty claim.
ronin amg (04-23-2018)
Isn't there also a component of the car learning your driving style? If a car has been driven hard, the learned response from the system will be faster vs a city-traffic driven car. I'm having mine checked at the dealership to see if the system can be reset. There was a post I read (cannot recall where) that gives an in-home means of resetting the system. I had a 6 series MSport that was very adaptive when I drove it hard it responded better.
thebishman (06-22-2018)
I took my GTR to the drag strip tonight.
Similar problem no power off the line.
1. ESP Off, TC 2 red ticks. Off Idle start
2. ESP Off TC completely off, slight rev.
3. ESP Off, TC completely off, Floored Start
4. ESP On, RACE START
Initial lag was so bad, that I was cutting .500-.900 lights as my timing was way off from what I am used to.
Usually I cut .100 or better lights.
The best 60 foot I could muster was a 2.0. Not because there is a lot of wheel spin, but the car is launching so soft.
Race start was just a bunch of wheel hop.
Best run of the night was #2, 11.56 @ 129, good MPH. 129 should be just inside 10's.
Even with just the SC2 tires I was hoping to at least be cutting 1.8 60 foot times.
Oh well, not drag car.
‘24 BMW iX M60
And did you experiment with increasing/decreasing the rpm at launch by using the cruise control?
I don’t drag race so perhaps don’t know what the hell I’m talking about! lol
Bish
Problem with C mode is it starts in 2nd gear. Wonder if his tire pressure was lowered.
im getting the Dragy box next week and will see results.
So far in the limited driving that I’ve had I’ve ran three or four hard pulls and the car hooks up like nothing I’ve ever felt I bet I can get to the high tens.
‘24 BMW iX M60
Good point. So ‘S’ mode and shocks set to soft, and use regular old LC; varying the launch speed.
Did you think about just using LC in various other modes such as ‘C’ or ‘S”? I was just thinking that with the shocks set to a ‘softer’ mode you might not have had as much wheel hop?
Bish
I didn't think about trying C or S mode. Good idea. Next time I will try.
I didn't try dropping the RPM, when I used LC there wasn't enough time given I brought the revs up on the first amber.
With a little practice this should be doable.
This was actually the first time I attempted any digs with the car. So steep learning curve, as I wasn't expecting the initial outcome.
I should have done some practice runs at my 'spot' where I test stuff and break in drag radials.
I suppose there was not a lot of wheel hop, but when trying to cut perfect 60 foot times I consider a few hops a wasted run. Others may think what I experienced as acceptable.
Tires were set at 36psi hot, I didn't air down since I just decided to go home, think about results and what I would try different. There was no sense beating on the car any more that night.
I want to get my times a bit better before I strap on the drag radials. If I can cut a 1.8 -1.9 60 foot I will then throw on the drag radials.
2022 AMG SL63
‘24 BMW iX M60
Bish
(I'm assuming that LC is for Launch Control, i.e. Race Start.)
thebishman (06-24-2018)
OK so I thought I would report back on the new PS4S on the rear of my car. On my super sports the car would just spin constantly through first and then about a couple seconds in second and then would hook up. With the new tires it’s a game changer. Traction control off, Car has a couple of wheel hops and then just hooks immediately and there is no spin after hitting second gear. Car has been transformed traction wise.
Highly recommended.
Highly recommended.
thebishman (06-30-2018)
I went back to the track last night to try a few more launch techniques.
1. C, suspension Soft. TC Off. off idle start. 2.0 60 foot.
1. C, suspension Soft. TC Off. rev/footbrake. 2.1 60 foot.
The car does seem to like to be flashed vs footbraking.
So, I was not able to improve on 60 foot times, traction is not an issue. Torque management will just not allow the car to leave hard.
There is a hope with stickier tires Race Mode will have better results, I will try later in the year perhaps.
I've only tried RM once and a few issues were the track was a bit wet from poor weather, and it was hot and DA was about 4000.
I am thinking that I have not given RM a fair chance.
On a side note, I did trap 130.2 MPH on one run which is pretty impressive in a stock car.
