Help guys! Are these authentic OEM wheels?? (E63 or e63s)
Old 05-22-2018, 11:52 AM
GarrettPrintup's Avatar
2015 Mercedes Benz ML 350 Blutec
Seem to cheap to be OEM maybe? E63 wheels apparently..
Old 05-22-2018, 01:11 PM
stealth.pilot's Avatar
2022 Mercedes EQS 580
These are E43 wheels.
Old 05-22-2018, 01:13 PM
Oem?
Old 05-22-2018, 01:20 PM
Originally Posted by GarrettPrintup
Oem?
Yes OEM E43 wheels.
Old 05-22-2018, 01:32 PM
Correct offset? Someone has mentioned they are replicas. They are on the coast so I waluld have to get them shipped to mw
Old 05-22-2018, 01:39 PM
bobblehead's Avatar
go fast grocery getter wagon
E43 does not have this kind of wheel offering.
I have a set of the mentioned for my winter use (E63).
For E43 real 19" OEM wheels
Front Wheels: 8Jx19 ET20
Rear Wheels: 9Jx19 ET49
Old 05-22-2018, 01:54 PM
Administrator
Vic55's Avatar
2020 Audi R8 V10, 2016 AMG GTS, 2018 E63S Edition 1, 2018 Porsche GTS Cab, 2012 C63 BS
I think they are AMG GTS wheels, split 5.
Actually they are probably not LOL
Old 05-22-2018, 02:05 PM
Would that offset/fitment fit onto my 2012 c250 4matic guys?
Old 05-22-2018, 02:14 PM
bobblehead's Avatar
W204 - 19" OEM setup runs on:
Front Wheels: 8Jx19 ET45 225/35R19
Rear Wheels: 9Jx19 ET54 255/30R19
I don't think it will work
Old 05-22-2018, 02:25 PM
I retract my assertion then. They are not E43 wheels. They do look like the AMG GT wheels vic posted above, but who knows if they are real.
Old 05-22-2018, 02:47 PM
And they won't work for sure on my w204? 😢
Old 05-22-2018, 03:09 PM
bobblehead's Avatar
just on the rims .... the calculation suggests https://www.quattrotires.com/wheel-offset-calculator
the proposed front rim will create a +39mm extension outward of wheel
the proposed rear rim will create a -14mm closer to the strut suspension which could rub against it
Old 05-22-2018, 03:17 PM
Oh jeez.. well I had better hold off on the purchase.. thanks so much
Old 05-22-2018, 03:23 PM
bobblehead's Avatar
the front you cannot do anything to fix the problem.
the rear, even if you put a spacer of like 15mm on, it will clear the strut/suspension components. However, the spacer will now create another problem, that is pushing the wheel outward by another 15mm, thus creating a +27mm extension of the wheel outward.
Old 05-22-2018, 03:26 PM
Smart
Old 05-22-2018, 03:39 PM
bobblehead's Avatar
It would be ideal not to stray off too far from the factory 19" spec. in terms of offset and width (as post #9)
Old 05-22-2018, 04:07 PM
Carac's Avatar
2018 E63S Wagon
They look like the rims that come in the factory E63 winter tire & rim package...but that set runs $6k+
I doubt anyone would sell a legitimate set of 4 OEM rims for less than the retail price of one. No doubt they are replicas.
Old 05-22-2018, 10:13 PM
Super Moderator
Wolfman's Avatar
Received 3,171 Likes on 1,977 Posts
The price is too good to be true but who knows. I would contact the seller and ask to get close-up pics on the inside wheel markings. Easy to spot a rep. this way...
Old 05-22-2018, 11:44 PM
What should I look for? It does say "made in Germany" stamped into the alloy and the MB logo with part number and the offset etc.... Thoughts?
Old 05-22-2018, 11:49 PM
Legit?
Old 05-23-2018, 03:35 AM
Super Moderator
Wolfman's Avatar
Legit?
Part number is legit for E63 19” winter wheels. Likely original.
I’ll buy if you don’t.
Old 05-23-2018, 08:41 AM
Carac's Avatar
2018 E63S Wagon
Counterfeits use the original rims as templates for the castings so anything on the original would show on the fake. The only way to really tell is the first time you hit a small pothole and the wheel deforms like you hit a sinkhole.
Old 05-23-2018, 01:54 PM
Super Moderator
Wolfman's Avatar
I have seen plenty of reps but not with MB part numbers on it. Also, most reps use more generic offsets to fit on more cars.
If those offsets are it and matching the original wheel offsets they are likely original because there would be only a tiny market for it.
Either way, AMG or not, those are low cost cast aluminum wheels.
Naturally it’s best is to see anything in person.
Old 05-23-2018, 02:00 PM
I've seen lots of replicas- but never any with the MB logo stamped on them. Ever. (And part number)..... Thoughts?
Old 05-23-2018, 02:17 PM
Carac's Avatar
2018 E63S Wagon
Well, the price is what would scare me off. 80% off retail falls under "too good to be true".
Quick Reply: Help guys! Are these authentic OEM wheels?? (E63 or e63s)
