LED interior bulb replacement (W212 E550)
Old 06-18-2018, 10:03 PM
mb3ps's Avatar
2014 E550
Just thought I'd share the interior light LED replacement I did on my '14 E550.
This required 18 type 194 wedge bulbs plus one 44mm festoon (where noted):
4 door
4 footwell
2 front vanity
2 front dome
1 glovebox
2 rear reading
1 rear dome (festoon)
2 trunk
1 trunk lid
I did not do the two map lights in the rearview mirror since that replacement looks too complicated/risky, and they already look like they are LED bulbs and have a natural white color temperature (my preference).
I chose superbrightleds.com part numbers:
194-NWHP5: 90 lm, 4100K, 70 mA@13.5 VDC
4410-NW8: 60 lm, 4300K, 110 mA
They are definitely way brighter than the stock incandescents and, true to the part description, a natural white ("NW") versus the yellowish tint of an old fashioned incandescent (~2700K?). They also emit very little waste heat and can be handled easily, unlike the incandescents which are untouchable once they have been on at least a few tens of seconds. It seems that if you open the doors and leave them open for 3,4,5 minutes, the interior lights will time out and turn off, which makes pulling the old incandescents easier on the fingers!
I adjusted the interior ambient lighting color to "neutral" to get a better color match and adjusted the intensity to the maximum of 5 to more closely match the new brightness.
It appears as if the door handles have separate, non-adjustable, very low-intensity lights in a sickly, jaundice-yellow/sodium-vapor color. Curiously, even after the main lights turn off, these remain on for a little longer before they finally turn off. I didn't notice these until I had the car in a dark garage at night. Now I can't unsee them...
And, to my surprise, it appears as if the car maintains a constant bias current through the footwell bulbs, so those are constantly lit while driving at night, i.e., once the doors are closed, they do not shut off as the door and dome lights do. They also do not change in intensity with the ambient lighting adjustment setting.
I never noticed the footwell lights being on before (even with my light grey interior), but given the higher lumens and the fact that they are LEDs, they are a little too bright IMHO. I may replace those with 30 lm bulbs in the future, but I'll see how much the ambient footwell lighting annoys me (most of my driving is sub/urban with high external light pollution anyway). I would think in a car with a black interior, the 90 lm bulbs would be just fine.
Pictures in this album.
The following 3 users liked this post by mb3ps:
CLS63Matt (08-09-2018), Cougar6 (10-07-2019), dannymic (06-21-2018)
Old 06-19-2018, 07:12 PM
JohnnyC's Avatar
2013 GLK350
You should try to wire in the new W205 lights, because they had a ambient light function.
Old 06-20-2018, 11:04 PM
ghlkal's Avatar
2012 E550 v8-Biturbo
Thanks for posting this. Wow, the images sure show the difference between the bulbs!
Old 06-21-2018, 08:41 AM
huewish's Avatar
e350
I have the same color combo as you, but my floor carpet and mats are black. I've done the same lighting upgrades you have, but there are six more that can be done on the outside which I did. The puddle lights in the mirrors are one (a PITA to do), the reverse lights (makes a HUGE difference), and the parking lights which takes away from the dull yellowish color if you have HID headlights retrofit. Regardless, your looks sharp. I'm also jealous of your floor color!
Old 06-21-2018, 09:17 AM
bigjule's Avatar
2007 mercedes e63, 2006 bmw 530 Xi with Mtech kit , 2005 ford expedition
That looks great ... Definitely my next lil mod! Thanks for sharing
Old 07-01-2018, 07:51 PM
F1penguin's Avatar
E350 W212
They look much whiter, thanks for sharing
Old 08-09-2018, 02:39 PM
CLS63Matt's Avatar
CLS63AMG W218 • CM7 Accord • '13 Yamaha R1
Thank you so much for this...
Old 08-21-2018, 03:40 AM
bigjule's Avatar
Any links to source the best onea for my 2015 212 ? Thanks
Old 08-21-2018, 09:45 AM
SPONSOR/MBworld Guru
AZN Optics's Avatar
We can help you out. We carry high end CREE XBD chipsets. Canbus enabled which although you don't need for error cancelling feature, will help with low current leak dim situation with the built in resistance.
Quick Reply: LED interior bulb replacement (W212 E550)
