3WD|AKRAPOVIC EVOLUTION Exhaust System: 2018 Mercedes E 63 AMG
SPONSOR
AKRAPOVIC EVOLUTION EXHAUST SYSTEM: 2018 MERCEDES E 63 AMG:
Perfectly formed using specially developed ultra-lightweight titanium alloys, this Akrapovič Evolution Line (Titanium) exhaust is designed to replace the performance exhaust fitted to the Mercedes-AMG E 63 and E 63 S. It is finished with hand-crafted carbon-fiber tailpipes in matte or high gloss finish, visually split with a newly-designed cast titanium part. This stunning system also includes other parts cast at the in-house foundry, featuring an active X connection and an additional pair of exhaust valves behind the rear mufflers, designed to provide optimal control of the exhaust sound for the best listening enjoyment. The system retains the signature AMG sound, while making it even throatier and richer, and provides great acoustic feedback both inside and outside the cabin. An increase in performance and torque through a broad rpm range and a significant weight savings of over 45% makes this a very serious performance upgrade. With optimized gas flow and reduced back pressure, it allows limitless tuning options. Because it is ECE type approved with no need to remap the
ECU or add any other parts, it has a simple plug-and-play installation.
Part Number:
MTP-ME/T/5H-5-G, Akrapovic 2018 Mercedes Benz E 63 Evolution Line (Titanium) & Link Pipe w/ Gloss Carbon Fiber Tips
MAP: $8,736.30
MTP-ME/T/5H-5-M, Akrapovic 2018 Mercedes Benz E 63 Evolution Line (Titanium) & Link Pipe w/ Matte Carbon Fiber Tips
MAP: $8,686.67
Please contact us for member special pricing...Thank you!
Part Number:
MAP: $8,736.30
MAP: $8,686.67
SPONSOR
SPONSOR
Hello,
Since this is a brand new system, there's not a lot of information regarding this. However we do know this system is made to replace the factory OEM AMG Performance exhaust system. So if you have this and it's valve controlled, then yes your OEM buttons will work.
Thank you!
Thank you!
bobblehead (06-26-2018)
