GL Class (X166) 2013-2015 after facelift became GLS (X166)
Main Screen Retrofit to 9" with CarPlay
Old 06-30-2018, 04:34 PM
Chedman13's Avatar
2014 Mercedes-Benz GL63 AMG
I'm going to try this out. There is one review, "Happy with Purchase. Installation was simple."
It comes with the wiring harness needed and bracket to mount.
https://www.ebay.com/itm/2013-2016-M...EAAOSwshJbDsRU
2013~2016 Mercedes X166 GL63 GL450 GL550 9INCH TOUCH Navigation Screen Monitor
US $899.99
CarPlay is an Extra $99
Fit on : 2012-2015 ML CLASS ALL MODEL . OR 2013-2016 GL CLASS ALL MODEL. WHEN OPEN DOOR HAS ML PICTURE AS WELL .
FULL SIZE 9 INCH SCREEN NAV MONITOR DISPLAY ( TOUCH FUNCTION ONLY WORK ON AFTERMARET MENU OR CARPLAY ( EXTRA $99 ) .
( OEM SCREEN SIZE 6.5INCH OR NO NAV VEHCLE WILL BE 5INCH SIZE )
OEM FACTORY ALL KEEP ORIGINAL . NO CHANGES. JUST BIGGER VIEW
THIS PACKAGE INCLUDE PLUG IN PLAY MONITOR . WITH ALL PLUG IN HARNESS KIT TO MAKE WORK ON YOUR VEHCILE .
WE DONT OFFER RETURN AS THIS IS BRAND NEW ITEM . BUT, ANY ISSUSE EMAIL US FOR REPLACEMENT AS THIS ITEM INCLUDE 1 YEAR LIMITED WARRANTY .
IF YOU WANT TO USE INTERNET / GOOGLE MAP OR OTHER APPS . YOU NEED WIFI TO HAVE SIGINAL . OR USE PERSONAL HOTSPOT TO GET SYSTEM HAVE SIGINAL .
BUT, IF YOU JUST WANT USE ALL ORIGNAL AND JUST LARGE VIEW LOOKS THEN ALL FUNCTION USE AS ORIGINAL AND NO NEED TO GO WITH AFTERMARKET SELECTION .
( TOUCH FUNCTION ONLY WORK WITH AFTERMARKET SELECTION ONLY OEM NAV , RADIO OR OTHER FUNCTION ARE SELECT BY KNOBS AS ORIGINAL NOT TOUCH ) .
HOW TO GO AFT SELECTION ? JUST TOUCH THE SCREEN AND WILL CHANGE TO AFT SELECTION . AND WHEN TOUCH FM/CD ON SCREEN WILL BRING BACK ORIGINAL OEM SCREEN SELECTION .
Features:
OS : Android system
CPU : T3,Cortex-A7 quad core,1.6G
RAM : 1GB DDR3
Flansh :16GB
Built in WIFI
Support USB DVR function (optional, not include, )
Connect external OBD (optional, not include,)
Connect external 3G 4G modem (optional)
Connect external Internal TPMS(optional, not include, )
Capacitive multi-touch screen
Screen resolution: 1024*600
Languages: Multi Country Languages
Function: Explorer ; Full Screen GPS; Air conditioning control; Rearview; Bluetooth; Phone Link;
Built in dual way mirror link function
Built-in Bluetooth for mobile hands-free.
Built in IPOD function
Built in GPS function
Steering wheel control function
USB/SD card port: support MP4,DIVX,JPEG,MP3 and WMA playback
Car backing display: Car reverse camera input (switch automatically) you can use your original view or aftermarket view with steering turning function but, need to change wire to get picture work .
Package include:
1 x Car GPS Navigation
1 x All cable , harness , gps antenna and Bluetooth antenna .
The following 2 users liked this post by Chedman13:
esung81 (10-22-2018), kainedogg (10-26-2020)
Old 07-01-2018, 10:23 AM
DaveW68's Avatar
Location: Land of Political Criminals and Urban Shootings
2015 S550
I'm looking forward to hearing your review of this system and seeing some Youtube videos of it in action. It would be nice if it came with the onscreen menus that come in the 2017+ GLS. It also needs an Android Auto option.
Old 07-03-2018, 01:40 AM
CA_Tallguy's Avatar
1997 E420
It does look interesting. The most critical factor will be the quality of the screen and how it performs in bright sunlight. So it sounds like one option is to just have the factory interface on a bigger screen, and then for $99 they give you a box that replaces the factory COMAND system? Or is COMAND still available in addition to the new options?
Old 07-03-2018, 07:19 AM
BlownV8's Avatar
Received 1,000 Likes on 807 Posts
E55, GLS450, GL63, GLE350
No sat radio - no deal.
Mick1113 (10-26-2020)
Old 07-03-2018, 07:50 AM
DaveW68's Avatar
2015 S550
Apparently you didn't read the description that was posted.
Old 07-03-2018, 08:50 AM
NaviTimer1's Avatar
GL550
I've seen other screens but they appear to be half-baked. The system can only do kilometers, Celsius, and can only display half the screen on certain menu options. This looks like a doable option, please do a video review, if you dice to move forward with the "aftermarket selection".
Old 07-03-2018, 10:05 AM
DaveW68's Avatar
2015 S550
I'm interested in hearing about how it mounts to the dash....and if it will be as sturdy as the units in the modern Benz vehicles. I'm assuming that the original screen will stay in place.
Old 07-03-2018, 11:43 AM
Chedman13's Avatar
Too many unknowns - I haven't received or installed yet.
The hope is that it's fine in direct sunlight and it mirrors exactly what the OEM screen does - with providing a bigger screen and extra menu/functions for Apple CarPlay. The hope also is that any bugs/errors can be updated via software/USB updates and the hardware can remain.
If it mirrors the OEM screen, SAT radio should work. Will my rear entertainment still work? Audio? My DVD in motion? We will see.
Looks cheaper here, not sure if it's the same product:
https://androidautoshop.com/mercedes.../26-map-europe
Also here:
https://www.graviton.no/produkt/klar...ernett-spotify
And here:
https://www.aliexpress.com/item/For-...849210805.html
Videos:
Old 07-08-2018, 08:48 AM
chriswit1's Avatar
2000 ML320
Stock mb screen Conversion
Hey guys love the look of this screen, but I was at the dealer yesterday looking at the new gls and noticed the lower half of the middle dash set up is identical with a different bezel. And also a cut out on the dash behind the new screen. I’ve dine a lot of conversion cars I’ve the years and I really think the stock gls screen will work in the gl450. The ac vents are in the identical spot if you measure. And from the bottom of the screen up is a separate piece. Has anyone tried this, or are the connections and features too different to make it work properly, even if it will fit correctly.
Old 07-08-2018, 09:47 AM
vivaitalia's Avatar
2013 GL450
Oooooooo ... gosh, and all I want is just a bigger, brighter, faster, sharper, higher DPI screen .... hahaha ... ughhhh ... hahaha ... sighhhh ... so many variables software being the most compatibility issue ... so lets hear it from the brave few :-)
Old 07-09-2018, 10:09 AM
NaviTimer1's Avatar
GL550
Why can the US produce these aftermarket devices? I'm very skeptical on conversions, reliability and warranties.
Hopefully someone that in the forums will share their experience, I'm not much of a DIY when it comes to car electronics.
Old 07-09-2018, 12:36 PM
OrionS55's Avatar
2015 GL550 2006 S55
Thumbs up
Good luck. Hope it works out because I'm definitely interested in doing the same.
Old 07-15-2018, 09:51 AM
vivaitalia's Avatar
2013 GL450
gotta hand it to the Japanese :-)
Old 07-15-2018, 02:19 PM
BlownV8's Avatar
MB will have a similar unit that the Toyota has in 5 to 10 years.
Old 07-17-2018, 04:01 PM
NYtoNCGL450's Avatar
2015 GL450
REALLY interested in this. Please post a review ASAP! Thank you!
Old 07-17-2018, 10:25 PM
Chedman13's Avatar
Anyone want to try the "Tesla" retrofit?
https://www.espony-cargo.com/12.1-te...des-benz-ml300
12.1" Tesla style Navigation Vertical Screen Android Radio for Mercedes-Benz ML300 350 2012 2013 2014 2015
  • The Newest Coolest Best Navigation, Big Screen, Android Head Unit/Radio/Stereo
    Intelligent, Running smoothly, WiFi, Bluetooth music and calling, MirrorLink with smartphones, Optional TV, DVR modules, etc.
  • Availability:In Stock
  • Product Code: Mercedes-Benz ML300 350 2012-2015
  • $1,566.00 $1,889.99
Old 07-17-2018, 10:33 PM
Chedman13's Avatar
Install completed, very happy with it. Will do a write-up when I get a chance.
The following 5 users liked this post by Chedman13:
KAHBOOM (05-14-2022), NYtoNCGL450 (07-18-2018), Raja Benz (11-04-2021), Reggie550 (07-21-2021), steh-fan (09-05-2021)
Old 07-24-2018, 10:41 AM
OrionS55's Avatar
2015 GL550 2006 S55
Definitely interested in this screen. Any major drawbacks? Would like to hear what you think.
Old 07-24-2018, 11:06 AM
DaveW68's Avatar
2015 S550
It's been a week. Can we get that write up and some video of it in action?
Old 07-24-2018, 12:28 PM
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
Awesome,. Only for the ML?
Mercedes needs to get away from that stuck on screen on the top of the dash!
Older GL guys have cool solution too:
Old 07-24-2018, 12:47 PM
DaveW68's Avatar
2015 S550
I didn't really care for the stuck on iPad look that has become the norm at the beginning either. But I definitely see how effective they are by being able to use a larger screen that doesn't require the driver to look lower on the center stack. These things have grown on me.
Old 07-24-2018, 12:59 PM
Jason B's Avatar
Yea, but good news is next gl will have w222 style dash where it's built in again. Lol, mercedes going back to their roots again with built in look. You don't what kind of German beer they're drinking sometimes.
Old 07-24-2018, 01:36 PM
Chedman13's Avatar
Initial thoughts:
Very impressed with everything. The fit and quality of the harnesses, wires, cables, bracket, etc. are all great.
Installation took me 4 hours the first time. I could do it in less then 20 minutes now that I know what to do. The biggest thing is knowing where to pull so you don't break any tabs and also to not bend the fiber optic cable.
The OEM screen is removed and a bracket is put in place to hold the new screen. It looks OEM and my MB dealership was impressed with it.
Cons:
Screen quality is not as high as the OEM screen. I believe this has to do with two factors, the scaling factor going from a 7" screen to a 9" screen and then the overall resolution is not as great.
If you wear polarized sunglasses, the screen is completely black. I had to buy a screen protector (http://www.tuffprotect.com/) just ask for a 136mm x 220mm one. I went with clear but you can get anti-glare if you prefer that. Once you put a screen protector, you can see the screen again.
Slightly goes into the vent area on the left and right, but I'm fine with this as I want the largest screen possible.
Aftermarket screen is only in km/h for speed.
Pros:
Looks OEM.
Makes the interior look much newer.
Screen is larger.
Easy installation and easily reversible.
Carplay, Google Maps, web browser are now options in the aftermarket screen.
Touchscreen for aftermarket screen.
Overall:
I don't use the aftermarket screen at all - I have it setup to mirror the OEM screen/display. So no functionality is lost and it works with rear entertainment, etc...
My goal was to have a OEM looking screen, with the look of the newer Mercedes. This product accomplished it, so very happy with it.
The seller on eBay was very helpful and responded to all my emails in how to install it so kudos to him.
This is also the same product and he posts installation videos on a different car but it's very similar:
https://www.youtube.com/user/CKMCardesign/videos
These are also all the videos I used to help me install:
Old 07-25-2018, 11:43 PM
maneesh's Avatar
2002 ML320, 2013 GL450
how does the resolution of the front and back camera, and surround view, look like in terms of video quality and resolution? A newer/loaner GLE with the new screen and a friend's 2016 Nissan Roque have fantastic resolution for front and rear facing cameras/ The GL with the stock screen is a joke for video resolution. DOes this improve the camera resolution? Does the manufacturer provide the screen resolution (IE: 1200x900 ?)
Thanks.
Old 07-25-2018, 11:51 PM
Chedman13's Avatar
Thanks.
No, the screen is worse than the OEM screen. That being said, I can see everything I need to in the 360 camera. I use it all the time too because I have this: https://www.midcityengineering.com/d...era-on-demand/
Screen resolution that is posted on the eBay listing is 1024x600.
Rate This Thread
Rate This Thread:
Quick Reply: Main Screen Retrofit to 9" with CarPlay
