S-Class (W222) 2014-2020
Door Handle recessed lights
Old 08-14-2018, 07:03 PM
chuck007's Avatar
2015 S 550 / SOLD:2012 CLS 550
Angry Door Handle recessed lights
How many out there have one or more of these (very hard to see) handle iights NOT working. They are supposed to come on at night when you grab the handle (any other time ??) The passenger side on my 2015 S550 seem to work but the driver's door handle does not and the passenger (same side) one just blinks on and off. I believe I could get the dealer to fix this (under warranty) but do they have to tear the door apart and possibly cause new problems.....I don't want that !!
Old 08-15-2018, 12:48 AM
Nice Ride's Avatar
2014 S550 AMG, 2017 XT5
I had every one die. From what I understand, the front door handle can be removed easily. The rear door, the panel must come off to remove the handle. And yes, they only come on at night when you Unlock or Lock the car. P.S. Check your sill plates, Driver side went also. 2014 s550 4matic Sport Pkg.
Old 08-15-2018, 04:42 PM
wilfie's Avatar
2014 S550 4matic, 2014 Corvette, 2016 Camaro SS 2011 Lexus RX350
One of mine quit working, off the B to B wty
Old 08-15-2018, 06:49 PM
chuck007's Avatar
How effective are they really......do we really need them ??
Old 08-15-2018, 09:20 PM
wilfie's Avatar
It''s bling but along with all the other nighttime show that happens when you open the car.
it's just gilding the lily.
The puddle lamps are more functional.
Old 08-15-2018, 09:22 PM
ItalianJoe1's Avatar
2003 CL 600
They fail all the time, we are constantly replacing them on 205s, less on 222s it seems. It does require opening the door, but that's not really an issue for any competent tech.
What I don't like, the new ones often don't match the color of the old ones. So many times we will replace the one that's out, then have to replace the other 3 because they don't match anymore. Takes way too much time and doesn't pay well at all.
Old 08-15-2018, 10:23 PM
mb1000's Avatar
S550 4MATIC W221, W222, Lotus Elise
Yes, I had bad light on driver side. At a visit for other things, I asked to replace it under warranty. They had to remove pennal and broke two clip bases and scratched the paint from inside. They ordered and replaced entire pennal then. I am sure they took out some or broke sound isolation things and I can feel a little bit noisy from hear outside.
Now I have rear door led light out I am not going to bring over for service again... I can do much better job myself
Old 08-15-2018, 11:17 PM
S63AMG888's Avatar
MY17 S63AMG - MBUSA Buyback. MY16 SL63 - Sold MY19 W213 E63s. 2020 W213 E63s Wagon
Get this. The door has to be open, but I think it’s pretty cool.
Old 08-16-2018, 02:18 PM
chuck007's Avatar
I installed these on a CLS 550 and they were cool, but the puddle lights on the S550 are smaller and seem trickier to mess with. Any thoughts or suggestions ? I think they can be found on E-Bay.
Old 08-17-2018, 12:11 AM
S63AMG888's Avatar
These shadow lights are just as easy to install as mine E63. Used a flat Wedgy tool to snap the OEM off and the new ones just popps back in.
As for the door handle lights. I would just let the dealer fix/replace it. That’s what our warranty is for and if they mess up which I highly doubt, they’ll have to fix it. I looked at it this PM and it’s not something I’m incline to do.
https://www.ebay.com/itm/2pcs-Laser-LED-Door-Shadow-Projector-Lights-For-Mercedes-benz-W222-S-Class-AMG/122682845804? ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m27 49.l2649
Old 08-17-2018, 10:38 PM
Nice Ride's Avatar
I was told the Front Door handle/light can be removed without pulling the panel. There is a hole for a long allen key inside the door jamb.
Old 08-18-2018, 12:06 AM
2003 CL 600
The light is inside the door on the 205, so you have to pull the handle, then the panel to remove. Maybe the 222 is different.
Old 08-19-2018, 09:30 AM
jiceoo's Avatar
2015 S550 and 2014 GL 550 gone but not forgotten: 2006 ML500
Do your dome lights inside the car have to be on for these lights to project on the ground? I know they did with my 2010 550.
Old 08-19-2018, 04:08 PM
S63AMG888's Avatar
No, the dome light doesn’t need to be on for the shadow light on the door to illuminate. Just open the door and it’ll light up.
It would defeat the purpose if the interior dome light would need to be on for the shadow light to illuminate in my opinion.
Easy swap.
Old 08-30-2018, 10:08 AM
merc.man's Avatar
2014 S550 4MATIC
Sadly yes, I just noticed my left rear door handle light is out, hopefully an easy fix
Old 08-30-2018, 09:19 PM
Nice Ride's Avatar
Front Passenger is out again Nothing but the best.. 4th one in 4 years.
Old 09-04-2018, 12:15 PM
chuck007's Avatar
Yeah.......I thought that the car had 100% LED lights ? So are these handle lights LEDs and if so they should not be going out so soon !!
Old 09-04-2018, 08:47 PM
superpop's Avatar
2019 S63 4Matic+, 2018 E400 Cabrio, wardens car.
I am guessing it is all of the abuse that the fixture takes from the door slamming shut. Probably a design flaw.
Old 09-04-2018, 09:05 PM
2003 CL 600
Doubtful, more likely cheap chinese LED elements, thats why they discolor so badly over a couple years. All about the price at the purchasing level.
Old 09-05-2018, 01:37 AM
Nice Ride's Avatar
Talking
My XT5 has no issues.... And it does not have Soft Close Doors....
Old 10-14-2018, 08:43 PM
SwineHund550's Avatar
2010 S550 4Matic
My 550 is black so I never really noticed the rear passenger side being out... I guess since they go out all the time, I'll see how long it takes for all the others to die.
Old 10-15-2018, 07:32 PM
obwielnls's Avatar
2014 S550
I just had to have my drivers door one replaced under CPO warranty.
Old 10-15-2018, 11:08 PM
Nice Ride's Avatar
Can you please provide me with a copy of your Work order, or Invoice and/or Dealer that covered it under CPO. My local dealer stated they will not cover it. Lights are not covered under CPO. You can PM me or any copy of your documentation would help. Had all 4 lights fail in 4 years, 3 under B2B, last under MB Extended warrantee not covered. They want $275- to replace it...
Old 10-17-2018, 06:25 PM
obwielnls's Avatar
2014 S550
I don't have a copy of that yet. But.... I had just purchased the car and it was one of the items they agreed to fix soo.. It might not actually be covered under the CPO thing.. Might have just been them agreeing to fix it. I'll let you know when I get a copy of the WO.
Old 10-17-2018, 10:52 PM
BSDTWD's Avatar
2014 S550 4Matic and 1968 MB 230
My 2014 S550 CPO had 5 of 6 LED Approach lights go bad. 3 exterior door handle lights and both puddle lamps near bottom of side view mirror housings. Of course this was to be fixed during a prepaid service visit. The Tech input "auto lock unlock inoperable" (in error) and described how all lights were functioning.
Vehicle was returned, I found all lights still inoperable, called Tech and I had to explain what and where the puddle lamps were!!
The only good news is my dealer covered it under CPO. ALL door panels must be removed to access these LED's. Rather sad that their tech's have not only poor listening skills, but also don't know their vehicles. When removing the panels, it's easy for them to break a large white/ main clip near edge of panel. These had to be ordered and shipped from Germany. After 8 days, I finally had my vehicle back.
Quick Reply: Door Handle recessed lights
