Sponsored by: DashLynx
why mostly the RIGHT cntrol arm?
Old 09-14-2018, 02:18 PM
MBS430's Avatar
S550 , S430
Question why mostly the RIGHT cntrol arm?
hi MB enthusiast friends,
I have 2008 S550 RWD.
I experience grunting & clunking when driving speed bump and just replaced the sway bar, both end links and sway bar bracket. It resolved the major creaking sounds but apparently there is another grunting sound, potentially masked by the sound from the way bar at the initial diagnose.
The current suspect the RIGHT control arm.
Questions:
1. from what I searched, I found most of the issue is RIGHT control arm. anybody has idea why mostly right? maybe more weight on the front right?
2. should I might as well replace both RIGHT and LEFT?
3. is the ball joint replaceable or do I need to replace the whole control arm?
Thank you much in advance for your help
Old 09-18-2018, 11:28 AM
Drives550's Avatar
2008 S550
Doesn't exactly answer your question, but after going round-and-round with my dealer on "creaking noises" and what felt to me like hitting bump-stops on lateral movements, both problems were finally solved thus:
1. Thrust Arms (what the dealer called them on the invoice), a.k.a lateral arms (what mbwholesalepartsonline calls them) a.k.a. control arms (what pelican parts calls them) (part no. for the right 221-330-66-11) got rid of the bump-stop feeling on lateral movements (make's sense to me, therefore, to call them lateral arms). This was the one the dealer had the most difficulty identifying as the culprit. They kept telling me nothing was wrong, but I could feel it and finally took them on a ride. Dealer was only going to replace the one I complained of (left side) but I had them do both.
2. Lower Control Arm a.k.a spring control arm (what mbpartsonline calls them and my dealership)(part no 221-330-77-07 for the right) got rid of the creaks/groans. The bad one here was on the right, but both got replaced at the same time.
So, sometimes my dealer did both, sometimes not. I could be wrong but pretty sure you can't buy just the ball joints. All my stuff was under warranty, so I never cared about cost (I've traded the car now that the warranty is up).
Old 09-18-2018, 11:53 AM
YCHU's Avatar
2008 S550, 2004 G500, 2020 Cayenne
Speaking of the Right side, isn't it also the right side airmatic strut that goes out first?
Old 09-20-2018, 09:54 AM
lionsfan54's Avatar
Mercedes Benz S600
Which way does the engine torque? Perhaps that's putting more stress on that one side?
Old 09-20-2018, 12:55 PM
JDowney's Avatar
2012 Mercedes-Benz S350 BlueTEC 2013 ML350 BlueTEC
Hi
Had similar issues on my S350, and was told that is is normal wear and tear. Ended up replacing both lower control arms, and did a front and back brake job. The car is now running a smooth as it ever did when it was new...
Jeff
Old 09-20-2018, 04:59 PM
lionsfan54's Avatar
Mercedes Benz S600
At least on the V-12 cars all those front end parts are considered consumables. They carry a tremendous amount of weight and are subject to some serious twist! The good news is that the parts are pretty cheap and any shop can install them. And, once replaced, you're back to a magic ride
Old 09-20-2018, 06:26 PM
tx170754's Avatar
S560/LS460/Q70L 5.6 AWD
That’s true on the V12, except the rear tires,my brand new Michelin’s PS are almost done after less than 10,000 miles, I guess because the huge amount of torque the V12 has...
Old 09-21-2018, 09:12 AM
lionsfan54's Avatar
Mercedes Benz S600
That's crazy. Do you drive hard? My Kumhos have about 10k on them and appear in good shape still.
Old 09-21-2018, 10:46 AM
tx170754's Avatar
I'm not driving hard at all, not so sure why they're so bad but in the end I guess I have to live with it and eventually order two new tires next year since both the SL and CL will be in my garage for the winter.
Quick Reply: why mostly the RIGHT cntrol arm?
