Engine suddenly dies while driving and dies at idle
Old 09-22-2018, 05:03 PM
Wail maghazi's Avatar
E200 CGI blueefficiency 2010 W212
I own an E200 BlueEFFICIENCY CGI petrol with 35,000 km. My car started to act weirdly about a month ago where it suffered many symptoms such as stalling jerking hesitation and suddenly dying.
i went to the dealer they replaced my spark plugs ,fuel pump and fuel filter and battery and boost pressure sensor and the crankshaft position sensor.
and they told me that they were the issue after i replaced all that yesterday my car hesitated and suddenly died while driving and the check engine light was turned on having a P0119 trouble code and the weird thing that i noticed before it died that on my instrument cluster the displayed outside temperature bounced from 30 to 45 and it kept on changing erratically which is weird.
Please could someone shed some light to my issue?
Old 09-22-2018, 07:31 PM
Sunnyslope48's Avatar
2016 E350 Sport 2WD
P0119 has to do with your engine coolant temp sensor or circuit, could be low on coolant. Maybe jjst replacing the CTS would solve the problem, but check the circuit itself to be sure the circuit is ok and not shorted or corroded.
Old 09-23-2018, 09:35 AM
The weird thing is that when the engine is about to die and starts hesitating i notice that the outside displayed temperature (not the coolant temperature) starts to bounce . Could the CTS also affect the vehicles outside temperature reading?
Old 09-23-2018, 02:07 PM
2016 E350 Sport 2WD
No. It only tells the ECM how warm/cold the engine itself is. The ECM needs to know the engine temp accurately whether it's -10* or 110* outside.
Quick Reply: Engine suddenly dies while driving and dies at idle
