trunk won't latch using trunk button
has anyone experienced this with their w212? mine is 2010. it started a few days ago. the motor works to pull trunk down but won't latch once lid is fully down. i thought it might be something in the way so it won't close but i've cleared out my trunk and still won't latch. thanks
Received 1,616 Likes
2014 E550-sold 😩
The latch may need adjustment or it is broken and in need of replacement.
2014 E550-sold 😩
Try lubricating the electric latch(on the lid) with some silicone spray and inspect it first.to make sure it's not hung up. Adjusting the catch(on the car) is probably not the problem since it will latch when you close the trunk manually. Unless you are having to slam the trunk very hard, in which case the catch may have been moved downward and the electric closer cannot pull the trunk down to work with that new catch position.
2010 e550 p2
To adjust it..
there is a little latch under a black plastic trim piece , you can adjust that , but be careful , mark the position where its sitting in right now and then adjust it.
I had this issue and it was just because the latch had something slightly out of alignment. When the trunk closes itself the motion is cancelled if it detects ANY pressure, so it doesn't shut on your hand or something. Shutting the trunk yourself will allow it to latch fine.
I wish I could help more but my car was under warranty and the dealer fixed it. All I know is it appeared to be fine but they said something was just slightly off.
Konigstiger - can you tell me what the part number 'power/soft closing motor' is? SA told me this is what is causing my trunk not to latch close after the trunk lid goes down. thanks!
can someone tell me the website for mb oem parts is? oemparts.com or something like that?
Received 4,415 Likes
'71 Pinto
https://www.parts.com
https://www.mbdirectparts.com/
https://www.fcpeuro.com/
Removal: https://workshop-manuals.com/mercede...ce_and_repair/
