Advise OBD2 Scanner to buy
Old 10-05-2018, 08:40 PM
jay4usc's Avatar
2001 ML 320
Since i'm starting to run into problems, I think its time to buy a scanner. Can someone give me some advice what Scanner I should purchase?
Old 10-05-2018, 10:34 PM
dtl919's Avatar
2024 GLS580; 2019 E450 4M Coupe; 2019 Lexus ES350
Amazon Amazon
I bought the previous model of the above 5 years ago and it still works like a charm.
Old 10-05-2018, 10:38 PM
jay4usc's Avatar
2001 ML 320
Originally Posted by dtl919
https://www.amazon.com/Autel-AutoLin.../dp/B007XE8C74
thats affordable. It can erase codes? Thanks for the info.
Old 10-05-2018, 10:43 PM
dtl919's Avatar
I don't believe so, but the more expensive ML619 model does.
Old 10-06-2018, 07:56 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
This one will read every module in your vehicle and erase every code if the proper repair has been done.
https://www.amazon.com/Autel-MD802-Maxidiag-System-Multifunctional/dp/B0090B7M2O/ref=sr_1_1?ie=UTF8&qid=1498997615&sr=8-1&keywords=autel+maxidiag https://www.amazon.com/Autel-MD802-Maxidiag-System-Multifunctional/dp/B0090B7M2O/ref=sr_1_1?ie=UTF8&qid=1498997615&sr=8-1&keywords=autel+maxidiag
Old 10-07-2018, 08:12 AM
kraizeg's Avatar
'99 w168, '99 w163
https://www.amazon.com/Autel-MD802-M...autel+maxidiag
Hi, maybe there is something i cant see, this Autel Scanner MD802 Maxidiag Elite in the link you give us is about 600$, but this:
Amazon Amazon
is about 180$.
Please, i have seen both models and seems to be equal, could you indicate which is the difference?
Thank you in advance.
Old 10-07-2018, 10:46 AM
https://www.amazon.com/Autel-MD802-S...ag+Elite&psc=1
is about 180$.
That is an entirely different scanner. Look at the description.
Old 10-07-2018, 10:55 AM
jay4usc's Avatar
2001 ML 320
is about 180$.
the one Dundee recommended is only $228 not $600.
It reads over 50+ modules
Maj. Dundee (10-07-2018)
Old 10-18-2018, 08:29 AM
kraizeg's Avatar
'99 w168, '99 w163
Hi, and what about one which could read both round 35 (?) pins and ours ml OBDII? Any plug conversor?
Thanks in advance
Old 10-18-2018, 09:35 AM
Thanks in advance
MLs do not round 35 pin connector. OBD connector is under the dash.
Old 10-18-2018, 01:46 PM
kraizeg's Avatar
'99 w168, '99 w163
'96 W211 does, and my father has one.
Old 10-19-2018, 05:03 AM
But a W211 is not an ML which the OP owns.
kraizeg (10-19-2018)
Old 10-19-2018, 11:16 AM
kraizeg's Avatar
'99 w168, '99 w163
ThankYou Anyway :d
Edit:
I found an answer, maybe it could help someone:
Amazon Amazon
Autel has a 38 pin to Obd2 plug for round plug connector.
Quick Reply: Advise OBD2 Scanner to buy
