GLC 63 very jerky in shifting
Hello all,
A new owner of a 2018 GLC 63. Had my eye on this for some time and finally pulled the trigger. Love the car but experiencing some weird shifting issues. Basically, at times in S, ECO, S+ the car will start jerking/shifting weird almost like a person learning to drive a stick shift for the first time. Will hover around 2-3k rpm and I have to let off the gas to calm it down. The dealer drove it a few times and was able to duplicate it. They basically said the car has so much torque that this is its way of keeping me safe as one of the wheels is starting to spin. Asked a few folks on FB Merc thread and few people said it's common with 21 tires and to put winter tires on. Either way, feel annoyed spending this kind of money to have this occur. Anyone else have this happen or thoughts on this?
Love everything else about this car
'18 GLC 63, '21 Model Y
There is a thread for this having to do with the GLC43s and summer tires with low temps. I've experienced it with mine (I think) as well but only when it was pretty cold - mid to low 40s.
Interesting. I live in San Francisco area and temps are pretty warm still this time of year. Not sure what the think now
Hello all,
GLC43, GTI, X3, Mazda3
Hello all,
I’ve heard of and experienced it in S+ mode on my 43, but not the other modes. Is it like a bucking back and forth? Are you past break-in? In S+ the throttle is quite sensitive and you can make this happen without realizing until you get the bucking. You can either mash back down on the throttle or upshift using the paddles and it will stop. I thought it was a defect at first, but there is a thread about it (link below) in either the C43 or C63 forum that explains. I believe the dealer can update the trans, but people claim it kinda neuters the car.
https://mbworld.org/forums/c450-c43-...g-instead.html
550orm5 (02-24-2022)
I have a 2019 GLC 63 AMG with the same issues. Not real happy about it either. And if you give it just enough pedal to where if down shifts, not floored, and you let up on the gas, it stays in that gear for at least 10 seconds before it up shifts. Not acceptable on an 85 thousand dollar car !
Think maybe the computer needs a flash or update? This is happening in Comfort mode, not the other modes. Car only has 450 miles on it.
2018 Mercedes GLC63S
On a side note, how do you find the tyre skipping on those tyres? I'm running Michelin pilot sport 4 and they are awful on 1/2 or full lock
Thanks for the info. The tires aren't too bad i guess, but i do notice it. Not sure one tire is better then the rest as far as that goes. i have 20 in wheels instead of 21's so that could be part of it to. Road noise on rough surface pavement is horrible. If it weren't for those 2 things It would damn near be the perfect car.
My thoughts exactly, I'm running 21" and it looks really tricky getting replacement tyres here. Hope you get the jerking fixed or at least make it less annoying.
I just bought a '19 GLC63 and experienced the same thing a few times this week. I noticed when I keep it in manual mode and control the shifts myself, it doesn't do it at all.
AMGSLNC (08-27-2019)
I used to have c63s. It starts in second, and in sports model I can manually start in second, but for the 9 speed tranny I can not manually put in second when car is not moving....
shoe3k (05-25-2019)
I also noticed in all modes the point of where it starts to do the "bronco" thing and it's usually between 0-15% pedal travel and then holding it until you push the accelerator more or shift manually. I literally can do this on command now and avoid it entirely, but there is definitely something that could be programmed out without neutering the driving experience.
My car has been jerky ever since I got it about 6 months ago.
Finally couldn't take it anymore so I took it to the dealer. The tech guy there drove it around the block and right away told me there was something wrong with it. I'm supposed to take the car back on Monday so I can get a loaner.
The car is abnormally jerky in all modes. Even when you're braking and trying to come to a stop in comfort mode, it jerks. I also noticed that if you're braking and coming to a stop and then you let your foot off the brake pedal, it also jerks.
I'm hoping they can fix it. Will report back once I get the car back.
I honestly think its to do with the new 9speed transmission because we also have the 2019 E63s and experience the same issues. I drove the new E53 in sport+, same issue, i think pulling off in 2nd gear like the old C63 would make such a difference because these cars just don't like the slower gears
The ‘jerking’ motion is going to happen when someone isn’t secure in their seat. What’s happening is when you acculturate very quickly it pulls your body back in the seat which takes your foot off the gas then your body slams back in to your seat and bounces forward off the seat back from the immediate deceleration which causes your foot to press more on the gas.....it’s a repeating cycle.
Causes:
driving in race mode and not driving like a racer
fixes:
Press left leg hard to floor securing you in your seat for take off
or
press gas pedal all the way to the floor
watch a racing video (not amateur drag racing) see how a driver sits, see how you don’t sit like this; fix
2019 GLC AMG 63 2018 Jeep Trackhawk
I should have read about the jerking trans before I bought the car! During the test drive I did not encounter a single stop light. I did notice that the trans was not smooth on take off but the car had 35 miles on it.
I am already disgusted. The problem is worse in C mode. The problem is the shift from 1st to 2nd on gentle take off for what must be ECO reasons the trans hurries the up shift after only a few feet and then jerks into gear. It would simple if as with other M-B's, the trans would start in second gear while in C mode but you can't do it! I have a 2015 Hellcat and a 2018 Jeep Trackhawk (hellcat cat motor) both can be eased away from a traffic light without jerking like a teenager learning to use a clutch for the first time. Both pick the correct gear at the right time. I would have thought that M-B would have a fix like reflash for a second gear start.
I hope this is not the start of a new night mare. I bought this car to replace my GLA AMG 45 which had a horrible turbo lag and made city stop and go driving a royal pain. The GLC AMG does not have the turbo lag which is why I bought it for every day stop and go driving. But now I have that jerk up shift from 1 to 2 on slow take offs. Had I known this was a problem that M-B has not addressed I would not have purchased the car.
So put me down as VERY unhappy.
Toughen (07-03-2019)
