Moisture build up with AC on
Old 10-16-2018, 01:56 PM
Njriedel25's Avatar
2015 C300 4matic
Hey all,
So when I run my climate control in the car, is it normal to have this much build up of moisture on the windshield? I usually have everything set to auto but If I don’t change the settings then my whole entire windshield will fog up. Thought the whole point of the climate control was so I didn’t have to blast the windshield and roast myself with heat?
Old 10-18-2018, 01:08 AM
r3dbenz89's Avatar
W213 E53 | 992 C2 | G20 330i
Originally Posted by Njriedel25
Hey all,
The A/C compressor button is probably off...the compressor dries out the air and would clear up moisture on the windows.
Old 10-18-2018, 07:31 AM
GSOTXL's Avatar
2019 MB C300 4Matic (me); 2021 BMW 530i xDrive (husband)
I am in the last days of having a 2016 GLC (until I take delivery of a new 2019 C300, currently in production)....and my GLC does what the bottom picture you posted shows on a very warm and humid day and in the first several minutes after starting the car and running AC. Whether I am heating or cooling, I always have the AC set to on so that the compressor dries out the cabin somewhat. I think it's caused from cooler air hitting the windshield which is warm, and there is enough humidity in the cabin since the car has not been running long. At least that's what I think is happening with my car. If your car is running for a while, the AC is set to on, and you still have that much condensation (or more) then something is likely wrong.
Old 10-18-2018, 09:19 AM
Mikey53's Avatar
2016 C300 4Matic traded in for a 2022 E450 Coupe
Looks normal to me assuming it's warm out with relatively high humidity.
Rate This Thread
Rate This Thread:
Quick Reply: Moisture build up with AC on
