w203 200 kompressor not working right!!
hello i have bought a mercedes 200 kompressor year 2001 and i cant seem to find the problem with the car!
Symptoms: dies after a couple of seconds on idle, goes as usal at normal tempuratures
Whats tested:changed out most inside the enginebay such as Air mass sensor, sparkpluggs, spark coils.
i am not very good at newer mercedes so im kind of lost right now, would appreciate all the help i can get.
sorry for the spelling Mvh johannes!
Here in the states some auto parts stores would loan that tool.
I bought mine at Harbor Fright for 20 bucks.
Where are you at?
BTW- My fuel pump failed, no fault codes. Just no fuel pressure.
When it went I was on the freeway...it didn't die all at once, it was gradual.
I was able to nurse it all the way to my work parking lot amazingly. It had just a smidge of pressure, you could start it barely and it would die...push the gas pedal and nada.
Anything like what you are experiencing? How many miles?
Where are you at?
Hmm i can start the car and rev a litle bit ut then it slowly dies i live in sweden and that kind of pressure test cost about 270 usd and i cant spend that kind of money, i hade checked the pump relay and that works and i can hear the fuelpump When IM swiching the ignition on. And the car has hit 220000 kilometers.
KevinH2000 (10-21-2018)
