C43/55 track car manual transmission conversion
Hi all
After much sheching I知 going to take the manual conversion on. I will do loads of pics and videos detailing how and why.
All parts will be R170 SLK320 sourced I値l trick the ECU with resister at least that痴 what I知 thinking.
Ive found a SLK320 in a scrap yard so will get the parts soon
Hi all
Looking forward to seeing it. A guy in Los Angeles did it on a CLK430. I'll be curious what the weak point in that transmission will be with 5.4 liter power pushing through it. Going to use the factory SLK flywheel and clutch or use something like the Rennsport Factory setup?
Yeah that CLK430 video is cool I値l go all SLK parts to begine with but will later go Rennsport
1999 C43 AMG, 2005 E55 Wagon
I know a guy on the facebook group who used resistor(s) to trick the ECU into thinking it's always in neutral so it's possible. He claims to have already done this exact swap but that it slips. IIRC he wasn't sure if the motor was just too much for the transmission or if he just had a bad transmission
🤔 Could be the clutch slipping that痴 the weak point.
maybe an upretted clutch would help
I admire you doing a transmission swap out on the bricks, especially going into the winter in the UK.
raw1879 (02-04-2020)
Might have to cut bigger hole for the manual selecter
When I did the 5.5 swoop i put a water outlet in the right hand cylinder head for the trans cooler I値l now blank it
raw1879 (04-20-2021)
Clearance is good
Made some new holes for R170 mounting
Feels good changing gear
Cutting hole for gear stick
SLK320 6speed
The linkage on left is from W203 the one on left is from R170 came with gearbox I知 using R170 on it sits further back
The following 2 users liked this post by raw1879:
DRBC43AMG (12-01-2018),
eFifty5AMG (12-01-2018)
Pp
Used alloy bar as spacer mount 15mm thick
Bridged inhibitor switch green and gray wire
Welded in slk320 mount for selector feet
raw1879 (01-22-2019)
Is the starter switch basically to bypass the Park/Neutral signal from the AT?
