15mm spacers
Old 11-17-2018, 10:55 AM
irshad's Avatar
mercedes
15mm spacers
hi
i have a 2010 e350 sport with oem 18 alloys, staggered setup 245/40/18 and 265/35/18.
Can i use 15mm spacers all round? I don’t want to roll the fenders. Does it rub?
my plan after the spacers is change tire size to 245/45r18 and 275/40r18. I have seen w212 with aftermarket wheels running on 245/45r18 but I like the oem look
Old 11-17-2018, 02:22 PM
raja777m's Avatar
2014 E350 4M Diamond Silver
What are the offsets?
Did you check against the WillTheyFit website?
Old 11-17-2018, 06:19 PM
threeMBs's Avatar
Only MBs - the best or nothing
Originally Posted by irshad
hi
Yes you can and no it will not rub with OEM wheels and tires. However, once you switch (per your plan) to much higher sidewall/diameter tires, you most likely will rub.
Quick Reply: 15mm spacers
